Question about ASUS Eee PC 900HD Netbook
Internet connetion setup problem
I bought a mini notebook with the Specifications below:
  • CPU: VIA ARM-WM8505
  • Processor Clock Speed: 400 MHz
  • Operation System: Microsoft WinCE Professional
  • Memory: 128MB RAM
  • Storage Device: 2GB Solid State Disk
  • LCD Size: 7 inch
  • Display Digital Screen TFT-LCD, True color image 800 x 480 Resolution
  • Networking Connection: Fast 10/100 MB Ethernet (RJ-45) / LAN
  • Wireless Connection: Wi-Fi 802.11b/g available at any hot spot!!
  • Keyboard: Standard English 84 key supports external USB keyboard
  • Mouse & Touch pad: Build-in touch panel, set two shortcut key and support USB mouse
  • 3 x USB Ports
  • PCMCIA Expansion: SD Card slot
  • Audio/Video: Integrated Quadraphonic Speakers, 1x 1/8" (3.5mm) Headphone/Line-Out, 1x 1/8" (3.5mm) Microphone, Input 1x Integrated Microphone
  • Audio Formats: MP3, AAC, WMA, WAV
  • Video Formats: DIVX, MP4, XVID, DIVX, H.263.3GP
  • Games: Free cell, Solitaire
  • Battery: 1800mA Li-ion batteries
  • Dimensions: Length: 8.5" x Width: 5.75" x Depth: 1.25"
  • Power Device Type: 110-240VAC Input, 9V DC Output / 2A
  • Net weight: 0.65KG
Built-in software: Office (Excel, Wordpad, planMaker, Presentations, TextMaker, FoxitReader), Internet Explorer, MailBox, Media Player, MSN, photo Viewer, WinRAR, YouTube & Skype and many more.
I am not able to connect to the wireless router modem.The wireless signal is excellent but connection failed.I use linksy and my passphrase is correct as I am able to connet with my other new acer laptop .
Please help.
  • 30 Answers
I also faced the same problem in past. You can first of all disconnect your LAN or Wireless connection as sometime is it not recognizing the network properly. You can enable it again and restart your laptop. Try to access internet once your laptop is on as I have resolved similar problem in this manner.
Posted on May 28, 2010
How does this computer compare to a Dimension 5000 with same RAM amount and clock speed?
Paulji786,
Below are the specs you requested on these 2 systems.
Optiplex GX280
Memory
Type
400 & 533 MHz DDR2 SDRAM
400 & 533 MHzMemory connectors
small form-factor computer: 2small desktop computer: 4desktop computer: 4small mini-tower computer: 4mini-tower computer: 4
Memory capacities
128 MB, 256 MB, 512 MB, or 1 GB non-ECC
Minimum memory
dual-channel: 256 MBsingle-channel: 128 MB
Maximum memory
small form-factor computer: 2 GBsmall desktop computer: 4 GBdesktop computer: 4 GBsmall mini-tower computer: 4 GBmini-tower computer: 4 GB
BIOS address
F0000h
Dimension 5000
Type 400- and 533-MHz DDR2 unbuffered SDRAM
Memory connectors four
Memory capacities 256 MB, 512 MB, or 1 GB non-ECC
Minimum memory 256 MB
Maximum memory 4 GB
System clock 800-MHz data rate
Memory speed
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jul 15, 2015 | Dell OptiPlex GX280 PC Desktop
Tip
MAKING YOUR COMPUTER OPERATE VERY FAST & SECURED THROUGH CPU OVERCLOCKING
NOTE: OVERCLOCKING COMPUTER CPU MAKES IT PERFORM FASTER ABOVE THE FACTORY SET LEVEL, BEFORE OVERCLOCKING, READ THE GUIDE BELOW, AND VIEW THE SOFTWARE APPROACH HERE OPEN
drbrightirem.jpgOverclocking a processor means enabling it to operate above the manufacturer's specified frequency. Many internet sites provide instructions for overclocking. Processor manufacturers and many computer experts believe the slight gain in performance (only perceivable on CPU-intensive software) isn't worth the expense or considerable risk.
