"K" in pink background after part installation LCD tv from sharp
A k in a pink background appears after i install a new powerboard in an lcd television made by sharp. How can i get rid of it?
    Sergeant:
  • 380 Answers
When you see the "K," hit channel down and volume down on the tv. Hit the down arrow key once. You should see some the says factory init. Use the channel up and down to select "Factory Init" and hit the right key to change to yes and hit ok. Once it turns green, unplug set for 30 seconds and plug back in.
post back here if I was too vague or if you get confused and I'll write up a more easier one.
Posted on May 28, 2010
  • Paul May 28, 2010
    1. unplug tv
    2. press and hold at the same time “Vol –“ and “input” button on the TV set.
    3. while holding those buttons, plug the tv back in
    4. the tv should turn on by itself, keep holding the
      buttons until the letter “K” appears. Then let go
    5. then at the same time press “Vol –“ and “Ch. Down”, you
      should see the service menu appear (if it does not appear, try pressing
      the two buttons again, it needs to be exactly at the same time)
    6. Then use the “Ch. Down” button to navigate down the service menu until you see
      “Industry Init” (NOT Industry Init +cause)
    7. Then press “Vol +” to toggle it to “ON”
    8. Then “/////////////////” should appear.
    9. when the screen turns GREEN, unplug the TV. Wait about
      30 seconds, then plug the TV back in.
    10. Then continue on with the initial setup again.
Tv turns on but backlight fails to light up,
Have to make sure all ribbons are seated, and tabs locked. If any.
Feb 10, 2014 | Sharp LC60LE810UN 60 in. LCD TV
52inch Sharp Aquos has a constant blue blinking power on light no picture at all.Tried the resets,still the same,installed new inverter boards,still the same.Now what?
This problems is not those 2 long LCD inverter boards problems,why did u replaced those 2 long LCD inverter boards?I fix this problems before for a 46" LCD Sharp Aquos L46D55U tv.This problems,it the Tuner signal board is dead.That the board,where the incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Nov 08, 2010 | Sharp LC52D65U 52 in. LCD TV
Plugged in a new cpu and the background is pink. I have tried to solve with appearances and no luck. I have another flat panel and plugged it in and get the same pink background. I think I am in a *****...
I think youa are using a VGA Connector, check if there is any bent pins. Reseat the VGA Cable once or try out with a diffrent cable. If that also does not work, then its a issue with the monitor.
Thanks and Regards
Mar 26, 2010 | Envision EN-7100e 17" Flat Panel LCD...
Sharpe lc32sb27u & DVD and everything is pink
test dvd on another tv, or change the cable,this is probably some electrical problems on lcd output connector, or the cable defective
Nov 28, 2009 | Sharp LC32SB27U LCD TV
Screen returned from supplier background bright pink, how do I change to white background.
To check if the video card or the Sharp LCD monitor is faulty, connect a different monitor to the computer. If this monitor displays a normal image then the video card is OK and the Sharp LCD monitor's back-light is faulty. Send it back to the supplier to have it fixed (they should not have reurned it to you in this condition).
If the other monitor also displays a bright pink background then the video card is faulty and needs to be replaced.
Nov 19, 2009 | Sharp Computers & Internet
Small white hole on LCD screen
Sorry to be the bearer of bad news, but you have what is called a "dead" pixel. Only repair would be to replace the LCD. I would like to think you would not spend $1400 to fix this problem.
Jul 11, 2009 | Sharp AQUOS LC-42D85U 42 in. LCD TV
Dark lines appearing across my lcd tv
This is symptom of LCD Faulty. Please note down cost of LCD is much high. In my suggestion
you change or purchase new TV
Nov 12, 2008 | Televison & Video
Sharp LCD TV LC-37GP1U flashing green power light
Unplug the unit for 1 minute, replug and try again. If it doesn't work the power supply is faulted and it needs professional service.
Sep 10, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Vertical Line
could be the logic board, but , unfortunately, more likely the lcd panel itself. very unlikely to be economically repaired. new panel and labor a few hundred $'s less than new tv
May 24, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
