Question about Hobart SR24C-4 Dishwasher
Not pumping at end of cycle
I just replaced the trap underneath the washer where the hose drains into. I put the machine on without any dishes to check for leaks and now the machine isn't pumping at the end of it's cycle. I did a 2nd cycle and now there is twice the water. please help
  • 901 Answers
Cancell all the pre- set programs. refer user guide. Restart after switching OFF and try.
Still problem continues, only option to reset the system board. This procedure is known to the manufactures service provider. You have to get the sequence from them.
Posted on May 28, 2010
My F09 and my E01 codes keep coming on in mid cycle and shutting down the cycle
F09/E01 are related codes.
LONG DRAIN: If the drain time exceeds 8 minutes without reaching reset level in pressure sensor, the valves are turned off and the drain pump will stop running. NOTE: Suds can cause delays in draining. Washer drains for 4 minutes, pauses 5 minutes, then tries again for 4 additional minutes of draining. F9E1 will display if washer does not drain. (Normal drain takes less than 2 minutes)
Possible Causes:
Verify that the drain hose is not blocked or kinked.
Make sure drain hose is not sealed into drain pipe.
Make sure the drain hose height does not exceed 96" (2.4 m).
Check/clean drain pump filter of foreign objects.
Check connections from tub to air trap, air trap to pressure hose, and pressure hose to pressure sensor.
See TEST #8 (Drain Pump) on page 19. Is pressure hose pinched, kinked, plugged, or leaking air?Is pressure hose pinched, kinked, plugged, or leaking air?Is pressure hose pinched, kinked, plugged, or leaking air?
Oct 03, 2016 | Whirlpool Washing Machines
Is there a lint trap on this washer. Rinse cycle leaves lint. I've even did a complete cycle as a rinse.
Disconnect power, water supply and free drain hose. Turn machine on it's side. Underneath, you'll see two hises the same size as the drain hose ( one is actually the drain hose, the other drains from the drum.
Disconnect both and take shop vac to hoses and water inlets. That should clean out your pump.
look around and see if those hoses lead anywhere other than the drum and directly to the drain. If there is anything inbetween either, that's likely your filter.
Jan 25, 2015 | Washing Machines
Beko washer is leaking water from underneath
This video will show you in detail how to replace the door seal gasket and fit the new one properly to a Beko washer that is leaking water from underneath washing machine How to Replace Beko washing Machine Door Seal
Jan 24, 2013 | Washing Machines
Water leaking underneath pitsos dishwasher when in use
It is so common that the drain leaks in many ways and is the most problematic fault in a dish washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
to replace door seal : click on door seal
Jan 12, 2013 | Dishwashers
I have a Kenmore Elite washing machine, and while washing a load of laundry, the washing machine stopped.
So you have water in the bottom at the end of a cycle. Clean out you drain pump's coin trap, and stop putting clothes into the washer without clearing the pockets.
Nov 19, 2010 | Kitchen Ranges
Whirlpool Duet ----"SUD" and "F02" code
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
Aug 05, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Noise/not draining on spin cycle
I had that problem and it was the drain pump trying to drain but it coulsn't because it had lint, plastic, 3 underwires a looney some costume jewellery stuck in the pump. By the pump underneath you'll see a black plastic boot leading away from the pump. disconnect this and inside you'll find the lint trap and if you dig you'll probably find the culprit that stopping your pump from moving. Put it all back together and Voila!
Jan 12, 2009 | Kenmore 43142 Front Load Washer
LG DISHWASHER
This is a common fault if your drain hose or the drain pipework after it is blocked by tissues or fluff etc remove the drain hose from the vertical drain pipe or u-bend connection and check that all are free of obstructions. Also a lot of machines have a filter located at the bottom of the machine either behind a flap at the front or located near the pump at (usually) the back of the machine underneath. This can be got at by either removing the back panel if there is one or tilting the machine forward to access it from underneath chock the drum with wood to avoid drum suspension damage or re- attach the drum bolts which were removed when the machine was delivered if you still have them. The pump will have a rubber hose attached before it and the pump is connected to the machine end of the drain hose, often the rubber hose is large bore and incorporates a hard plastic filter designed to trap buttons coins etc before entering the pump and damaging the impeller blades, remove any debris.
In essence you are making sure the the whole drainage route from the drum to the final drain point is clear and free flowing.
Jul 14, 2008 | LG 24 in. LD-12BW5 Free-standing...
Smelly drum
run a load with no clothes, hot water and a gallon or two of bleach and less then 1 drop, very small amount of dish detergent. the dish detergent is used as  surfactant (makes the bleach stick to the interior walls)
run an extra rinse cycle to make sure you get all the bleach out before putting clothes in.
Jul 04, 2008 | Hotpoint Ultima WF865 Front Load Washer
Washing machine wont drain
the drain hose assembly is similar to a p-trap underneath your sink. make sure your drain hose is a upside-down J. from what you describe your hose isn't a p-trap.
Nov 02, 2007 | Washing Machines
Hobart SR24C-4 Dishwasher Logo
183 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
