Question about D-Link DGL-4500 Wireless Router
Router not connecting to internet not recognized by Windows 7
Trying to set up router on new computer. Set up program stiops at step 2 with message noting compatibility issue with windows 7.
  • 532 Answers
Do a manual setup. Look at the instruction booklet and access the router from a browser.
Posted on Jul 02, 2010
Hello, I am trying to install my d-link 125 usb adapter. I had to download the windows 7 driver from the d-link website, and now I am trying to install it to my computer. When I try to run the driver...
Use the following steps to let Windows do the installation for you.
Step 1: Use an Ethernet cable and plug your computer directly to your Internet gateway. Make sure Internet is accessible.
Step 2: Place your new adapter in the proper slot or port.
Step 3: With your computer running, a bubble message will appear stating that this device was not installed successfully. Left click on the message.
But if the message no longer appears, skip to Device Manager Installation.
Step 4: On driver installation failure, you can change the setting to use Windows Update by clicking Change setting...
Step 5: Chose to allow Windows to update your driver when it is not found on you computer.
Step 6: Once the driver installs successfully, close the window.
Step 7: Click/Right Click on the Network Icon located on the system tray to View the Available Wireless Networks. Find your personal Network and double click to connect. It should request for a wireless key, which by now should have been set up.
Oct 26, 2011 | D-Link DWA-125 Wireless 150 USB Adapter...
Tip
How to resolve "Limited Or No Connectivity Errors" in Windows
When attempting to set up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Limited or no connectivity: The connection has limited or no connectivity. You might be unable to access the Internet or some network resources.
This message can result from any of several different technical glitches or configuration problems. Follow these steps to resolve Limited Or No Connectivity errors in Windows.
1. Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. See Microsoft Knowledge Base article 892896 for details on how to work around this error appropriately.
2. If your network access is non-functional. continue to the following steps.
3. If your computer connects to the network through a broadband router , resetting (powering off and on) the router may resolve the issue. If not using a broadband router, or if resetting your router only temporarily resolves the issue and the error message re-appears later, continue to the following steps.
If connecting to your network using Wi-Fi and using wireless security, your WEP or other security key may not be set properly. Check the wireless security configuration on your computer's network adapter and update if it necessary.
4. If connecting to your network using an Ethernet cable, your cable may have failed. Temporarily replace your network cable with a new one to determine whether this resolves the issue.
5. If using a broadband router and DHCP on your network, check your computer's IP address to verify it is valid and not a private address that starts with 169.254. An invalid address of the form 169.254.x.x signifies your computer's inability to obtain a usable IP address from your router.
To resolve DHCP configuration problems, proceed to the following steps.
6. Reboot your computer, router (if present) and broadband modem together, then re-test your connection.
7. If your connection remains non-functional, run the Windows Network Repair utility on your computer.
8. If your connection remains non-functional, update your router settings to change from dynamic to static IP address configuration, and set an IP address on the computer appropriately.
9. If your connection remains non-functional, unplug your router and connect the computer directly to your broadband modem. If this configuration is functional, contact the manufacturer of your router for additional support.
10. If your computer is connecting to your network directly through a broadband modem, or if your Internet access remains non-functional after following the instructions above, contact your Internet provider for support.
on Jul 20, 2010 | Computers & Internet
I have a zhone 6211-I3-200-ADSL2+CPE w/phone filter. I am trying to connect 2 computers (1 laptop, 1 desk top) to a linksys WRT 150n wireless router and cannot get the wireless connection to work. It shows...
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Aug 03, 2010 | Zhone 6211-I3-200 Router
Laptop running 0n win 7 wont connect to router
1. you will have to designate the laptop or allow it to connect by entering it into the 3com router.
2. try connecting to the router via ethernet cord (that is connecting with a physical straight through cord) that came with the router.
If connected with this then you will have to go into the router via the IP set 192.168..0.1 depending on the router ip for loging in.
2. Go to the "wireless setup" and enter your MAC address for the laptop in the permissions list in the router. Instructions on how to do this is at the manufacturers site. Step by step.
3. Do the following step if instructions not found.
1.Log into router
4.. Check the laptop do ipconfig /all to see current IP adresses.
Jun 19, 2010 | 3Com OfficeConnect Router
My WRT54G2 V1 is having connecting to my internet
Are you trying to install the router.
You can do it manually without the CD.
MAke sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 16, 2010 | Linksys Wireless-G Broadband Router
Compatible with windows 7?
through the modem.
modem
Jan 11, 2010 | NetGear WGR614 Wireless Router
No internet connection...
Check your cable-connections:
AC power to the router.
Cable-modem <----> WAN-port on the router.
or
DSL-modem <----> WAN-port on the router.
LAN-port on the router <----> Ethernet port on your computer.
Windows 7 should show that you have obtained an IP-address,
starting with '192.168.' that was supplied by the router.
Note that some ISPs (Internet Service Providers) will require
that you tell them the MAC (Media Acccess Control) address
of the _ROUTER_ before the router will be able to connect,
through the ISP's services, to the Internet. Contact your ISP.
Jan 09, 2010 | Linksys Wireless-G WRT54G Router
Connect a router
Are you trying to set up the router ?
Or you are trying to connect to the wireless network.
It is very easy to set up the router.
I hope the following link will help you
Click Here for step by step solutions
Nov 06, 2009 | Linksys Wireless-G Broadband Router
How To Configure FM114P or FR114P for an Internet Connection and Printer Sharing
There are three steps: 1. Configuring the router for Internet access 2. Installing and configuring the print server 3. Adding the printer to the Windows configuration To Configure the Router for Internet Access 1. Connect the modem to the router's Internet port and your LAN computers to the router's LAN ports. 2. Shut down your LAN computers. (Power them off.) 3. Power off the router. 4. Power off the modem. 5. Power on the modem. 6. Power on the router. 7. Start the LAN computers. 8. Enter 192.168.0.1 in a Web browser's address. 9. Type username and password (by default admin and password). 10. Click Setup Wizard to configure the router's Internet access. To Install and Configure the Print Server 1. Install the Printer Server Driver program on a computer. 2. After installation, make sure to select the Run Print Port Setup now box. 3. Click Finish. Print Port Setup runs, showing you the firewall and the printer. 4. Click Port 1. 5. Click Add. A pop-up message says whether a port was created, then the Add Printer wizard starts. To Add a Printer With the Windows Add Printer Wizard 1. Continuing from the last section (or clicking Start > Settings > Printers > Add Printer), click Next. 2. Select Network Printer, and click Next. 3. Click Next again (leaving the port as LPT1). 4. Select the manufacturer and printer model of your printer. (If your printer does not appear, you need to get the CD or floppy that came with the printer, and use Have Disk to specify the file location. Note that it is looking for a file that ends with .inf.) 5. Click Next. 6. Change the printer name to something users on your LAN will recognize easily. 7. If prompted by the Add Printer Wizard about sharing: DO NOT enable sharing! Now test the printer. Other information about Windows configuration is available in Windows help in the article "To connect to a printer on a network".
Feb 19, 2006 | NetGear FR114P Router
Feb 19, 2006 | NetGear FM114P Cable/DSL ProSafe 802.11b...
D-Link DGL-4500 Wireless Router Logo
110 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
