Question about Philips 42PF9630A 42 in. Plasma Television
Red fuzzy horizontal screen on plasma tv (PHILLIPS 42). i read something about tightening the Y cable (im no tech...explain?) any one else experience this? Im about to put this tv out the goddam window. THANKS!!!!
  • 94 Answers
A transistor on the Y sus board needs to be adjusted. Or the entire Y sus board needs to be replaced
Posted on May 28, 2010
When you use a input the screen fuzzes red. It's a Panasonic Plasma TV TH-42PZ85U. It was made in 2008. Started when i was playing a game. It did it a few times and now its permanent. On the Video Inp
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 19, 2017 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
Whats causing horizontal lines in my philips 42 in. plasma tv? seems to be 4 sets of lines with about 15 to 20 lines in each set. Also has the red vertical explosion from images on the channel im watching.
There are very fragile ribbons that are attatched to the top of some LCD displays, if these have been pinched or damaged in anyway, this can create what you are describing. Was the LCD panel ever hit by like a wii remote around the tv bezel or did it fall without cracking the screen? It could be something simpler like, some really wrong color settings or something...
Jun 14, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
Red lines on plasma screen.
you may want to check out your buffers.
for cheap buffers check out hssparts.com
thank you
Dec 11, 2009 | Philips 42PF7220A 42 in. Plasma Television
No power to my Phillips 42 inch Plasma 42pf7321d/37, just a red blinking light
Most likely it going to be a power supply related problem. The red blinking light is a code for a TV tech to diagnose the problem on the power supply board itself or the board that regulates the power for the screen. Some manufactures call it a Backlight Inverter Board. A TV repair shop should be able to look at it for you and tell you which board is bad.
Replacement boards can be found at a good price at Shopjimmy.com
Sep 05, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Why do i have red lines on my philips plasma tv?
if the lines are going horizontally across and look like someone took a thin magic marker and marked across the screen, you have one of two problems, either some scan ic's have failed or you have a flex cable coming loose from the panel. Either way it will require repair. If it is the flex cable the cost to repair will be beyond the tv's worth because the whole panel needs to be changed to fix this. If it turns out to be the scan ic's, they can be changed or the board the ic's are on may be changed depending on how the repair is approched by the tech. But the cost would be reasonable around 200 to 250.
Good luck
Sep 03, 2009 | Philips 42HF7444T 42 in. Plasma TV
Samsung plasma red fuzz on black screen
Most likey its a bad panel, you can try adjusting VS voltage on Y main board, if this is to complex you will need a tech
Aug 09, 2009 | Philips 42PF9630A 42 in. Plasma Television
Our 52 inch Phillips Plasma tv is not working
open the back of the set and inspect the power supply board -- there should be two fuses on the board- they cost around 2 dollars at radio shack -- check all connections for wear or damage -- there are two boards in most televisions -- a power supply board and a audio / digital board -- one is probably board
Feb 28, 2009 | Philips 42PF7220A 42 in. Plasma Television
42'plasma phillips tv
I had the same problem and fixed with a great online tutorial. Just replace 3 capacitors available at Radioshack onthe the board. 2662, 2663, 2664 1 is a 1000uf the others are 100uf. Max Volts need to be over 25. It worked great, check http://dynamicorange.com/2008/06/25/fixing-a-plasma-tv/
for more detail.
Jan 06, 2009 | Philips 42FD9932 42 in. Plasma Television
Floating Horizontal Line
Sounds like a bad component on the video board. These days, TV techs just swap out boards for whole new ones.
Nov 17, 2008 | Hitachi 42HDX62 42 in. HDTV Plasma...
Red in left sie of screen show up sometimes on 42 samsung SP P4251
What component(s) are you connected to this TV?And what type of A/V cables are you using?
Does it only happen when you watch cable or directv or dishnetwork?
solutiondoct
Nov 06, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Philips 42PF9630A 42 in. Plasma Television Logo
220 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
