Have a Maytag (SAV365ZA) top load washer. Has a leak in the bottom of the unit. It does not leak in small loads but, anything bigger and it is a steady stream. Could this be a seal gone bad?
    Brigadier General:
  • 3,917 Answers
Yes you are correct there is a seal which is leaking. Open the washer door and at the top of the inside seal there is a plastic nipple. Normally the water comes out of this area. Make sure that nipple hasn't worked itself loose and pushed back from the seal. If it is pull it back through the hole and line it up with the impression in the seal. We had the same problem and this fixed it.
Let us know if you want to know something else accept the suggestion.
Thanks for contacting fixya.com
Posted on May 28, 2010
I have lse7806ace (stackable) and problem with water leak. I live in condo and this washer/dryer stackable in small closet. I can't reach locking tabs. This stackable is also on the pan (bottom). 'BTW,...
Remove the 2 screws which hold the lower front washer panel , lift out from the bottom and remove the panel.You can now run the machine and use a flashlight to see where the leak maybe. Usually the top tub seal under the plastic tub cover will leak. The other possibility is the main tub bearing and seal on the main tub where the transmission goes up through tub. Hope this helps.
Feb 11, 2011 | Maytag LSE7806A Top Load Stacked...
Maytag washer top loading leaks water seems to be coming from the tub itself 7 years old thank you mija
does unit leak constant or only when spinning ther are 2 screws done low on front panel fill unit with water and watch center shaft there is a seal below basket
inside washer changing seal is a little difficult have also had this style of washer leak when starting spin cycle if water has not drained out fast enough
http://www.repairclinic.com/Washing-Machine-Top-Load-Maytag-Style-Appliance-Diagram
this page has a break down of normal maytag top load machine part at center is called boot and seal have also had thi type unit leak where bolts go through tub
good luck ron
Dec 12, 2009 | Cameras
Hello - we have a top loading Maytag Performa washing machine that leaks water during the spin cycle when my wife is washing heavy items that she has placed on center spindal to avoid an unbalanced load....
Maytag Epic is leaking water from the bottom about 8 or 9 inches from the front door back on the right side. Is there and thing i can do. It only about 2 years old or less.
Oct 13, 2009 | Maytag Performa PAV2200
Maytag Washer leaking from the bottom
It will be the normal trial and error. Remove the top lld and the back panel.statt the wash again and start looking for anything obvious. Start from the soap box, then carefully look down the sides and then if nothing seen, switch machine off and tilt machine untill you can see the underneath. Look for any areas where there is water .(when visible start looking a little higher untill you find the spot.) Most of the underneath areas are likely rust spots that have broken through.. On occation the pipes are perferrated and have a small leak. All observation.
Sep 23, 2009 | Maytag Atlantis MAV6000 Top Load Washer
My Maytag top loader leaks at the bottom of the bucket. I took off the front cover and should see that the wahser at the top of the shaft is leaking. Is this an easy fix?
not easy, unit must be stripped to allow access to bottom seals and bearing/s. Special tools needed and a goog knowlege of the wiring.
Sep 15, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag top load washing machine leaking water from bottom
The machine is leaking water from the bottom, I think the leak is in the area near where the motor is mounted. Before we noticed the water comes from underneath the washer, we smelled like burning rubber.
Al Bana
Jun 26, 2009 | Maytag PAV2300 Top Load Washer
Stackable maytag washer and dryer
Hello, on most Maytag units you can take the the front panel off by removing 2 phillips screws , 1 on each side of the front panel. With the panel off you can run the machine and see where the water is coming from. Good luck
Dec 21, 2008 | Maytag LSE7806A Top Load Stacked...
Oil leak from bottom of maytag neptune tl - about 4 years old
sounds like seal leak in tub water is leaking onto drive unit and washing over it bring and oil it can with it couls be big bucks some parts may be under warranty call service but be sure to get estimate first
Nov 27, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washer leaking water on floor
Need to check drain pump and its hose connections. If its not from the drum seal then that's usually where the leaks occur.
Mar 30, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Washer 5401A
this is a leak in your triple lip seal that has seeped water into your bearing. this requires special wrench and experience to change
Feb 13, 2008 | Maytag SAV5401A Top Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
