Question about Samsung LN32A330 32 in. LCD TV
Samsung ln32a330j1d.what can cause my tv not to turn on. the standby light is on i used my remote or my hand to put it on b ut did not get any responce
SOURCE: samsung tv LE32R74BD standby light on but wont turn on
samsung tv le32r74bd had tv on standby and wont turn on,it is stuck on standby please can you solve this
Posted on Nov 24, 2008
  • 304 Answers
SOURCE: I cannot get the tv to turn on. The red standby
You either have a bad T-Con bd or a bad Main bd. Have a trained samsung troubleshoot the set.
Posted on Jul 17, 2009
dave1645
  • 834 Answers
SOURCE: Samsung LN32A330J1D - LCD TV - only 2 years old
ya thats abiout right the board is around 125 and of course labor so your in the ball park and that set is worth it
Posted on Dec 11, 2009
Testimonial: "gave me a good idea of price guide"
  • 380 Answers
Capacitors, capacitors and capacitors. I can't stress that enough. Common issue with these samsungs. Check those capacitors before changing any board.
If there is a bad capacitor in the power supply, you will either get one of two symptons.
1 - Solid red Led and thats it. You hit the power button and nothing will respond.
2 - You just hear a click repeatedly.
Posted on Dec 15, 2009
budmrtn
  • 11361 Answers
SOURCE: My samsung lcd tv won't turn on.It is plugged into
Look at the power supply first; look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Samsung+LN32A330+
Please post back what you find
Posted on Dec 17, 2009
Sky remote code for model UE40J5100AK
Programming the remote control
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Press "TV" again then enter the code for the TV listings below (Use the 4 digit codes from the left hand column), the red light will flash twice if a valid code has been entered. Press TV then the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes below or continue with this process by continuously pressing "TV" then "Standby" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code.
If you are still unable to control your TV from the remote control see: Programming The Sky Remote or go to Sky's official website where you can see if a particular remote control version number will operate your make of TV, this can be found at:Skyplease remember to use your back button and come back to us.
www.electro-medical.blogspot.com
Samsung brand code 0060
3 digit code for Samsung
065, 584, 037, 245, 476, 398, 516, 292, 318,037
Oct 13, 2015 | Samsung Televison & Video
May someone please send the service mode specifications for a Samsung LED 40 inch TV UA40EH5000R?
I don't have service mode specifications but I do have a Samsung and looked around for how to get it in service mode some time ago because the HDMI cables somehow disconnected themselves a lot. Thought it was an electronic problem but it turned out to be a parenting problem instead SO I have never used this information and can not vouch for it. I cut and paste it from a note I copied from a forum entry to use at your discretion:
First post:
To enter "Service Mode" Press the remote - control keys in this sequence :
From Standby Info-Menu-Mute-Power On
- The buttons are active in the service mode.
Remote - Control Key : Power, Arrow Up, Arrow Down, Arrow Left, Arrow Right, Menu, Enter, Number Key(0~9)
Careful though there are things you shouldn't touch in this menu.
avforums.com/forums/lcd-led-lc­d-tvs/601553-samsung-service-m­enu-research.html
Another post:
Method 1
Put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu.
Method 2
Turn the power off. On the remote, press Mute followed by 1, 8, 2, Power in sequence.
Method 3
With the TV in standby, press the {DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
Method 4
With the TV in standby, press the {SLEEP} {P.STD} {MUTE} {POWER} on the remote.
Method 5
With the TV in standby, press the {DISPLAY} {MENU} {MUTE} {POWER} on the remote.
Method 6
With the TV in standby. On the remote, press Mute followed by 1, 1, 9, Enter in sequence.
Samsung LCD Monitor Service Menu Instructions
End quote.
Good luck. Just a basic suggestion you probably don't need: keep track of any changes made by writing them down so you can put it all back if you have to.
Dec 20, 2014 | Samsung Televison & Video
I got samsung tv ln32a330j1d it won"t turn on even
You have a bad power supply.
You can get get parts for this tv at www.interliquidparts.com
Aug 28, 2011 | Samsung LN32A330 32 in. LCD TV
My samsung lcd tv model number LN32A330J1D won't turn on. the power light comes on but nothing else happens. what do I do?
The power supply for the lcd tv can have problems that don't put proper voltage to the control board. Some can be fixed others have to be replaced. a good multimeter can be used to probe for voltage . also if the backlight is burned out you can still see a very fait picture by shinning a light on the screen.
Apr 18, 2011 | Samsung LN32A330 32 in. LCD TV
My samsung model ln32a330j1d tv will not turn on. The red standby light is on but it will not turn on.
I have the same TV and just fixed it in a couple mins. The problem is capacitor # CM861 on your power supply board. It is a 10v, 2200uF capacitor. You can tell it is bad because the top is rounded not flat like the others.
Aug 24, 2010 | Samsung LN32A330 32 in. LCD TV
My ln32a330j1d
do you got power regulator?
because looks like you power supply dosen't work.
Jan 08, 2010 | Samsung LN32A330 32 in. LCD TV
Pacific tv model will only turn on using the remote from standby, can i change so ut turns on from the power?
Looks like a faulty power button on the TV..or bad circuitry..would recommend taking it in for servicing first..
Jul 22, 2008 | Televison & Video
Child lock will not allow my tv to turn on
i was programming my television by hand because i do not have a remote to my television and i accidentally set the child lock and now my tv will not turn on what can i do to fix my tvtv is on standby, standby light is on. can turn tv on with programable remote after pressing on button several times to set code on remote. press any function button and screen says child lock is on. can't get anywhere pressing any buttons, turn tv off with on/off button and tv goes back to stand by. don't have magnavox remote any ideas?
Jul 19, 2008 | Philips Magnavox 20MS3442 20" TV
Samsung LN32A330 32 in. LCD TV Logo
175 people viewed this question
Henry  Thomas
Henry Thomas
