Question about Eton E10 AM/FM Radio
I just put new batteries in my E10 and it won't turn on. The display is working, I tried reset. It has been without any batteries for a while.
I recently won an E10 in an auction. I did not receive any paper work or anything with it, so I don't know a whole lot about this little camera. But what I do know is that when I turn it on, it go
There are other complaints all over the internet about this cameras' battery life. Are you using NiMH batteries or alkaline? If you used 8 you must be using alkaline. If they are heavy duty regular batteries you are using the wrong kind of battery. NiMh hold more power and last longer with a flatter power curve up till they are about done. Recahrging means not buying lots of batteries too. They should last for a long, long time; like a week or two at least. The manual and quick guide can be downloaded in PDF from http://www.ricoh-imaging.co.uk/en/Photo-Downloads.html
Jul 22, 2012 | Pentax Optio E10 Digital Camera
I have put new batteries in my FinePix A360 camera but it doesn't seem to power on.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Nov 10, 2011 | Fuji FinePix A360 Digital Camera
How do I reset the computer after changing the battery in my 2004 mini cooper S? The car started three times. Now it won't start even though all of the other electrics work
Turn off ignition. Press and hold the trip reset button, then turn the ignition on (don't start the engine), within 5 sec the SIA status will be displayed. Release the reset button. Press and hold the trip reset button for 5 sec, "rst" will be displayed. Release and re-press trip reset button.
The new status should be displayed.
Oct 02, 2011 | 2004 Mini Cooper
After i turn on my Optio E10, it shuts off right away even after i put in new batteries.
Sounds like a memory card problem. Try using A 512mb San Disk SD Card. Not a San Disk SDHC card. see if that doesn;t help you out. Good-Luck
Mar 21, 2011 | Pentax Optio E10 Digital Camera
E10 and s45 same problem
the batteries needed for the cameras are quite high powered
though the batteries show that they are fuly charged most times they have lost their actual capacity of power storage in them so not being able to supply enough to start the camera best way to test this is to start the camera on preview mode if this works then you will need to buy a new set of rechargable batteries, i would suggest to take batteries in the range of 2000MAh to 2500MAh and
the normal batteries will not be able to sustain long even for normal lens open and retract functions, instead of normal batteries try LR6 varieties (eg: Duracell, Energizer, etc)
Jul 25, 2009 | Pentax Optio S45 Digital Camera
My front end loader washer keeps saying e10 error
E10- Problems with water drain during washing
-Drain hose kinked, filter blocked, drain pump, water distributor, wiring , main PCB, pressure switches
Usually due to debris trapped in the drain pump (pebbles/coins/hairgrips etc) jamming it. Clean it all out including all pipes.
Please rate fixya if we could solve your problem.thank you.
Dec 11, 2008 | Washing Machines
Iriver - E10, 6GB
Hope just battery got disconected. Just open the player's back and check.
Otherwise, it's USB Power Controller or Step-Down DC/DC Regulator broken.
Apr 17, 2008 | iRiver E10 Digital Media Player
Pentax optio E10
Put a quality battery and start it.....
Mar 22, 2008 | Pentax Cameras
Iriver E10 Reseting Options
can i suggest you try rockox http://build.rockbox.org/ this will give you more than the regular ole iriver software.
but if you really want to start fresh back up the e10 iriver software, format you e10, re-install iriver software, add your media back (i've done this with my kids ipods also..and it works like new)
good luck............feel free to rate if helpful
Jan 03, 2008 | iRiver E10 Digital Media Player
Eton E10 AM/FM Radio Logo
Top Eton Audio Players & Recorders Experts
Mike carichael
Level 1 Expert
k24674
RobertFonner
RobertFonner
Are you an Eton Audio Player and Recorder Expert? Answer questions, earn points and help others
