Acomdata hard drive used with Apple Airport extreme as hub
Hello
I have an "Apple" looking external hard drive that I want to use as a hub on the airport extreme but my Mac is not reading the drive. Can you help?
    President:
  • 2,600 Answers
Make sure the hard drive is formatted in the FAT32 file system. That is the only file system that Apple uses.
Posted on May 28, 2010
Using an external hard drive for tv recording
in article < The LaCie 1TB Big Disk Extreme Hard Drive with Triple Interface available on the Apple Store looks interesting. The reviews of it and some of the other capacities in the range indicate it is quiet. Anyone used one from that range? Stream it how? I've just tried to watch a a DVD in DVD Player from a VIDEO_TS folder stored on the Mac Pro and shared over the wireless Airport Extreme network. It was very poor. Video and Audio stopping every few frames
Jul 31, 2012 | Seagate Computers & Internet
I am having a problem with my external hard drive I look over and the blue light is good on the Acomdata D32OUFAPE5-72 Hard drive and then I go to explorer and it is no longer in my directory as a...
You can remove the hard drive from the case and put it into another, new usb hard drive case. You can buy one for 20-30 dollars. I have seen this many times before. The hard drive is probably okay, but the controller inside the acomdata case is likely dead. Don't worry, just get a new usb hd case.
Hope this helps!
Regards,
Joe
Jan 04, 2011 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
How to use apple time capsule and apple base station together?
Basically Time capsule is same as Airport extreme base station added with a hard drive to take wireless backup.Put same Network Name and password in both Time capsule and airport base station.Suppose your are making TC as a primary base station and Airport extreme as a secondary base station. Select WDS in both the base stations .In "Wireless Mode" select"Participate in WDS network" in both the base stations.Dont change rest of the options.Put TC Mac id to Extreme base station and extreme Mac ID to TC.now open the airport option in your laptop and check.you can see a single network name.Its DONE.Njoy using wireless
Mar 31, 2010 | Apple MacBook Pro Laptop Computer with...
I have a model HD320UHE5-72 external acomdata hard drive that when pluged into usb and power turned on is not reconized by computer. Vista It worked fine until yesterday.
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Sep 18, 2009 | Acomdata E5 HD320UHE5-72 320 GB USB 2.0...
Can't enable Bi-directional support for Canon MP610
go to cannon website and download new drivers for windows 7. Had the same problem and this fixed it right up
Dec 11, 2008 | Canon MP610 Photo All-In-One Printer
Hard drive doesnt turn on
It appears that your USB hard disk is drawing power that exceeds what the computer's USB port can deliver.
If your USB drive has a power adapter, connect it to your USB drive before you connect it to the computer's USB port.
If your USB drive does not have a power adapter/connector then you need to insert your USB drive into a USB hub that is powered from the mains adapter. Connect this hub to your computer's USB port first and then connect the USB drive into the powered hub.
If none of this works then it is possible that you have a faulty hard drive. If possible test this drive in a computer, use a old computer.
Dec 02, 2008 | Acomdata Computers & Internet
Firewire problem I think - I have a Sony Vaio laptop, the firewire port is 4 pin, it is connected to a LaCie CD Burner via 6 pin and the burner is daisy chained to a AcomData external hard drive via 6 pin....
If the hub has an external power supply it migh do the trick. That way you can have a backup port if needed.
Make sure the hard drive isn't connected to the hub. Sometime windows doesn't see it when its connected to a hub.
Jul 14, 2008 | Computers & Internet
Storage for macbook
I don't think there is another wireless option? You will probably have to buy an external hard drive and use your USB port. That will be your cheapest option.
Jun 15, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
