Question about Remington Electric Pole Saw
Center of plastic motor housing melted away at end of shaft. Have there been any recalls for this problem?
    Brigadier General:
  • 4,088 Answers
If there were any, there is now no company to honor them as they have gone out of business. Some parts are still available from various dealers, but it takes some serious web searching to find them (the parts, that is). Good luck!
Posted on May 28, 2010
How do I fix my Kitchenaid food processor? Motor hums but center shaft is stuck and won't turn.
Hi Eric, you are going to have to get the motor out and yes it will be because of the spilled liquid fusing/rusting the motor armature shaft into the bronze bush. Those motors are very expensive so worth a go to save it. You will have to get the plastic sleeve off that shaft first before you can get the motor out. Removal will destroy the sleeve. I drill a hole through the top of the sleeve, side to side leaving about 5mm of meat at the top. I shackle a chain through it and attach it to my bench leg and then accelerate the whole motor unit away in a straight line. The shaft needs to be pointing at the attachment point on the bench or it can slip from your hands creating more grief. It will only take 1 to 3 pulls, 1st one doesn't work do it harder, same with second pull and harder for the 3rd. The chain needs to have welded links or the chain will break. That is far the easiest removal method I have found, other methods could involve hacksawing it down one side being careful not to damage the metal shaft or melting a line down 1 side to split it open with a soldering iron. Once that is off then remove base, detach motor wires from pcb and remove the screws under the plastic caps on top of the top housing. Then it will be working away with levers and a spanner on the shaft and CRC, sweat and time. If you strike trouble after that email me
screaming_skull@hotmail.com Cheers Ross
Apr 03, 2015 | KitchenAid KFP600 Ultra Power 11 Cups Food...
Disassembling a robot coupe mp450
First you drill out the plastic plugs to acess the torx screws holding the housing together. Remove 4 motor mounting screws to separate from shaft.
May 28, 2013 | Robot Coupe MP450 Handheld Blender
Im trying to replace a fan on a simplicity freedom f3300 vacum. HOW DOES THE OLD FAN COME OFF? It seems to be pressed on but I dont want to brake anything.
Assuming you have the motor out of the fan housings, check to see if you can move the fan around clockwise/counter-clockwise. If the fan is not moveable, the fan has probably melted to the motor housing. Replacing the motor is recommended as the plastic motor housing under the fan is probably damaged/melted. It could still be fixed but there is a possibility of damaging the housing. If after removing the fan following the directions below be sure to remove/trim any melted plastic away from housing before replacing fan. Not trimming the plastic could result in your new fan melting again to the housing when the machine is turned on. If you have an older model pay careful attention to the carbon brush area, if there are plastic posts holding the carbon brush springs, these are easy to break.
If the fan is movable, remove the nut and washers from fan. Use two large flat head screwdrivers and place them opposite of each other under the bottom lip of the fan between the fan and motor housing. (it might be a little easier if you have an extra pair of hands to hold the motor). With the flat heads in place, push the handles of the flatheads toward the side of the motor where the belt shaft is. If the fan does not pop off rotate the position of the screwdrivers and try again. Pay close attention that the fan washer is installed before replacing your new fan. after installing the new fan, rotate it several times making sure it isn't rubbing anywhere.
If you need any further help feel free to contact me.
Tim
TheVacCenter.com
Mar 02, 2013 | Simplicity Freedom Cord - F3300 -...
Impeller dropped off. Replaced the hub but did it again.
maybe you should be using a washer and a nut to securely fix the plastic hub in place
Jul 13, 2017 | Garden
The wash basket is off and there are pieces of melted plastic in my clothes.
Check whirlpool website for recall. Check fan belt for wear. check basket housing holder for loose screws or bolts. Check to see if you purchased an extended warranty. last check to see if store you purchased from will help with repair cost if you did not get extended warranty.
Nov 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
TDA200 Recirculating pump how to replace impellor
There are a number of screws on the pump housing opposite the motor that can be removed to open the pump and expose the impeller. Some pumps have a screw into the center of the shaft that helps keep the impeller from spinning off the shaft. It often is a left handed screw. Once any center screw is removed the cover on the other end of the pump should be removed to expose the end of the motor shaft. This end of the shaft should be held solid with a wrench while the impellor is unscrewed. These threads are usually right handed. The process can be reversed with a new impeller. I hope this helps.
Aug 13, 2011 | Pool & Spa
Vacuum Belt keep breaking
When your first belt burnt, the burnt plastics goes into the roller ends and then it dries off causing your roller to not turn or put more pressure on your belt. Until you clean that you will continue burning your belts soon after you put them in. You need to add a little bit of WD40 or any other type of lubricant after you remove the tar from the roller.
Feb 26, 2010 | Dirt Devil Breeze Bagless VacuumVacuum
Rear wiper motor does not work
It is possible to fix the problem; it is not the motor itself - the shaft/housing gets corroded and eventually seizes. Remove the wiper and bolts from the outside and the panel on the inside. Remove the wiper motor, take the screws out and open the motor. Put as much solvent as you can into the shaft area and let it soak. Put the nut back on the the end of the shaft and tap the shaft loose as far as it will go - us a punch in the center of the shaft so you don't screw up the threads. Remove the nut and continue to twist and tap the shaft out. It is possible the corrosion was very bad nad the housing is now cracked or worse by forcing the shaft out of that area. You will need to determine whether it is still ok for use. As long as there is a good amount of meat for the shaft to run in, it should be ok. Also - the nut still has to go on the end of the housing. You will also have to look at the big plastic gear and ensure it is still good - the metal worm gear may have grinded it down too far depending on how many times it has cycled. Once its out, its straight forward to clean and smooth down the shaft and housing, load up the whole thing with lithium grease and reassemble. If it proves to be pointless along the way, no haven't lost anything and would have had to remove the unit to replace it anyways.
Sep 26, 2009 | 2006 Chevrolet Uplander
Replace liftmaster 1245R drive/worm gear
I have a 1265 and took the cover off (unplug first).
There are screws securing the cover: 2 on each side at top, 2 at either end bottom.
Then I disconnected the chain.
There are 3 hex head screws securing the drive gear assembly (of course they thread from the inside out which makes taking them out a bit time consuming). Take care not to damage the circuit board or other electronic connections.
Then at the bottom of the shaft is the "limit switch assembly" that is clipped into the metal housing. Squeeze the 2 on the outside and it should swing free.
Then at the very end of the shaft there is another plastic gear. It is secured by a 3 prong plastic clip. Pull the outside clips away from the shaft while pushing the center piece back through the shaft. The gear should come off and you can now remove the gear and sprocket assembly up through the assembly.
call 800 528 2817 and order the "Gear and Sprocket Assembly".
I am waiting for the part and assume we reverse the order above to reinstall.
Oct 23, 2008 | Sears Craftsman LiftMaster Chamberlain...
I have a whirlpool gas dryer model number LGR5636JQ1. The belt burner up, when I went to replace it I noticed the thick plastic piece on the motor shaft had melted. Is this piece necessary? If so how do...
I assume you mean the cone shaped plastic on the motor shaft. this is not necessary, it is there to keep a worn belt from riding onto the shaft. if the belt and idler(should be replace with belt) are good it shouldn't cause a problem.
J
Jun 12, 2008 | Whirlpool Dryers
Remington Electric Pole Saw Logo
55 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
roeb
Are you a Remington Garden Expert? Answer questions, earn points and help others
