Question about Jandy Aqualink Rs4 One Touch Control System Control System
Cannot get temp to raise
I set my orca bay temp at 70 for winter storage. Spring start up the heater kicks in to the 70 degrees but cannot get the temp to raise get a 968 code all other functions work from the topside control and am getting a ambient temp reading on the topside control.I did change a pump and pulled the temp sensor cable and the sensor is a little loose in the thermowell.Becuse the heater kicked in and there is a temp reading I am suspecting that the temp sensor is ok Don't know what to do am thinking of replacing the pcb board
  • 990 Answers
I would go for the sensor first. It is in the easy to afforde range and easy to install along with more sucpeteable to falure.If that dosen't help then you can still try the board.
Posted on May 28, 2010
Honeywell thermostate will not kick off on set temperture
There's a "throttling range." The unit starts (say, in heating) one degree below setpoint and shuts off two degrees above set point.
You can change the "temp" but you can't change the throttling range.
Mar 02, 2014 | Honeywell Programmable Thermostat Heater
Need to know how to turn the temp up on my gas hot water heater noritz tankless m n-o631-s od
If you are in a cold area, having it outside isn't helping you. Tank less heaters only raise the water temperature 40 - 70 degrees. If you had 50 degree water coming in and it is 35 degrees outside, you will be lucky to get 90 degree water.
Nov 25, 2012 | Dishwashers
Raise temp above 120
Raising temperature above 120 degrees requires service call.
Or change dip switch settings and risk voiding warranty and causing service call expense.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#temperature
Earliest versions of Rheem tankless 2006-8 let you set temperature up to 140 degrees F using remote.
However the hotter setting caused error codes because the burner cannot keep up with both high temperature and large volume of hot water rushing through pipe. Especially in winter with cooler incoming water that must be heated more to reach temperature set point.
The burner simply cannot keep up.
So Rheem changed maximum temperature at remote control to tepid 120 degrees, which is not hot enough for folks wanting hot shower, or folks filling whirlpool tub because water in tub cools before tub fills.
Oct 27, 2012 | Rheem Tankless Water Heater Main Remote...
Goodman GKS9. I have this unit in a condo that I only use sparingly in the winter. I keep the dual thermostats both at 57 and it maintains that tempeature. The problem is that when the thermostat is raised...
The presure switch is breaking down try taking the tubes off and blowing down the switch , or take a small drill bit and clean inside the connections to the pressure switch some times this becomes blocked .
Jan 16, 2012 | Goodman Heating & Cooling
I have a 5 ton ac with two 10 kw heat strips. The problem is that the unit runs constantly on one stage with the temp. set at 66 degrees in the winter. The second stage heat will kick on if I manually...
Between two stages, the difference temp has been set up to call for second stage.. If you need immediate heat what you did is right. But again you have to reduce to your required temp. Hence, wait the second stage get started.
Jan 13, 2011 | Heating & Cooling
My heat pump runs most all the time i will set the thermostat on 70 when it gets to 70 it still runs I can kick it back down to 69 and it kicks off.I can put it on 72 when it gets to 72 it still runs, I...
therostats have what is known as off-set deflection , or simplely put the plus or minus of the temp range which the heat turns on or off this setting is adjustable on many thermostats i usually set for 3 degrees if it is set for 1 or 2 it will run all the time refer to owners manual to see how to set this in program
Jan 06, 2010 | Honeywell Programmable Thermostat Heater
Does the T8602C1095 have an anticipator that may need adjustment when the temperature set is exceeded, eg we set at 70 and it goes to 71-72 and then need to manually shut down system.
that is how they work. ther is a 1 to 3 degree variance up or down.it probaly does not kick back until 67 or68 degrees. a two stage furnace will keep a more steady temp.
Oct 01, 2009 | Honeywell Electronic Programmable...
Have gas furnace and this winter,began having
The Thermostat Wizard is an interactive tool that will guide you through wiring and troubleshooting your thermostat, as well as programming it to the most comfortable settings for you and your family. Simply answer the questions from the Thermostat Wizard to correctly connect, troubleshoot and/or program your Honeywell Thermostat. You can even print the instructions and bring them right to the thermostat to help make things easier.
Go to: http://yourhome.honeywell.com/Consumer/Cultures/en-US/Support/Thermostat+Wizard/
However - the problem is probably not with your thermostat but with your furnace. It is most likely a dirty flame sensor - a maintenance issue. If you have not had your furnace serviced recently (more than 1 year) that is where you should start. Modern furnaces require regular maintenance.
Please rate my answer!
Feb 28, 2009 | Honeywell Electronic Programmable...
My Dayton garage heater model 2E636B does not heat up.
These heaters are the same as the marley heater, the element never gets red hot. the unit is set up so the fan kicks on after the element has heated to a certain temp and turns off after the element has cooled. It is common for these heater fans to cycle on and off quite often untill the air temp reaches about 55 degrees and then will operate normaly. If the fan still cycles too often you may have to replace the fan control and high limit switch. These are not very expensive and easy to replace yourself. they arte usualy attached to the back of the element with clips. The luke warm air is what these units put out. I have an equivelent to the dayton G73 and it heats a 24' X 30' garrage all winter in central Minnesota.
Nov 17, 2008 | Dayton G73 Utility Heater
Jandy Aqualink Rs4 One Touch Control System Control System Logo
182 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
