Question about ASUS Eee 4G Notebook
Hi, every time I power up, my eeepc jitters and runs down the page until I hit the top 2nd left key in next to F1...then it is fine...also when I try to play a flash game it will load but will not let me play because it does not recognize my click from the pad or a wirelees mouse...can you help me??
    Guru:
  • 689 Answers
You must restore OS /image then clean install
Posted on Sep 04, 2010
Won't find wireless connection
Did you turn the wireless switch on? Normally there is a switch either on the sides or the front of the laptop that you have to turn on. Sometimes it is a button at the top of the keyboard.
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
May 21, 2012 | Packard Bell Easy One Silver 2101 Notebook
How do I the ALPHA f1 function menu to appear so I can enter fractions
Hi...
You can access F1 by
  1. Press and Release "ALPHA" Key
  2. Now press desire function key. Here in this case, Press "Y="
Many keys in this calculator serves one than one function which can be access through by pressing either "2nd"(Blue Key) or "ALPHA"(GREEN KEY). Such extra functions are noted on keys in Green or Blue color. These additional functions are accessed by first pressing corresponding color key and desired function Key.
For example:
pressing UP and DOWN keys navigates the screen up and down
if we press ALPHA key and then UP/DOWN key, it will scroll screen UP/DOWN by a page. Also you can use this combination for copy functions.
if we press 2nd Key instead of ALPHA, we can change Contrast of The screen
Mar 18, 2011 | Texas Instruments TI-84 Plus Calculator
Hi I need to scan something to my computer and it says i need the software. i dont have it. can i download it?
Hi There,
You sure can. Go to the page below, choose your operating system, click the blue "Next" button and you'll be at your software page. Once there, download the Full Version to your desktop by saving it there. Next, go to the Control Panel>Programs and uninstall the printer (it will be there in the programs list from when you plugged it in). Unplug the printer. Restart your computer if prompted to do so.
Now, hold down the Windows Logo key on the keyboard at the bottom left and press the R key. A Run window will appear. In that window type %temp% and hit Enter. Now you'll be looking at your temp files. Left click your cursor once in the window and then hold down the CTRL key and press A. All the files will be highlighted. Hit the delete key and remove all the files that windows allows. Close the window.
Finally, double click on the software install file and install your printer and DO NOT connect it until prompted. You'll be good to go.
Regards,
Marcus
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=1153481&
Sep 14, 2010 | HP Photosmart C5180 All-In-One InkJet...
A few days ago when I was on the the laptop anytime I pressed the letters mjkluio , numbers would appear instead. I tried to press the num lock button and it made no difference. Nothing would fix it so I...
The Function keys up top will not do anything when not in a program that has them set.
The num lock key on most laptops does not itself work: it must be pressed in conjunction with another key. This is normally the "FN" key at the lower left.
Please try pressing the "FN" key while you press the "num lock" key and see if this now works.
-halfs
Aug 12, 2010 | HP Computers & Internet
Turn off ''you've got mail'' thank you
control pane > sounds > sounds tab > program event > scroll down until you find the sound named "You've Got Mail" > Highlight it and then click on the drop down list of sounds under that in the window marked Sounds: > at the very top of that drop down list is the word "none" > click that and hit apply, then ok.
Sep 20, 2009 | HP Pavilion dv9000z Notebook
I was given a IBM netvista and I have to setup the hard drive what keys do I hit to get into setup
Make sure the computer is off, hold down F1 and start the computer, that should get you into the BIOS setup.
If not hit the F1 key when you see the IBM logo, you may have to repeat this until you get in to setup as you have to be fast with an IBM machine.
Regards.
Aug 17, 2009 | IBM (24P6829) for NetVista M41 160-Watt...
No dial tone with 3730
No dial tone means the terminal is not getting a signal from the phone line.
Troubleshooting:
1) Make sure it is not on a splitter most of time the splitter goes bad.
2) Make sure the phone cord used is a 2 pin cord.
3) Make sure if you have DSL from your phone company plug it in a DSL filter but make sure
you drop the baud rate the terminal uses.
Hit the more key (2nd purple key from left usually the tip key) until you see other setup.
Enter Password Default 1 Alpha Alpha 66831 Alpha key is the little black button above
the number 2.
Then hit the more key again until you see COMMS choose that and hit next until you see
Baud rate. Hit Edit and then NEXT until you get 300 baud when that shows under new hit
select or enter. Choose F4 exit save changes and then the red X key until you are back at
main sales screen Run a test sale.
If still same problem Repeat steps and change baud rate until one works. Usually 300 will
work for DSL lines.
Call me if you need assistance.
www.greenlightpayments.com EXT 105
Jul 02, 2009 | VeriFone Omni 3700
Dell dimensions 3100
sounds like your floppy drive is failing, you could get it replaced or simply turn it off via the BIOS.
to turn it off simply hit the F2 key. On the first screen usually it will list your Hard Drives, CD ROMs', and the Floppy. scroll down to the floppy and hit enter ot the corresponding key form the bios's legend at the bottom or right hand side of the screen untill you see disable.
Next you can navigate to Save & exit or hit F10 to do the same. G/L.
Apr 16, 2009 | Dell Dimension 3100 PC Desktop
Entering BIOS settings, Easy-Access, after POP, with external KB
The Power On Password problem is near impossible to crack. It is designed to prevent unauthorized access to the Thinkpad and removing the BIOS battery will not remove the password because the password is stored on an EEPROM chip.
There are no backdoor passwords available, the only option is to ask the person who set the password.
OR
There is a way to hack into the Thinkpad to see and remove the password but it requires electronic skills, a program and a working computer.
For details on how to do this go to :-
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
Feb 03, 2009 | IBM ThinkPad 600X Notebook
HOW TO SAVE NOTES ON A CALCULATOR?
There is no note program. You can hit [2nd] {STRNG} [F1] (type text with A-LOCK) [F1] [STO->] (type name with A-LOCK) [ENTER]
To view:
[2nd] {RCL} (type name with A-LOCK)
or
[2nd] {CATALOG] [ALPHA] <P> (hit down 5 times) [ENTER] (type name) [ENTER]
Turn off caps lock next time.
Oct 29, 2008 | Texas Instruments TI-85 Calculator
ASUS Eee 4G Notebook Logo
27 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
