Question about Garmin Rino 120 2-Way Radio
Overheat/battery drain I was using my 120 at night and used the LED light a few times and it suddenly got really, really hot even though I turned it off. Now it will still turn on and works correctly but it will heat up almost immediately and drain a set of three new batteries in less than an hour.
  • 1 more comment
  • timklass Jul 14, 2008
    I have four 120's and have the exact same problem with only one of them. Put new batteries in and within one hour (even less) the unit is uncomfortably hot to the touch and the batteries are dead. This is not from use, rather the unit was sitting on my desk out of the sun.
  • walking long Oct 07, 2008
    my 120 runs through batteries when on or off, the only way to stop the drain is to remove the batteries
  • Anonymous Nov 12, 2008
    I have the exact same problem, the Rhino GPS overheats almost too hot to hold like it has a short in it.
    Sergeant:
  • 250 Answers
Hello dogwillhunt,
It is normal for a two-way radio to generate some heat, especially during extended periods of long talk time. Consumer two-way radios tend to be much more susceptible to this because they tend to be constructed out of materials that do not dissipate heat very efficiently, such as polycarbonate and plastic. Periods of heavy transmit times also use additional power, causing the radio’s batteries to run down more quickly and require replacement or recharge. Use of the display backlight feature can generate additional heat and run the unit out of battery power even more quickly.
If the radio is heating up excessively and burning through batteries (pardon the pun) in situations where you are not using the LCD backlight excessively or transmitting for long periods of time, this may be indicative of a problem with the unit that would require service, such as a short or defective component. If such is the case, I would recommend contacting the manufacturer.
Agent Ken
Go Ahead. Use Us
Posted on Apr 09, 2008
SOURCE:
Laptop randomly overheats/shuts down.
avoid geeks, try real shops , they are NOT.
it is overheating
and all PCs every made do that, if not serviced
ever heard of service? like a car, like oil filters and air cleaner.
same here but no filters
we clean the vents, and all air paths clean.
never use it on a a blanket blocking vents the go to geeks and it works. ok.
load program that reports, CPU/GPU heat.
see it overheat sure, over 50c is too hot.
and needs service or off that blanket.
i cant watch you use your LT, so.... only you know what you do.
use a desk, or better buy a bottom plate with fans added.
I have a fan plate platform that i use on my hotter running I7 LT's
if the CPU overheats the CPU will shut itself down , by its self
Intel or AMD magic, does that.
the BIOS will see it overheat and crank up fan speeds.
if the venting system is blocked, there is no HOPE NOW.
all PCs must breath, or they overheat, all do.
May 08, 2017 | HEWLETT-PACKARD Pavilion DV74065dx...
I bought my g1 about 1 month ago and now its just slow, draining battery fast, and getting really hot. anyways one night i left my G1 on my desk next to a cold ice bottle of water and the next morning my...
the mobile requires a service with solution dipped in liquid, as few resisitors and capcitors might have been still corrosive, i think you please leave the phone without battery in room temp of 26-30 deg ... for a day or two...
Jun 16, 2011 | HTC G1
Car has not been driven for about a week, we had below freezing nights for a few nights. light, radio, electrical seem to work ok. motor makes an effort to turn over, shakes a little and makes a squeal...
drain and flush the cooling system and make sure that you use a 50/50 mixture of coolant and water when you fill it back up.
Common issue.... Most people are under the impression that if you use straight coolant in a vehicle, it will never overheat or freeze. WRONG...WRONG...WRONG,
Coolant needs water to activate or it will freeze just like water will.
Jan 06, 2011 | 2002 Chrysler PT Cruiser
My laptop was starting to run really high and hot and would shut down after just a few minutes. Last night when I tried to restart it, the lights all came on, but not the screen. It doesn't even sound...
Try to drain the static energy of the motherboard first by follwing this steps.
Take out the battery
Unplugged the power adapter
Press and hold the power button for 30 secs
Put the battery back in
Plugged in the power adapter
Turn ON the computer
If still NO display. You need to call HP tech support department for this could be a mainbaord issue. Since you mention that system is running hot. Computer fan might stop working that damages the mainboard.
Jun 13, 2010 | HP Pavilion DV6500T Notebook
Turns on, led works, just suddenly stopped applying its awesome phase 90 effect though.
If you are using battery power, just because the LED lights doesn't mean the battery is adequate. Check the battery voltage.
If you are on adapter power, make sure any bypass switch is in right state. Also occassionally someone gets the in's and out's cables backward... that can do it!
Nov 09, 2009 | MXR Custom Shop Phase 90 Led
LED Flashlight Battery Drain Problem
This particular flashlight uses a microchip that consumes the power of the batteries, whether in use or not. Loosen the case to where the batteries go in, so there is no contact with polarity. Or just take the batteries out completely and replace them for actual use.
GGBMDB
Apr 05, 2009 | Stinger Streamlight 75000
Water to dishwasher not hot enough
The 737 model could run on even lower temperature (80F). Given time, the unit will heat up the water. the trick is to give it time.
That model is made for commercial use, not really for residential. It will not fully drain every cycles. The important thing to keep in mind is to empty the dishwasher (turn it off, pull the stand-pipe out, and drain) every night and left empty. When you want to use the unit, put the plug back in and turn it on, wait 20 to 30 minutes and it should be ready.
Robert Marsolais
Jul 28, 2008 | Jet Tech Systems 24 in. 737 Free-standing...
Canon S2 IS won't turn on with rechargeable batteries??
I would let them charge til you get an indication that they are done. TV remotes require very little power to operate, while digital cameras need a lot, so that's why the batteries would work in the remotes though not fully charged.
Jun 16, 2007 | Canon PowerShot S2 IS Digital Camera
Will not turn on
Howdy! Same thing happens to me after only a while of having it. iRiver were of very little help but I found my solstice in selling it to some other unfortunate person. I found if you charge it for a hour and then take out the charger, remove the battery and replace it, it will go. What a pain! Perhaps the battery drains out when it sits unused for a few days.
Sep 17, 2006 | iRiver PMC-120 Digital Media Player
Garmin Rino 120 2-Way Radio Logo
294 people viewed this question
Top Garmin Radio Communications Experts
Ken Williams
Ken Williams
eradiostore
eradiostore
 mason
mason
Are you a Garmin Radio Communication Expert? Answer questions, earn points and help others
