Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Food freezing in fridge
This is happening in every area of fridge, shelves, door and crisper
    Novelist:
  • 77 Answers
Since the refrigerator is obviously cooling, what we have here is simply to much cooling. I will need a model number of the frig to be sure, but this is probably a thermostat or timer not working properly. I just keeps the refrigerator running when it should be kicking off.
If you want to repair it I'd be glad to help. If you wanted to know if it's worth fixing I would say yes! With a model I can tell you what the parts should roughly cost to you.
Posted on May 29, 2010
My Samsung RL39WBMS fridge on m fridge freezer keeps freezing food. Why is this happening all the time and how can I prevent it?
maybe the fridge is set on a colder setting and if that's not it then stick it on the lower shelves and that might help from not freezing because are fridge is the same way when it is stuck by the coolant fan
Nov 02, 2014 | Refrigerators
My Whirlpool refrigerator (Model ET21GKXHT01) has water on the shelves, in and under the crispers. I can't see where it's coming from. I don't see any plugged hoses. Help!
condensation with collect on any shinny surface,have you put uncovered food in the fridge or left the door open,refilled the fridge with food from the mall,especially veg,or is it very humid at this time.also check door seals for fit all round as an air leak will not help.
Jul 20, 2010 | Whirlpool GD2SHGX Refrigerator
Fridge is freezing food
Make sure nothing fell below your crisper, deli drawer section. There are some air return vents below them and if they get partially obstructed would allow cold air to pool in the bottom of the fridge.
Make sure your freezer control did not get turned up too high.
Also you may want to check with the manufacturer as they did have some issues with some of the bottom mount models exhibiting this problem and they developed a repair kit for them.
Jun 11, 2010 | Amana ABB1927DE Bottom Freezer...
FOOD ON MIDDEL SHELVES IS STARTING TO FREEZ
you need to send model number next time,cold air from the freezer is blown into the fridge section in this area,on some models there's a damper that controls this,the damper door doesn't close all the way when the temp.is cold enough still letting the cold air in and then food starts freezing.you'll see a tag with a model number on the left or right side up near the ceiling in the fridge section that will have the model number,you need this to order parts and to look up your machine
Apr 21, 2010 | Refrigerators
What is causing water to build up inside the refrigerator section? there is water in the crispers and on the shelves.
A condensation problem inside a fridge, normally means either, you are puting uncoverd food /or food that has a high water content (i.e.salads) into the fridge, which may be warmer than the inside temperature of the fridge, hence condensation(leaving the door open too long has the same effect)only remedy is paper towels in bottom of crisper so that salads dont go soggy.and wipe out fridge as often as needed.
Mar 10, 2010 | Whirlpool ES5FHAXS Side by Side...
Both freezer and fridge Not cold on top
sounds like the circulation fans are jammed/seized or faulty -try a full defrost and see what happens after that.
Apr 04, 2009 | Refrigerators
The refrigerator section is freezing. the temp adjust is at 1
This could be the actuator is not closing the door that controls how much cold air from the freezer is ciculated into the fresh food section. It could be something broken or there could be ice biuldup on the door itself, not allowing the door to open or close.
Nov 12, 2008 | Refrigerators
Fridge filling with water
There usually is a drain at the back of the fridge it's possible that this is clogged, This drain leads to an evaporation tray usually in the base of the fridge.
Oct 09, 2007 | Kenmore 94499 Refrigerator
Freezing food in Frig especially lower compartments
Is you refrig. cycling off and on?... sounds like a themostate if its NOT.. you might see if you have vents that have adjustments.. pull out the crispers and check for adjustable vents ... if there close them down some.
Aug 30, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
60 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
