Question about Kodak Office Equipment & Supplies
The documents are faded even after putting in a new cartridge
    Problem Solver:
  • 19 Answers
  • make sure you are using inkjet papers as inkjet printers work on inkjet papers.
  • Lift the printer access door, then remove the ink cartridges from the printhead.
  • Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  • Close the printer access door.
  • Reprint the picture or document that had the quality problem.
  • if still light prints then proceed further
  • Print Test Page
  • Review the printed test page and verify that:
    • the left color blocks are gray, cyan, and black.
    • the right color blocks are magenta, yellow, and black.
    • each block is completely filled with color.
  • If no---> Clean Printhead, the On/Off light flashes during the cleaning procedure.When the On/Off light glows steady, print test page again.
  • If Yes---->The problem could be caused by the type of paper you are using.
Posted on May 28, 2010
  • 295 Answers
SOURCE: PRINT FADES OMPLEELY OUT EVEN WITH NEW INK CARTRIDGES
Open the kodak all in one home center on your desktop and click on [?] on top most right hand side. choose maintenance under general links and choose printhead cleaning. if this does not solve the issue, call kodak @ 1800 421 6699 and they will replace the printhead for you free of cost.. do not worry.
Posted on Sep 21, 2009
SOURCE: Printer no longer prints legibly
My CLP-300 color laser printer does not print clear in black. The left side of the page is worse then the right side. what can be done to fix this problem
Posted on Oct 30, 2009
SOURCE: printed documents are faded even with a new cartridge
please get a newer version of driver.
Posted on Jan 27, 2010
  • 117 Answers
SOURCE: Black print is faded on my HP deskjet 6980
Here are some steps you can check to resolve your issue.
Check if the ink cartridges are low, specially the color black since if the black is empty, you are using the colored cartridges to print black. If the cartridges are newly replaced check the cartridges by reseating it. Try to consider changing the print quality high but doing so will use more ink. If still the same try to clean your printer heads.
Here are the instruction for cleaning your printer.
Open the printer tool box. (open a word, then click on file then print, choose properties, then services)
click on clean the print cartridges, then clean. Do test printing as well to check if the color is correct. If still the same calibrate the color which can be found in the same menu.
For more information here is the link for step by step instruction with visuals.
Hope this will help you resolve the problem.
Thank you for choosing fixya
Posted on Mar 03, 2011
  • 89 Answers
SOURCE: i just put in new
Most likely bad cartridges. Try going to Printers and Devices, find your printer, right click on it and select "printer properties". At the Properties window, select "Services" and on that window select "clean the cartridges" and ok. Let the printer complete its gyrations and try again. You can repeat this a couple of times and perhaps add the "prime" selection on subsequent tries. If that doesn't help, take the cartridges back and try for another pair. If they were refills, chances are they just weren't refilled.
Posted on Mar 16, 2011
Faded black and white printouts
If you remove the toner cartridge and gently shake it side to side, then reinstall it, does the problem go away, or come back after a few pages? I would suspect you have a bad toner cartridge/image unit and recommend you put in a new one.
Jan 24, 2014 | Xerox Phaser 4500 Printer
Hp officejet pro L7580 printer alignment failed and ink faded
Try the steps below.
Remove the Cartridges ( bottom left side of printer ) and clean the electrical ( golden contacts ) and put them back in.
Remove the Printhead ( Open the Printer cover and you will find the Carriage that moves. Lift the latch and clean the electrical contacts ( golden contacts ) with lint free cloth
Reinstall the Printhead and wait for printer to respond. IT should fix the issue.
Regards,
Sean
Apr 10, 2013 | HP Officejet Pro L7580 All-In-One InkJet...
Black print is faded on my HP deskjet 6980 printer. Whenever I print a word document it will have sporadic fading. It will be fine in one place then all faded in another. I've cleaned the cartridges and...
Mar 03, 2011 | HP Deskjet 6980 InkJet Photo Printer
Printing with a faded line down the document. does it just need a new cartridge/ Thanks Nick
Yes a new catridge can be the first option for the option for the fault but if after the new catridge is put in the fault is remaining then do a head cleaning before we can think of the laser jet.
Sep 24, 2010 | HP LaserJet 1018 Printer
Fading prints and new cartridge error, will not aliegn
It's possible it is the new cartridge, but it sounds more like the print heads. I had the same printer and same problems until I changed the print heads. You are better off buying American Made Printer Ink Cartridges Even If They Cost A Little Less Than Name Brands. I get mine from www.officeinks.com with a 1 year quality and satisfaction guarantee with free return shipping. I have used it once and had no hassle.
Oct 16, 2009 | HP Officejet 5610 All-In-One InkJet...
Faded or no printing of documents
First, have you removed the protective tape from the bottom of the printer cartridge? I know it sounds simple, but it's something easy to overlook when you install a new cartridge.
Jun 15, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Fading cartridge problems
That printer is pretty old. Are you selecting "Best" quality when you print or is it possible that some documents are being printed in Quick Print mode (which puts less ink on the page)? If you're doing the same thing on each print job but the print quality changes, there's definitely a problem. If you're printing from web pages, the print quality may be a factor of the design of the pages. If you print two pages of a multi-page document and quality declines, you should be able to get help through Lexmark's technical support.
Apr 09, 2008 | Lexmark P6350 All-In-One InkJet Printer
Black ink looks faded!
Providing that the ink cartridges were new and supplied with the printer, the cartridge is defective. I also don't think that you used up all the ink either unless you printed hundreds of documents already. Take the cartridge back to the store where you got the printer from and they should give you a new one.
Oct 29, 2007 | Dell 810 All-In-One InkJet Printer
97 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
