Question about Jeep Lantern
Replaced D batteries a week ago but tonight nothing works.
Cannot get lantern to turn on either manually or with remote.
Remote car opener
Does, "batteries ok" mean that you've replaced the battery in your remote? If not, worth doing.
Sep 03, 2014 | 2010 Toyota iQ 1.0
Htc inspire not charging
After going through six chargers, you might conclude the battery is defective. If it shorts, goodbye charger.
Jul 27, 2017 | HTC Inspire 4G Smartphone
Tried to charge my Coleman Retro Lantern, the red light for charging is on but after 24hrs charging, I take the charger off and try to turn the lantern on, it wont work. How can I fix this...
I just bought a retro rechargeable sealed battery,recently. I charged it for 18 hours,the lights all worked,but I don't remember the green light comming on.i put the lantern away for 3 months or so.i decided to check the the battery light out first week of june, the light was there,then I said let me charge it up again, I never seen any green light come on showing it was fully charged. I took the battery out and checked the wires to see if there was a break. None that I could tell. After you take the battery out ,there is another section square that covers where the bulb is located,but I didn't touch that part yet. Stuck" on this one. Help"
Sep 15, 2011 | Coleman Retro Rechargeable Battery Powered...
Nissan Altima 2000 Manual. Recently had remote starter installed and was working fine for a few days. This morning I remote started the vehicle and when I came out car was off. Try starting the car up...
the remote starter is not going to damage the starter, but if wired wrong it could damage the wiring or fuses, or run the battery down from a short.
Jun 11, 2017 | Nissan Altima Cars & Trucks
Our remote control has stopped working. We only bought the set 2 weeks ago and used the batteries provided. It stopped working 2 days ago. We have replaced with new batteries and nothing happens. The...
either the remote is bad or on the tv the circuit board at has the remote receiver on it is bad. If you bought it new and it has a warranty contact them for service. If not you could try programming a universal remote to see if it will work your set.
Sep 11, 2010 | Televison & Video
B93-366 Indoor Unit Ours is mounted on the wall in a new room addition (3 years ago). Has worked fine. Used it with remote control a few days ago. It worked fine. Turned it off with remote control. next...
You will have to remove the front panel and check the fuse to make sure that it did not pop. Also check your breaker switch to make sure that your breaker did not pop. Those can be your really only two issues
Please rate
Jun 01, 2010 | Heating & Cooling
Television displays in blue , only checked all
For your remote problem, mine has stopped working a couple of times and here is what Sharp had me do: Take the batteries out of the compartment. Next press and hold down the power button on the remote for a count of 30 seconds. Return batteries and the RC should be reset. As for the other problem, I had a similar thing happen tonight, hence I am on this site looking for help. My remote quite working, so I did the above, to no avail. I noticed the channel number box was frozen on the screen. I could not turn the TV off manually and had to unplug from AC. I plugged it back in and got sound but no picture, just that bluish dark screen. TV would not turn off. Then I got nothing, no sound, no pic. I left the TV unplugged for several minutes, 5 or so, plugged it in and it did work and is working now, RC too. You might try unplugging it for an extended time.
Jun 11, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Batteries need changing about every 2-3 weeks !!
Three options
1. take out the batts, press every button twice and put new ones in
2.call logitech and see if they will replce it
3. take that baby back to the store and get a new one
Jan 24, 2009 | Logitech HARMONY 659 Remote Control
Focus shut off while slowing to a stop.
check the batterie again also try to jump start the car, and if it does run while you jump start it, then most likelly your alternator is not chargin
Jun 17, 2008 | 2001 Ford Focus
Minka aire ceiling fan
This may not apply. There could be an electrical problem. But if you installed the bulb with your hand, the oil on your skin can cause the buld to heat excessively and fail. I suggest you use the packaging or part of it when installing it, taking great care not to touch it.
Mar 11, 2008 | Dryers
Jeep Lantern Logo
55 people viewed this question
Top Jeep Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Jeep Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
