Question about LG KU990 Viewty
LG viewty - using windows 7 on pc - unable to find my phone when connected via USB
    President:
  • 1,118 Answers
I have this PC Suite, It works fine with my wife's KF750. Not sure whether it is device specific or not, though. Give it a try, if you really want.
Regards, Carlos
Posted on May 28, 2010
Lg ku990i pc suite
Visit this link to download the PC software for LG KU990.
If You want to be able to see the contents of your LG Viewty on your PC, you don't have to install the software. Here's a very simple solution to that
On your Viewy go to
1.Phone Settings,
2.select Connectivity,
3.select USB connection Mode
4.set it to Mass storage, (select)
5.go back to main screen, and connect your USB to the PC
6.Your Viwety should go immediately to USB mode
7. On your PC, Go to Computer, and look for the removable driver that corresponds to the new connection (your viewty), click on the driver icon and you should be able to see your phone's content if u have a flash memory inserted on your phone.
Thanks for using Fixya.
Rating the solution is highly appreciated.
Jul 01, 2010 | LG KU990 Viewty
Computer doesn't seem to recognise LG KU990i via usb
first check ur usb port that is it ok? sometimes some usb has problem when it become old. then check ur usb cable is that ok? if everything are ok then format ur pc and install usb 2 software for ur usb system. thanks
Aug 08, 2009 | LG KU990 Viewty
I cannot connect my lg viewty to my pc without it saying intialis
Did you have installed the drivers?
Run the software as administrator and by the warnig choose yes.
The fallowing software will e installed:
LG PcSuit
LG modem driver
USB modem driver
Ths take a few min.
Disconnect your LG before installing the software!!!
When its finshed you can also make an internet connction via USB or Bluethoot.
The second option go to your phone settings.
choose connctivity and the USB connection mode.
Choose Mass storage.
Now the phone will act as an extern USB Harddrive.
You can drop and drag files in the explorer of your windows.
After you finished the job you had to do put the setting back to Data service to receive the calls
etc.
I hope this will help.
May 26, 2009 | LG KU990 Viewty
No cd software
You CAN connect it to windows vista using the cable, however my own LG Viewty won't transfer anything without the software installed on the PC, the PC can detect it but it won't show on My Computer.
You can try it, but i'd advise downloading the software from somewhere.
Jan 12, 2009 | LG KU990 Viewty
Use LG KU990 Viewty as modem with a Mac
I want LG KU990 Viewty Pc suite to transfer datas.So please tell me from which site i can get it free of cost?
Puru
Nov 10, 2008 | LG KU990 Viewty
Unable to connect LG Viewty to PC via USB
Im going to tell you the safest, fastest, and Easiest way to do it, using your USB ,but it may require you to change settings manually on your device first. Make sure you have a Memory card,
Choose settings for USB connections
1.Find "USB connection mo..."
  • Press the menu icon.
  • Press the fourth tab.
  • Press Phone settings.
  • Press Connectivity.
  • Press USB connection mo....
  • 2.Select setting
  • Press Mass storage
  • Press OK.
  • 3.Exit
    Once you've done this and have your memory in your device, Open the MY COMPUTER folder in your computer and connect your device to your computer using the USB cord, a new Icon will appear containing the folders from your device's memory card, that way you will easily be able to transfer files back and forth without the NEED of any sofware Cd's or use slow Bluethoot.
    And Welcome to the Viewty Family! Enjoy...!
    Oct 23, 2008 | LG KU990 Viewty
    LG KU990 Viewty can't open the contents in the lg pc suite.
    HI All,
    I had the same problem where i could not access the pictures etc off my viewty using a Vista laptop.
    Now, assuming you guys are not bothered about the photo suite software itself, you can set the Viewty up to act as a mass data storage device (i.e. usb dongle etc). This enables you to view the full content of your Viewty, without using the **** LG software..
    To do this...
    1: Open up "Phone Settings"
    2: Select "Connectivity"
    3: Select "USB Connection Mode"
    4: Select "Mass Storage"
    5: Confirm by pressing "Select" at the bottom of the screen.
    6: Return to home screen and connect to PC.
    7: If PC does not automatically find the data, go to "My Computer" and look for a "Removable Storage Device"
    If all goes well, you should have access to all your files!
    Regards
    Craig
    Oct 16, 2008 | LG KU990 Viewty
    Trying to upload photo's but phone wont connect via usb
    while connecting phone to pc through usb port u should install the phone software in the pc first otherwise the pc will not allow you to connect and trasfer data. if there is a software u can easily trasfer data from phone to pc and pc to phone.
    May 23, 2008 | LG KU990 Viewty
    LG Viewty pc connection problems
    What you need to do is click on the top right corner of your LG Viewty phone which will show all applications running. If you have an 'Unknown' app, click on this.
    The problem is that the user guide for the phone is running and you need to click on 'Unknown' and finish the tour or exit.
    This will then alow you to connect to your pc;-)
    Dec 22, 2007 | Cell Phones
    LG KU990 Viewty Logo
    341 people viewed this question
    Top LG Computers & Internet Experts
    Michael Vincent Cruz
    Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