  • Get whatever tools you need: screwdriver, needle-nose pliers, motherboard manual, cooling hardware, etc.
  • 2 Find out whether your motherboard can be adjusted in the BIOS setup, with jumpers or not at all.
  • 3 Find out clock-speed limitations of the motherboard.
  • 4 Run all Windows and any third-party diagnostic applications you have. Fix all system problems.
  • 5 Make a complete backup of your system, documents and applications you don't have on CD-ROM. Do not overwrite these copies.
  • 6 If you have a BIOS-adjustable motherboard, make changes according to your motherboard manual, and skip to Step 15.
  • 7 Shut down computer.
  • 8 Leave computer plugged in to surge suppressor.
  • 9 Disconnect all peripherals from computer.
  • 10 Remove cover of chassis.
  • 11 Ground yourself to computer with any professional grounding equipment you have. Otherwise, ground yourself by touching a metal part of the chassis.
  • 12 If your motherboard has adjustable jumpers, locate the jumpers that control the CPU speed.
  • 13 Use needle-nose pliers to change jumper settings. Move jumpers to positions indicated in your motherboard manual for the clock speed you want. Check the internet for recommendations.
  • 14 Install a CPU heat sink, heat-sink compound, and a specialty cooling fan, if appropriate and possible.
  • 15 Put system back together, and reboot.
  • 16 If computer does not boot, and CPU still works, try lowering the clock speed. If that doesn't work, restore the original configuration.
  • 17 Check all functions, and run a CPU-intensive program.
  • NOTE: OVERCLOCKING COMPUTER CPU MAKES IT PERFORM FASTER ABOVE THE FACTORY SET LEVEL, BEFORE OVERCLOCKING, READ THE GUIDE BELOW, AND VIEW THE SOFTWARE APPROACH HERE OPEN Tips & Warnings
    • CPUs have rated and maximum speeds. Exceeding the maximum speed is far more likely to cause problems than more conservative adjustments.
    • Overclocking an Intel processor explicitly voids its warranty. Other manufacturers have similar exclusions. Intel prevents overclocking of some CPUs by disabling higher multiplier settings.
    • Expect a shorter life for an overclocked processor, including the possibility of its immediate failure.
    • Prepare to deal with seemingly unrelated problems that can be caused by overclocking: destruction of other internal components, lost data, system and application crashes, and an inability to boot the system. Such problems can occur randomly or materialize well after you have altered your motherboard
    on Dec 06, 2010 | Computers & Internet
    I bought a new 1GB ram(DD2) when i insert it it nt work bt whenever i insert it with old 512MB ram then its work bt in bios setting only show the 1GB ram
    Maybe 1GB is the maximum amount of memory that your system will hold. And maybe your system likes memory to be in pairs, so when you put the 1GB in by itself it didn't work, but when you put it in with a 512MB it works.
    May 18, 2012 | Computers & Internet
    Motherboard ID 07/28/2004-KM266-8237-6A6LYM4BC-00 **Above mentioned is the motherboard id of my motherboard. can u please tell me how much of the DDR can i use on my board? m using now one 512mb and...
    Maximum of 1 GB per slot.
    Yes, you can buy DDR400, it will be underclocked by the motherboard to DDR266. If you want some extra performance you can go in the BIOS and lower the timings one unit.
    Yes, they will work, but not very fast. They should be used only as a last option.
    Aug 03, 2010 | MSI Computers & Internet
    What is the clock speed & how to fixe it?
    erm you can't fix a clock speed, you can reset it to default in the bios if you overclocked it though.
    Jun 14, 2010 | Intel Pentium 4 2.40GHz 512/400/1.5V...
    Need specifications for Intel PM-865G1 mobo
    Specifications
    CPU
    • Supports Intel® P4 Northwood/Prescott/P4 Extreme Edition processors.(PCB v1.1 only)
    • FSB 400(Northwood only)/533/800MHz
    • Supports up 3.2GHz and higher speed
    Memory Speed/CPU FSB Support Matrix
    FSB\Memory clock DDR266 DDR333 DDR400 800 MHz YES YES* YES 533 MHz YES YES NO 400 MHz YES NO NO
    • Intel® 865G Chipset
    - Supports 800/533/400MHz Intel NetBurst micro-architecture bus.
