Question about Maytag MDG2300BWW Electric Dryer
How do you replace ignitor on maytag mdg2300 dryer
    President:
  • 1,554 Answers
The igniter can be accessed for replacement through the front of the dryer by removing the front panel. Once the front panel is removed, unplug the igniter from the gas valve assembly then remove the screws securing it to the burner assembly. Secure the new igniter in place then plug it to the gas valve assembly. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock. Take extra care in handling the igniter to avoid breaking it into pieces due to its fragility.
The front panel can be removed by removing the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer. Follow these steps in reverse order when reinstalling the front panel.
Posted on May 28, 2010
Matag dryer not heating
Here is a link to maytag dryer repairs http://apcoappliancerepair.wordpress.com/?s=maytag+dryer . The most common problem is the thermal fuse. My question is. Does the heating element start to light. If not...... and you have changed the ignitor and thermal fuse. Then check the flame sensor to see if there is continuity threw it. Power to the gas coils and ignitor runs threw the flame sensor. CLICK HERE to see a flame sensor on a GE dryer. They are the same on most units but Maytag will be on the opposite side of burner chamber.
Apr 30, 2013 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Broken wire from the igniter on a maytag dg312 gas dryer
Hello Randy,
If the wire it broken on the actual ignitor with the ceramic base and the gray filiment,you could just replace that ignitor and keep that glorious 20 year old plus dryer going for years to come.The ignitor could be purchased at your local applince parts store for under $30 the part number is 279311 it also could be ordered online at;
assuredparts.com
apdepot.com
appliancepartspros.com
repairclinic.com
Gene
Aug 09, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag dryer mug15pdaww won't light, the ignitor
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 16, 2011 | Maytag Dryers
Maytag MCG8000AWW gas dryer no heat
The ignitor may be bad you can chek to see if there is 110volts when the dryer is allin by unplugging the wire to the ignitor and putting using a multimeter to chek for voltage at the wires. If there is power to the ignitor and the ignitor is not glowing up then the ignitor is probably bad replace the ignitor.
Jan 12, 2010 | Maytag Neptune MCG8000AW Gas Dryer
Maytag gas dryer, ignitor comes on, gas valve opens, ignites gas, runs for 30 sec the shuts down. Replaced hi temp fuse & thermostat. What next?
Try the ignitor... As crazy as it may seem the ignitor can be bad even if it works....
This will get your dryer back to normal again.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Nov 25, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer pilot light
You might have a hot surface ignitor that if broken can fall off and be somewhat difficult to locate by sight having never replaced one before.
Look at the new parts base as thats all you may have showing.
The ignitor regarless of type is very close to the gas manifold temination
going into the combustion compartment.
Replacing the new ignitor BE CAREFUL not to touch or bump the ignitors surface or it may fry out before you leave! they break easily!
I would use magnetic nutdrivers, its either 1/4 or 5/16 inch on most everything, very handy for furnace and AC work too
Aug 25, 2009 | Maytag Dryers
Maytag dryer got wet motor still runs but gas won't fire
if the dryer is gas you must relight the pilot light or (if it has one)the ignitor is no good if it got wet also you could dry off the igintor or replace it.ignitor or pilot light will be under a small door on the back of the dryer about where the gas line goes into the dryer.jaykra
Aug 16, 2009 | Maytag Neptune MDG5500AW Gas Dryer
My Maytag model # mdg6000bww doesn't heat up?
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
Jul 18, 2009 | Maytag MDG2600BWW Gas Dryer
Maytag gas dryer, no heat, ignitor wont glow
The machine will check all safety features first. check the overlimit by the burner. It may have a reset. If not, turn power off and check continuity (ohms). Good luck.
Apr 17, 2009 | Dryers
My Maytag Atlantis MDG6400AWW will not heat up. The drum spins but the clothes don't dry!
my dryer timer is not turning off and it does not get hot,I check glow coil.its working but it does not fire up.I smell gas some time
Apr 16, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag MDG2300BWW Electric Dryer Logo
277 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
