Question about Car Audio & Video
My deck is locked i never set code what could it be?
  • 185 Answers
Try 0000 or 1234
Posted on Apr 10, 2008
SOURCE:
Removed tape that jammed, replaced everything, how to clear code and get deck working again??
The deck should reset if the power cord is unpluged. On power up the deck should return to normal. If it does not then the condition that caused it could still be present or is now set up wrong. It is quite possible that the mode switch is in the wrong position and would need to be set up correctly. Unless you have done this before, you will probably need the service manual, as most VCR's are not set up in the eject mode!
Dec 06, 2011 | Sony UVW1800 VCR
I got a clarion vz409 car stereo an it locked completely
I just had the EXACT same problem, and 5 hours searching on the web got me nowhere. I set the lockout code, but it will not unlock, and now its locked up. then I called clarion. Turn the deck on with the screen out, then hold the power and play button to bring back up the password screen. Default is 0000 but if that does not work, enter 4356 and it will Unlock!
Aug 19, 2010 | Car Audio & Video
Panasonic vcr wont release tape has fault code f03
It sounds like you have a model that uses the K-Deck, you might need to confirm this, by putting the model number on Google and the words "K-Deck". However if it is a K-Deck F03 means that it locks up when unloading. This can be put down to the loading motor, or the drive system, perhaps even the mode switch, also the timing of the mechanism.
I suspect you will need the service manual, as setting up a new mode switch is tricky. The good news is that you can get the K-Deck manual online free, all you need do is do a websearch for "Panasonic K-Deck manual". It will even explain how to the tape out of the mechaism.
One tip you can try however is spraying the mode switch with Servisol Video 40, if you think it's the culprit, it could have just got some dirt in it, not saying it could be that though, but worth trying before replacing one. (Curry's Partmaster if you need to replace the mode).
Jul 04, 2010 | Panasonic Televison & Video
How to adjust height on tractor mower model no. 917.270812? I turn the adjustment knob and it will lock in only on the highest and lowest heights and nowhere in between.
You need to turn that knob to its highest point with the deck height lever to its highest setting. Now turn that knob counter clockwise a few turns and let the deck lever all the way down. That knob will stop the lever part way down. If it mowes to high rase that deck lever again and turn that knob counter clockwise some more and let that deck lever down again. Repete till you have the correct cutting height. If you were cutting to low turn the knob clockwise insted of counter clockwise in the instruction above. The knob only set the stop of the deck lever. Once set the deck lever lifts the deck up and holds it but when you let that lever down it returns to its mowing set height.
Aug 12, 2009 | Craftsman Garden
Hyundai accent 07 mp3-03 security code
IT WIL LOCK YOU OUT BUT IF YOU LEAVE IGN.ON ACC. FOR TWO HOURS IT WILL RESET AND ASK FOR CODE AGAIN.
Jul 06, 2009 | Hyundai Excel Cars & Trucks
Panasonic deck ag dv2000 gives error code f09
Your vcr seems to use the K Mech. F04 Means that the mechanism locks unloading.
The cause of which might be the loading motor timing.
F09 means No serial clock linking IC2004, IC7005 and IC7701.
Apr 29, 2009 | Panasonic AG-DV2000 Mini DV VCR
SPDIF IN/OUT not working on Gigabyte p35c-ds3r
hiya
you may have to set the input on your deck to digital b4 it will recognise the signal
Rik
Feb 21, 2009 | Gigabyte Computers & Internet
Where do you find the codes to lock and unlock the doors
sometimes the code is on the deck lid underside or the deck lid arms. or, call dealer with VIN number.
Dec 29, 2008 | 1990 Lincoln Town Car
Pioneer dvd head deck problem
either its lock to one region or the lens need cleaning. Search system settings for Region Settings
Jul 14, 2008 | Pioneer AVH-P5700DVD Car DVD Player
Eclipse 5340 deck
I forget about the security light but I do know about the clock. I believe you turn the deck off and hold display or push display and the clock will come up. Then use the preset buttons for adjustment. I think 1/2 is for the hour and 3/4 are for the minute. It has been a while for me doing this but I think it is right. I just powered mine back up a while back and am trying to find my starting cd. You wouldn't happen to know how to reset this function and start over?
Apr 11, 2007 | Eclipse 5340
Car Audio & Video Logo
49 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