    - Integrated graphic controller.
    - Supports PC2100/PC2700 /PC3200 memory.
    - Supports AGP 8X/4X at 0.8V (AGP 3.0) or 4X at 1.5V (not support 3.3V) interface.
    • Intel® ICH5 Chipset
    - AC'97 2.3 interface
    - 8 USB 2.0/1.1 ports
    - 2 channel Ultra ATA/100 Bus Master IDE controller
    - SMBus 2.0 support
    - 2 serial ATA Host Controllers
    - Integrated LAN controller
    • Support 100(Northwood only)/133/200MHz
    • Support 400(Northwood only)/533/800MHz Intel NetBurst micro-architecture bus.
    • Supports two 64-bit wide DDR data channels.
    • Available bandwidth up to 3.2GB/s(DDR 400) for single-channel
    mode and 6.4GB/s(DDR 400) for dual-channel mode.
    • Supports four unbuffered DIMM of 2.5 Volt DDR SDRAM.
    • Supports up to 4GB memory size without ECC.
    • One AGP slot supports 8x/4x at 0.8V (AGP 3.0) or 4x at 1.5V (3.3V is not supported).
    • Three PCI 2.2 32-bit Master PCI Bus slots.
    - Supports 3.3v/5v PCI bus Interface.
    • One CNR slot
    • Dual Ultra DMA 66/100 IDE controllers integrated in ICH5
    - Supports PIO, Bus Master operation modes.
    - Can connect up to four Ultra ATA drives.
    • Serial ATA/150 controller integrated in ICH5
    - Up to 150MB/sec transfer speeds.
    - Can connect up to two Serial ATA drives.
    • AC'97 link controller integrated in ICH5
    • 6 channels software audio codec C-Media 9739A
    - Compliance with AC97 v2.2 Spec.
    - Meet PC2001 audio performance requirement.
    - Can support SPDIF Out via 3-pin SPDIF bracket only.
    • Intel 82562EZ
    - Integrated 10/100 Ethernet MAC and PHY in one chip
    - Supports 10Mb/s and 100Mb/s auto-negotiation operation
    - Compliant with PCI v2.2, and LAN on Motherboard (LOM) standard
    Apr 27, 2010 | Intel Motherboard
    Overclocking!!
    If this a Notebook/laptop, please do not try overclocking, it may damage CPU/other components..
    Jun 25, 2008 | Toshiba Satellite A45-S250 Notebook
    Cpu clock wrong
    2500/256 celeron is 2.4 GHz. If there is a setting in bios, it should work. Most Intel motherboards do not allow you to change the clock speed as incressing clock speeds lead to system instability and less processor life. YOU WILL ALSO LOSE THE WARRANTY!!!
    Feb 16, 2008 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
    BIOS DISPLAYING INCORRECT CPU SPEED
    Hi, I have to agree "...that the motherboard's bios doesn't recognize the processor and that I should upgrade the bios...". Though I think that this is only a display issue and not necessarily true CPU speed. You can check if the correct CPU is displayed inside Windows by right click on My Computer and details would be shown in the System Properties. To upgrade the BIOS: 1. Determine/log your current BIOS and its date by pressing Pause on initial boot when motherboard details are shown; 2. Continue booting by pressing escape and run your Windows normally. Go to the website of your motherboard manufacturer and verify if they have an updated BIOS (compare date of release). If an updated BIOS is available, download. Likewise download the flashing utility. Further instructions are also available on a step by step procedure. Some newer mb versions/models have a Window based update feature. Check if you have such. Hope this be of some help/idea. Post back how things are or should you need further information. Good luck and kind regards.
    Aug 28, 2007 | Soltek SL-75FRV Motherboard
    ASUS Eee PC 900HD Netbook Logo
    309 people viewed this question
    Top ASUS Computers & Internet Experts
    David
    David
    Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
