Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
HI On a GE range-model #GRCR3825ZBB-1, shortly after oven is turned on-"door"is displayed in control screen & oven will not heat.I couldn,t find that error code--do you know what it means? Thanks Rene
  • 10,515 Answers
What you will need to do is pull the control panel off of the front of the range so that you can get to the door lock mechanism. You will need to check to see if you are getting power to the lock. If you are then you will need to replace the lock assembly. If you are not getting power to the lock assembly then the control module will have to be replaced.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 28, 2010
  • Rene Matz Jun 01, 2010
    This couple had the same problem--bake cycle would start-- then"door" would display when the
    range was still on warranty. They are to letme know which part was replaced--I,m sure it was the
    clock. Thanks Rene
Ge model jb400d oven will not heat up
Troubleshooting Why Your Gas Oven Won't Ignite or Heat ...
? 4:39
https://www.youtube.com/watch?v=Oe0BJmXhh7M
Dec 20, 2012 - Uploaded by PartSelect
Remember, parts are specific to your model and the ones shown t. ... Range/Stove/Oven Repair - Replacing ...
Gas Oven Won't Heat - How to Repair (Part 1 of 2 ... - YouTube
? 9:20
https://www.youtube.com/watch?v=sHWRRMrIpfU
Jan 29, 2012 - Uploaded by Tomahawk DIY
If I order on ebay for ge gas range oven ignitor do they as formodel #? .... removed the entire gas tube with ...
GE, Hotpoint & RCA - Wall Oven Diagnostic - Not heating ...
? 11:16
https://www.youtube.com/watch?v=BQNs4gHlT_A
Jun 13, 2013 - Uploaded by ApplianceVideo.com
Fix a GE Wall Oven which has some of the following dilemmas:Not heating By ... GE, Hotpoint & RCA ..
Dec 30, 2015 | GE Kitchen Ranges
GE Model J S968S0F4SS. During bake display goes bake, oven turns off.
Oven Does Not Heat, But The Burners Heat - GE Appliances
products.geappliances.com/appliance/gea-support-search-content?...
Range - Oven Does Not Heat, But The Burners Heat. To minimize the ... Turn yourrange OFF and either remove the fuses or turn the breaker OFF. Then unplug ...
How To Fix Oven With Little or No Heat When Baking ...
Troubleshooting Why Your Oven Won't Heat ' PartSelect ...
? 2:54
https://www.youtube.com/watch?v=ketJHf3rrSk
Sep 14, 2011 - Uploaded by PartSelect
In this video you'll learn why your oven may not be heatingproperly. ... Neither the bake or broil elements ..
Oct 31, 2015 | GE Kitchen Ranges
Ge stove oven get a f4 fault
Open or shorted oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.What is the model number?
Nov 08, 2012 | GE Stove/Range/Oven Oven Control -...
Ge true temp oven with an F1 code...what is it...model #J KP15AOA
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Feb 10, 2010 | Kitchen Ranges
Controlpanel flashes f 3
You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
Oct 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
F2e0 error on stove
Turn off the breaker and wait for 5 minutes. the follow this 3 steps:
--> After turn the breaker back on, go to the range and press "OFF", "OFF", "START", then click on the "clock set", there is a message on the display saying that do you want to delete the error, at this time press on the "START" again. And wait for a while until the everything on the screen disappear except the clock time. Hope this will fix yours. It fixed mine.
Dec 28, 2008 | KitchenAid KESC307 Electric Kitchen Range
Oven not working
This is either a faulty display panel, or a short inside the oven that is causing the panel malfunctioning.
The wirings, elements (both), thermostat contacts inside the oven must be checked for an eventual short. If there is none, replace the control assembly.
You find parts and diagrams here, just enter the correct model number.
Dec 20, 2008 | GE JBP80 Electric Kitchen Range
GE Range Model GRCR3825ZWW-1 DOOR error code on range display
The door latched Micro-switch is not working or is dirty.
Remove the back panel, in the middle of the back there will be a metal arm that moves in and out when self cleaning latch is closed and opened. This arm pushes two or more Micro-Switches in the back, they are dirty or not working and need replacing.
Nov 05, 2008 | Kitchen Ranges
GE Profile Still Heating with nothing selected
IS THIS A DIGITAL RANGE,IF SO REMOVE THE TOP BACK COVER AND SEE IF ANYTHING ARCED(BURNED SPOTS) ON THE CONTROL BOARD,IF NOT DIGITAL, YOUR OVEN KNOB SWITCH IS STUCK IN CLEAN MODE,I HOPE IT'S NOT THE CONTROL BOARD AS THEY RUN ABOUT $200 ,LET ME KNOW-MIKE
Jun 15, 2008 | GE JBP65 Electric Kitchen Range
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
236 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
