Question about LG Microwave Ovens
How do i remove the broken door handle to replace with the new one? Do I remove the frame on the inside of the door to reveal the screws to remove the inner frame to reveal the screws for the door?
  • LG Master
  • 9,047 Answers
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.We may have the service manual for download. Feel free to e-mail us at prototech@usa.net.
Posted on May 28, 2010
How to replace the door handle on a whirlpool MH2155XPQ micro wave
The screws that hold on the handle are inside the door assembly. Here is the way its done but its not for the average person. On the inside of the door is a plastic frame all the way around the door. It is held in place by plastic tabs. You have to gently pry off that frame with something like a putty knife or small screw driver. If you are not careful you end up breaking off some of the tabs. Once that frame is off you should have access to the 2 screws holding on the handle. Remove screws---replace handle---and push plastic frame back on.
Jun 26, 2015 | Whirlpool MH1150XM Convection/Microwave...
Trying to replace handle on door,removed three screws on side of door unable to remove inside panel
Most microwave doors are just clipped together with plastic tabs.To remove the inner door panel you need to carefully pry the plastic frame off the inside with something like a small screwdriver or putty knife. Even being careful you may end up breaking the tabs or frame. Once the inner frame is removed you should be able to get to the handle screws. I'll try to attach a picture of the door breakdown.
May 09, 2015 | Whirlpool MH7140XF Microwave Oven
Mmi have a ge advantiun x20 model SCA1001FSS01 THE HNDLE IS BROKEN OFF HOW DO i REPLACE THIS pafife@yahoo.com
HELLO.
THE SOLUTION ON HOW TO REPLACE THE BROKEN HANDLE
THINGS NEEDED.
Phillips screwdriver.
Thin, flat-head screwdriver.
Putty knife.
Replacement microwave door handle.
1 Examine the inside of the door. The handles of some early GE Spacemaker microwave models were attached after the two inner door panels were assembled to the outer door. If you see two recessed screws opposite the handle attaching points, undo them with a Phillips screwdriver and remove the handle. If not, go to the next step.
2 Insert the blade of a thin, flat-head screwdriver into the top, outer corner of the door, between the plastic inner frame and the outer door. Gently pry the inner frame out and slip a putty knife into the exposed opening on top of the door. Slide the putty knife toward the hinges to free the top of the inner frame; repeat on the front and bottom edges of the door and lift the inner frame out to expose a second metal inner frame.
3 Insert a thin, flat-head screwdriver into each of the small square openings on the top and bottom of the inner metal frame, starting at the handle end of the door. Undo the attaching clips by gently levering the inner door away, using the rim of the outer door as a fulcrum. Move the inner door away from the outer door on its hinges.
4 Remove the glass from the outer door. Undo the two screws holding the handle to the outer door with a Phillips screwdriver. Screw the replacement handle onto the door and tighten securely.
5 Replace the glass panel and reassemble the door by snapping the two inner frames back in place.
Thanks.
Aug 30, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Need to replace broken door handle. Cannot get to screws inside door to release broken handle and replace with new handle.
Look for a removable insert around the inside window. If not there may be screws along the outside edges to separate the door sections. Eric
Aug 02, 2009 | GE JVM1650 1000 Watts Microwave Oven
I would like to replace the microwave oven handle.
The inside of the door has a Black Plastic frame about 1 inch wide. This frame can be removed by placing a thin screwdriver between it and the outer door frame and gently (very gently) prying it away from the door. It takes a little wiggling of the frame but it will unlock. On each end of the handle is a philips head screw that holds the handle to the door.
Jan 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Repalce Door handle on GE Profile model number SCA1000DBB03
There're some half a dozen or so small screws securing that frame to the door face. These screws must be removed. Then, the frame can be pried out by releasing the plastic snappers (with a flat screwdriver) while in the same time gently helping the frame to detach from these snappers' hold and the door face. It's a tidious, somewhat annoying task. The snappers may and will even likely break in the process, but aren't needed for the frame to be resecured to the door face after the handle is replaced. Note that the broken ends of the handle must be held with a pair of pliers or a flat screwdriver needs to be inserted bewteen each of them and the hole, or the ends will turn with the screws. This is because the metal screws' grip of the plastic handle broken ends is very strong and will otherwise won't get separated.Once the above is accomplished, reassembling the door is a brease.
P.S.: The dual end latch may interfere somewhat with the job and can be removed for the prtocess to be undertaken without it disturbing. It's easy to remove and replace that latch, including its spring.
Nov 07, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Oven Door Handle Replacement
You shoul take off the hole door, use something like a flat screw driver and wedge the plate off.
some of the mics got tamper holes where it hooks in.
Hope it works...
Sep 09, 2008 | Whirlpool MH7155XM Microwave Oven
Jvm 1410 spacemaker xl1400
not the easiest thing in the world to do. From my notes, that requires actually removing that door. ughhh/
Apr 02, 2008 | Microwave Ovens
Microwave door handle replacement
Solution for GE Spacemaker Ovens (my model is JVM1650BH05)
1- Remove door by lifting it out of hinges. You will need to remove grille first (2 set screws).
2- Carefully pry off the plastic inside door trim. Use a fine knife or putty knife. There are 10 tabs holding the trim from behind. It's OK if you break a tab! Try to pull out as straight as possible.
3- Once the trim is off, remove the 2 visible screws that hold the door handle. NOTE: There are 2 invisible screws so you are not done yet!
4- You now need to remove the metal ring that holds the latches. To do that, grab the metal ring and using your other hand, release each plastic tab one by one (same tabs as above).
5- Once the metal ring is loose, you will see 2 screws. Remove them if they are still there.
6- Position your new handle and attach using the first 2 screws.
7- Reposition the metal ring by re-snapping it in place. Install the other 2 screws.
8- Replace the plastic trim by snapping it back in place
9- Reinstall door and grille. Tell wife or hubby that you are a genius!
Bonus: use metal washers when screwing down the 2 first screws.
Mar 10, 2008 | Microwave Ovens
Spacmaker xl sensor
Same goes for me. I can get most of the trim off but not the area near the hinge. ! It will cost $100 for GE to come out, and I already own the new handle. Come on GE tell us the secret.
Oct 28, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
74 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Greg Cann
Greg Cann
Devabhakthuni...
Devabhakthuni...
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
