Question about Acer Aspire One PC Notebook
Will not boot all the way
When I turn on the notebook, the screen giving the option to start normal or to safe mode comes up. No matter which mode I select the machine locks out and will not complete the booting up process.
  • Lacerz
    Lacerz Jun 01, 2010
    Hello, Ill assume you are receiving a blue screen. When your laptop starts up, please press F8 continuously until menu comes up with multiple options - Choose the one that says : "Disable automatic restart on system failure" and report to me which bluescreen you have... 0x0000000A 0x0000007A 0x00000024 0x00000051 0x0000008E 0x0000007B 0x000000C1
  • jvidot Jun 02, 2010
    The problem is that when I turn on the notebook, the screen giving the option to start
    machine locks out and will not complete the booting up process.The codes that show up after pressing F8 and disabling automatic restart are:
    0X00000073(0X00000001, 0XC000017D, 0X00000001, 0XF749BBB8)
    Scholar:
  • 92 Answers
Please restart unit and start pressing F8 continuously after the Acer Logo, and select "Disable automatic restart after power failure", then press enter. Please write down the Bluescreen code...
0x000007B
0x0000024
Posted on Jun 01, 2010
  • Lacerz
    Lacerz Jun 02, 2010
    Hello again,
    From what I've seen, it seems your hard drive is out of space and your system is trying to increase the pagefile and just can't do so as their is insufficient system resouce available to handle the request.
    What you CAN (not recommended to normal PC users) do is to remove the hard drive into another machine and take off huge data files like ISO images, video files and other larger files that take up space. Once this has been done and enough data has been removed from the drive, install the hard drive into the AOA150 again and try to boot.
    Last resort in this case would be a fresh re-installation, with format wipe.
2 Suggested Answers
  • 13 Answers
SOURCE: When I turn on the
My first thought is the Hard Drive has a problem. I would pull the Hard Drive out and start the computer a few times without it. If it boots and POSTS to where you can see the white text on a black background and consistently gets to the point to where it says there is no Hard Drive present....that would point even more to a bad or corrupted hard drive.
If you have data that is not backed up, I would not attempt any further repair without pulling the info off. If you dont know how, it may be best to go to a local repair shop.
I would hook the Hard Drive up to another computer as a Slave. You can buy laptop IDE HD to USB adapters online. If it is SATA, you can just hook it up to most Desktop computers. Copy any data you need and when you are done, run a Disk Check on the HD while it is still hooked up as a slave.
If the HD is not the problem, my next thought would be the Memory. You probably have 2 sticks of RAM installed. The easiest way to test is to just take one stick out and see if it works....then repeat with the other stick.
Posted on Jun 02, 2010
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
When I boot up my laptop, it asks me 4 options. Start windows normally, safe mode, safe mode with command prompt, and safe mode with network support. It doesn't matter which one I pick, but when the laptop...
To start your computer normally you must choose either of that options but the only thing you must choose is the start windows normally so that all the settings from the previous working settings will be applied in your windows start up.
Dec 25, 2010 | Toshiba Satellite L45-S7423 Notebook
My hp compaq nc 6000 is running in safe mode, how can i turn this off plz plz help me!!
Follow the steps mentioned below to boot in normal mode.
1: Once you are in the Safe Mode, Click on Start and then Click on Run.
2: Type msconfig (you will see system configuration utility).
3: Click on Boot.ini tab and check for the Boot Options.
4: You will see Safe boot options check.
5: Uncheck it then click on apply and then ok.
6: Now your computer will boot in Normal mode.
Once you reach the desktop you will again see the system configuration utility screen. Just check the option don
Dec 11, 2010 | HP Compaq nc6000 Notebook
How do i turn off safe mode
Most computers when you boot it up give the option of "Boot Menu" upon the first few seconds of powering the machine on. Look at the screen and see if it reads Press F1 or F2 for Boot Menu. From there you can toggle off the safe mode option. Sometimes it's the delete key or alt key for some other computer providers as well.
Hope this helps,
Marty
Nov 27, 2010 | Computers & Internet
Laptop wont even attempt to load windows??
With this kind of problem, you must put in the Windows software disk and boot. Then select repair Windows from the list. This option will attempt to correct the problem.
If you do not have the disc, boot into the repair / diagnostic mode from the boot screen. See if there is an option to create boot disks.
Jan 04, 2010 | Toshiba Satellite A70 Notebook
When trying to boot up
Hello
So in that case you need to reinstall the Windows so that it will fix the problem. Some instances of that problem corrupted Operating System it needs a new copy.
Regards
PCmania
Sep 25, 2009 | Acer Aspire One Netbook 8.9" Notebook
My hp pavilion zv5320us laptop will not boot up... Once it turns on it asks where do i want to boot from, the boot order or from LAN. If i do not enter anything it goes to a black screens and says : For...
yeah if you have your win vista cd with you boot from the cd and clixk on repair your computer, here use the restore computer and not complete system restore.
Jul 14, 2009 | Computers & Internet
Computer keeps returning to "safe mode" options screen
If you choose Start Normal and it boots into safe mode again then you should get professional help if you value any of the files on your computer and don't want to loose any data.
Jun 01, 2009 | Sony VAIO VGC-V617G PC Desktop
Dell will not come on has a grey screen and can
Attempt to boot the machine into Safe-Mode.
Continuously hitting F8 while booting will get you to the Boot Option Menu.
If you can successfully boot into Safe mode, this may be enough to put things back together.
Attempt Safe-Mode and if successful try a normal boot.
Start from there and let us know the results.
Apr 11, 2009 | Dell Inspiron 1525 Notebook
Hp laptop
windows is thnking that you have a problem with the system
start windows in safe mode and troubleshoot and see what the problem is if all else fails you might have to to a system restore
or take it into a tech and see what they think
hope this helps
cheers
Jul 20, 2008 | HP Pavilion dv1000 Notebook
Acer Aspire One  PC Notebook Logo
100 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
