Question about Toro Lawn Mower With Toro Power Tools
Model 74 218 FI will start and rin for ashort time but dies,it will restart and run for a while but will die again
  • rstubbs4 May 28, 2010
    the mowerruns fine when it runs but appears to have afuel problem
  • 6,826 Answers
I would dump the old gas out of the tank,and wash it out with fresh gas,and fill the tank with stabil,for lawn mowers,and fresh gas,see if this helps,if not remove the carb,and dissasemble and clean,
Posted on May 28, 2010
    Brigadier General:
  • 3,917 Answers
Hi
The major reason of the unit to die soon after start is because of the key which is broken instead of the crankshaft. The flywheel will need to be removed and a new key installed. Make sure to clean the shaft and flywheel mating surfaces so they fit tightly or the new key won't last too long.
Let us know if you want to know something else accept the suggestion.
Thanks for contacting fixya.com
Just turns off on it's own, Wait 60 sec. restart press pedel it dies.
This engine is electronically controlled so the first thing that must be done here is to have the systems control computer tested for fault codes and then do the proper diagnostics based on those codes.
Jun 07, 2012 | 1995 Plymouth Voyager
My gen starts and runs for 1 min or so then dies restarts then dies again and again. if i start it under load ( turn on air con) it will run for 10 min then die allen
Is there a fault?? All UL listed generators including Kohler are required to lockout on a fault on shut down. This really sounds like a problem with your 2-wire auto start connection between your automatic transfer switch and genset. RDT model automatic transfer switch it is the 2 middle wires on the green connector and terminals 3&4 in the generator. close to run and open to shut down. Any open at any time will cause the unit to shut down. The 12 will shut down instantly upon an open because your 5 minute cool down is built into the transfer switch.
Jun 27, 2011 | Kohler 12 kW Emergency Power System -...
Started stalling after last usage. then it would not start at all the next time. cleaned the carb replaced fuel line and checked fuel filter which is inside the fuel tank. it started ran about 2 or 3...
When cleaning the carburetor make sure the small screen is free of debris. (Should be able to see daylight through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked and will keep the mower from running. Reassemble and start. Good luck!!
If you need further assistance, just let me know.
Jim
Jun 21, 2009 | Poulan Garden
SAbre ridingb mower. Runs, backfires,almot die, still run. Backfire again,then dies and can not restart. PLEASE HELLP!!!!! PHIL Mpwer M#1438 Engime B&S M#287707 14.5hp, OHV
Sabre riding mower. Runs, back fires, almost dies,still runs. Back fires again, then dies and can not restart Please HELP!!!!!! Mower model #1438 14.5/38. Engine Briggs and Stratton, Model #287707, 14.5hp, OHV.
Jun 06, 2009 | 2003 Ford E150
86 honda prelude si 2.0 dies, won't restart
hey sounds to me like it's the alternator see when the alternator is not working properly the main source of direct energy comes from the battery and when that runs out it makes your car die . then it might turn on again but it does not last. u shuld have you alternator checked to make sure if not ask me again..
Dec 27, 2008 | 1986 Honda Prelude
1991 Mazda MX-6 starts and it dies within 30 seconds or less.
Check to see fi your fuel pump is functioning, also change the fuel filter. I had this same problem on a 1984 626. While i waited for the car to restart fuel would seep into the line to allow for the enging to startbe that was it.
Dec 25, 2008 | 1989 Mazda MX-6
Toro Lawn Mower With Toro Power Tools Logo
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
