Question about Vector VEC010BD Jump Start System 300 Amp starting power
I need a replacement part for vec010bd . I need a wall charger to charge this
Charger seems to have both red and green lites flashing at the same time no sequence and both batteries connected read 4.0 VDC, are these chargers repariable or throw aways
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
http://www.invacare.com/doc_files/1125085.pdf
Mar 24, 2016 | Invacare Pronto M51 Power Wheelchair
Is there a way to charge my 930 T on a wall socket AC adapter
The trouble with cheap chargers ' Mobile Fun Blog
www.mobilefun.com/blog/the-trouble-with-cheap-chargers/
Jul 10, 2012 - The abbreviation for amp is A. There are also milliamps which have the abbreviation mA. ... The other way around isn't as much of a problem. If you try tocharge an iPhone (1.1A) using an iPad charger (2.1A), ... micro USB cables can't tell the difference between a wall socket (AC power) and a USB port.
How USB charging works, or how to avoid blowing up your ...
www.extremetech.com > Computing
ExtremeTechAug 26, 2015 - If you take a smartphone which came with a 900mA wall charger, and plug it ... It turns out there's a method to all this madness - but first we have to ... A regular USB 1.0 or 2.0 socket has four pins, and a USB cable has four wires. ..... Last week I couldn't find my phone charger (wall plug), so I tried using ...
What wall plug chargers can be used to charge PS3 ...
gaming.stackexchange.com/.../what-wall-plug-chargers-can-be-used-to-c...
Jun 19, 2012 - I want to charge my PS3 controllers (SIXAXIS) without having the PS3... I have noticed there are (expensive) third party PS3 controller charger ... Why can'tthe normal wall plug chargers, that are able to charge way ... The PS3 controller won't charge when connected to any usb outlet (where only ...
Amazon.com: AC Adapter Wall Charger w/6'FT Power Cable ...
www.amazon.com/Adapter-ChargerCity-Manufacture...
Amazon.com, Inc.
Rating: 5 - ‎5 reviews
ChargerCity GPS AC Wall GPS USB Power Adapter Cable Accessories for ... XXL 550 540 535 530 GO 920 930 720 730 740 630 640 TOM TOM LIVE Traffic GPS ... I don't really have any need for the Micro SD Memory Card Writer so can't ... I now cancharge my TOMTOM from a wall socket instead of leaving it in my car.
Charging your Lumia 930 ' MyUCS
Jan 03, 2016 | Computers & Internet
How do you use the vector start it pro to charge a battery
The overall verdict is this is a poor quality jump starter which has an unreliable charger and a battery that will die if you don't look after it. However, I found one fair report on Amazon amongst many bad ones:
"The compressor on this unit, like so many others this small, is really only made for pumping up toys or bicycle tires. So don't buy this unit for that purpose. Go to a gas station with quarters and use their air vender.
If, like me, you bought a used unit, you will need to get both the manual and the charger. Do a search on servicenet dewalt to find the owners manual. The manual is a download pdf. Charger model number is 514005-42.
Hope this helps. It's really a neat little device to have around. I especially like the built-in LED flashlight.
You really NEED to read the manual all the way through. The special sealed type battery requires charging at least every 60 days or it WILL go bad quickly."
The Manual is here: http://documents2.dewalt.com/documents/English/Instruction%20Manual/Vector/VEC010BD.pdf
Because I'm an engineer I know I could easily replace the 12v lead-acid battery charger, open the box and replace the battery with another 12v say 200 Amp cranking (short circuit effectively) battery but I would tend to spend a bit more on a gel battery of similar spec 'cos it basically is the only sort that should be used for deep cycle discharge with such a small volume battery. Good luck.
Jan 25, 2014 | JUMP START SYSTEM
I need the instructions for Black and Decker Start It How do I recharge it?
This unit is recharged using any household 120v outlet. Remove the rubber cap from the recharge port on the top of the unit. Plug the barrel end of the adapter cord into this port and then the put the adapter into the wall outlet. Make sure the power switch is in the off position. To check the charge level push the button to the left of the 3 indicator lights. When the green LED lights up, the unit is fully charged, (yellow is moderate charge and red is minimum charge).
Try to charge the unit from the minimum (red) charge level to maintain the maximum battery life and use of the product.
If you have misplaced the manual I am providing a link to it from Black and Decker's site.
http://servicenet.blackanddecker.com/documents/English/Instruction%20Manual/90550872,VEC010BD.pdf
Have a great day.
Jim
Dec 30, 2010 | Vacuums
My phone is not charging
If your phone is not charging, try use a similar charger to charge to see if it is charger problem, if the similar charger did not charge your phone, it means the problem is the charging port on your phone.
The charging port of your phone is bad and will need to be replace. Replace the charging port on your phone to solve the problem of your phone not charging.
Once the charging port is replaced, the not charging problem with your phone solve.
Take care.
Jul 23, 2010 | Sony Ericsson Walkman® W880i Cellular...
Vec010bd AC charger part # 5140045-34 question . . .
barrel pin 12v 500Ma is correct. the only other required stat that you need to know is that the polarity is( ---------that's how the inside pin polarity is shown on the transformer. Go to any radio Shack, and they have this charger in stock. tell them you need a 120v. a/c input, 12v. DC 500 ma output, with the center (inside) pin positive( ).It should be less than $20.00
Feb 20, 2010 | JUMP START SYSTEM
IPhone wont charge after plugging into the wall.
There are three solutions to your problem:
1) The battery needs to be replaced; or
2) The charger is defective (if you have a car charger you can use it to see if the phone will charge. If it will you'll need to replace the wall charger.) or
3) Your phone needs to be sent to a service facility for repair.
Feb 01, 2010 | Apple iPhone Smartphone
Charger won't charge
The unit is probably bad. Mine just died turned out its the wall wart. The wall wart is a transformer only set up and outputs about 17VAC. The DC conversion is done in the clip. Only option I found was to replace the charger with the new multivolt charger , Upside batteries charge in about an hour to hour+1/2 vice 3 hours.
Jun 13, 2009 | Black & Decker 14.4 Volt Battery Charger...
Need instructions on how to use black and decker jump start
Amazon.com: Customer Reviews: Black & Decker VEC010BD Start It 300 Amp ... Instructions note that units are already partially charged before ... Recent discussions in the Black & Decker VEC010BD Start It 300 Amp Jump Starter forum ...amazon.com/Black-Decker-VEC010BD-Start-Starter/.../B000E1HAIK - 235k - Cached
Feb 22, 2009 | Black & Decker Jump Start System 300 Amp...
Razr will not charge with wall charger
Your charger is faulty. If your phone is able to charge off of other sources (computer, car charger, another wall charger) Then, the charger needs to be replaced. Some mobile companies have a 90 warranty on accessories like the charger and battery. Then the mobile manufacture (Motorola) has a 1 year warranty on the charge and battery. I would check on that, and get those replaced.
Feb 04, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Vector VEC010BD Jump Start System 300 Amp starting power Logo
191 people viewed this question
Top Vector Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Vector Hammering Expert? Answer questions, earn points and help others
