Question about Consew 3321-194 (head only)
I am selling a Consew 332R and someone asked me if it has reverse this is not my machine how do I tell if it has Reverse.
    President:
  • 405 Answers
It doesnt have reverse
Posted on May 28, 2010
Is there a zipper foot available for the consew 146rb?
Ask the manufacturer this question . we have no idea
Sep 27, 2015 | Consew Sewing Machines
How to Change stitch size
It is the knob above your reverse lever. Heres a copy of instruction manual.http://www.consew.com/Files/112347/InstructionManuals/206RB-5.pdf
Apr 16, 2015 | Consew 206RB
My reverse button is stuck and the lights on the stitch panel keep flashing, how do I fix it?
Meybe if you reformulate your questin telling WHAT brans and model of sewing machine are you using, someone might give you a straight answer
Feb 06, 2015 | Sewing Machines
I have used consew bls-600 industrial sewing I purchased recently. The stitch length 0-4 dial was not working and was very tight. I tried to open it. Now the reverse handle is also not working and t
Shorten your stitch in reverse the machine can't do a stitch that long in reverse. Also google your make and model machine and the word Manual so you can properly learn to use the machine safely.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Nov 04, 2014 | Consew Sewing Machines
Won t turn
Hello John, You need to push the silver button on the machine bed and turn the hand wheel in the reverse direction of rotation until it clicks. Good luck.
Mar 13, 2014 | Consew Sewing Machines
Changing the stitch length
I can't tell from the research I've done. But it appears that a lot of these 200 series machines are called "long stitch" machines and they do one stitch only.
You might call or email this fellow and ask him
http://www.billsewing.com/consew.shtml
Mar 14, 2013 | Consew 226R2 Sewing Machine
I have a Consew 206RB and it feeds backwords. How can I fix this?
I have a Consew 206RB-1 , if I had This problem I would think the stitch length setting or the downward pressure of the upper walking foot is wrong.
If you set the stitch length to less than 0 it would be in reverse and feed backward.
Dec 02, 2010 | Consew 206RB
Tension discs/ shredding needle thread
Your knee pad raises the presser foot and in turn releases the disc tension. The mechanism for this is in the front of the machine. If you can remove a nose piece this will be a lot easier to see,
There is a pin that pushes the tension discs open and quite often this has been removed or adjusted so a to not release tension when the presser foot is raised {more likely if this was a production machine} If someone took the tension control apart to accomplish this that my guess as to question 2.
The best part about Consew is the parts are common and the whole tension assembly isn't expensive. You can find service manuals on their website (see link) http://www.consew.com/Files/112347/InstructionManuals/206RB-5.pdf
Apr 12, 2017 | Consew 206RB
Dont know what model my consew is
I ask this same question of a man trying to sell me an old Pfaff that was made without reverse. He told me I only need reverse to knot the thread at the end of a seam. All I had to do was hold the fabric a little tighter than the presser foot does and the needle would stay in the same spot and the thread would pass through itself as many times as you think you need.
I have not tried it yet but if you just let the needle sew past the end of the fabric a half inch or so you should get a line of knots
The end of the seem you are making will always be covered by the next piece of fabric your adding to what ever your making.
Or a trimming of some kind, or as in upholstery held in place with staples and then always covered.
Your not going to leave a raw edge any where ! right?
Jul 18, 2009 | Consew 206RB
Loose top stitch when in reverse 206 RB4 Consew
Do you know how to check the timing of your machine? It sounds like a timing problem to me. If you don't know how to check the timing:
take the side plate off, take the needle plate off, take the presser foot off, and put a new needle in the machine. Make sure that the needle is in the lowest position and look at the needle bar for the two timing lines. Locate the top line. Then, turn the handwheel toward you until the top line is where the bottom line was. At this point, the tip of the hook should be directly in the scarf of the needle.
Oct 19, 2008 | Consew 206RB
Consew 3321-194 (head only) Logo
121 people viewed this question
Top Consew Sewing Machines Experts
SewTechWayne
SewTechWayne
Shehu Pro
Shehu Pro
Irene Tulloch
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
