Question about Acer Aspire 3680 Laptop
I clicked on fn and F2 button cannot run mouse touch
    Scholar:
  • 92 Answers
Please try the FN and F7 key combination
Posted on Jun 01, 2010
Lenova G570 laptop the touch pad will not work
There is usually either a button someplace for the keypad or it is disabled via use the Fn key. Look at your F keys (i.e. F1 , F2, F3) one of them should look like a mouse icon.. press that and see if the touchpad works again.. If not you may need to press and hold the Fn key (Botton left on most laptop keyboards) while pressing the button with the mouse icon on it.
Jan 02, 2014 | Lenovo 3000 Computers & Internet
How to unlock a mouse on a laptop
On the top of your keyboard there should be F keys like F1,F2 etc.
Every F key has a little picture.When you see a touchpad picture press Fn+F5. According to my Laptop. For example if your touchpad picture is at F6 then you would press Fn+F6.The Fn key should be located near the ctrl keys. If this does not work then try the following steps:-
1 Click the Windows "Start" button in the bottom-left corner of your desktop. Scroll up and click "Control Panel."
2 Choose the "Mouse" icon or type "Mouse" in the field in the upper-right corner. Click the "Enter" button and then click the "Mouse" link.
3 Press the "Hardware" tab or the tab to the right of it that specifies the type of touch pad you have. If you are under the "Hardware" tab, highlight the touch pad in the list of devices and click the "Enable" button. If you are under the touch pad tab, click the enable button.
4 Click the "Apply" button and then click the "OK" button.
Apr 30, 2012 | Dell Computers & Internet
How can I disable the trackpad to only use an external mouse? Toshiba laptop (Satellite)
For most Toshiba laptops, you should be able to hit FN+F9, and it will disable the touch pad. If that doesn't work, go to your Control Panel, Hardware and Sound, Mouse, and disable it there. Hope this helps!
Mar 28, 2011 | Toshiba Satellite 2400-S251 Notebook
How do I turn off the touch pad on my Acer Aspire 5742 laptop
Thank you for using fixya. My name is Carlo.
There are two ways that you can do to turn off/on the touch pad in your acer aspire.
1. Press FN + F7. It will turn off the touchpad and will turn on once you press the same buttons again.
2. If the buttons do not work. You can do this:
1. Go to control panel>hardware and devices>Devices and Printers>Mouse
2. CLick on the last setting on the right.
3. Click on Disable in the Mouse Properties.
5. Click OK.
Just go to the same area when you want to enable your touchpad again.
I hope this helps.
Carlo
var geo_Partner = '82910b1e-9b92-42fd-b83f-fa09a0787ae7'; var geo_isCG = true;
Mar 01, 2011 | Acer Aspire 5742 Notebook
The touchpad stopped working after a powerpoint presentation i made. A friend helped me set up the laptop to the projector and he did press keys. Did he accidentally press some inactivating key in the...
FN + F9 should enable / disable the touchpad goto control panel - mouse - and see if you can change disable/enable touch pad from there Otherwise post back what windows version you have
Touchpads
you can enable and disable the touchpads Touchpad: - to enable or disable a touch pad/pointing device from the Start Menu > control panel > Change to classic view - {on left hand menu} click on the mouse icon Mouse Properties dialog box, click "Device Settings tab" select the device click to Enable or Disable OR You may need to enable in the bios/setup menu - as the PC boots - you should get a message on how to get into the bios/setup - usually using F2 or DEL Key or F10 see if touch pad needs to be enabled there OR one of the F keys may disable/enable - depends on the model of the Laptop - toshiba sometime use FN+F9 key
Apr 10, 2010 | Toshiba Satellite M55-S325 Notebook
Satellite P505 Model S8980 - unable to get TouchPad to work now where it did work before. The TouchPad ON/OFF button nor the Fn+F9 approach are no help. A USB-connected mouse worked fine, tho. Just no...
----- control panel - mouse - see if touch pad disabled there ----- have a look in the bios/setup and see if the touch pad is disabled there, as the PC boots - you should see which key to use to enter the bios/setup F2, F10, DEL KEY are often used ----- On some machines a combination of FN and F key can disable/enable the touch pad - F7 or F9 ----- If you point the mouse to the top of the screen you may get a menu dropdown, which will also tell which key to use to disable/enable the touchpad ----- control panel>system>{vista}lefthand side device manger or {XP}hardware>Device Manager>Mouse and other pointing devices>Touchpad>highlight touchpad and right click, Properties, may be an option here to Disable/enable,
Feb 18, 2010 | Toshiba Satellite P505-S8950 Notebook
Hello im tryin to connect wirless when i click on the thing its sayin my wireless cacability is not turned on i have no buttons on my computer and ive tryed fn+f2 can u solve this problem
Click Start
Click Control Panel
Click Network Connections
Click with the SECOND (usually the RIGHT) mouse-button on the "wireless" adapter.
Click to "enable" the adapter.
Nov 06, 2009 | Computers & Internet
How to turn off mouse on laptop when using wireless mouse
Now depending on the model of your laptop, the procedure may defer. I will just show you the various basic ways available with most laptops.
1. Look around your touch pad (especially the area between it and the keypad). Some laptops have a button here that turns the touch pad (laptop mouse) on and off. If you see one just press it.
2. If you do not see this button. Then check your fn keys (They are usually labeled in a different colour, e.g. blue). Usually they are on the normal function keys. Look for the one that resemble a mouse figure. If you see it, you need to press it in combination with the Fn key; press the Fn key first. (The Fn key is usually near the Ctrl key). This will turn on and off your touch pad (laptop mouse).
Sep 13, 2009 | Gateway Computers & Internet
Cannot right click Try to copy and right click paste and the wireless laser mouse will not right click
If it is a Laptop try Fn keys comination like Fn+F8 otherwise if it is connected to desktop computer then need to check mouse properties from control panel
Hope it works ;-)
Sep 08, 2009 | Logitech Cordless Mouse
Acer Vista Laptop and cursor nightmare!!
Hi -
I've been having the same problem and it is MAJORLY annoying to be typing along, and have the cursor reappear on another line!
I had a heck of a time finding the place to disable the touchpad, since we use a USB mouse with the laptop. Turns out, someone else helped me find a simple way - hold down the Fn key (next to the left side CNTRL key), and hit F7. That toggles the touchpad off/on easily!
Also suggested by someone else, some mice can cause erratice behavior with Acer laptops, so perhaps try another mouse?
So far, I've been typing this response AFTER disabling the touchpad, and the cursor has not jumped around at all.
Good luck! : )
Dec 10, 2007 | Microsoft Windows Vista Ultimate Edition
Acer Aspire 3680 Laptop Logo
23 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
