Question about Bradley BTDS108P Smoker
The advance system: the motor arm will not make a full rotation and it not blocked by the micro switch but seems to come to a stop there
    Genius:
  • 1,417 Answers
what you need to apply to solve the problem of not rotating properly is oil
what i mean by oil is engine oil it wi free the dry on the surface of then engine
apply it on it then motor will rotate properly then the problem is solve.
than you and thanks for using fixya.
Posted on Jun 04, 2010
Unit will not stop
Dear Hal,
Here is some generic information about shredders that may help you.
Most of the shredders have a micro switch that "senses" if the paper has been introduced to the shredding slot. These micro switches are activated by a little arm/leveler that touches the paper and activates de contact inside the shredder housing. Also, note that some shredders may have an optical sensor that may be "clogged" with paper dust.
If you shredder does not stop, the sensor may be stuck in a on position, or, in case it has optical sensor may be detecting dust or a little piece of paper may be blocking the optical sensor and keeping the motor running.
I hope this gives you some light in further investigating your problem.
RC
Apr 14, 2014 | Office Equipment & Supplies
Frigidaire Model FDB780RCB0 I am getting water in the machine but it seems the arms are not turning what can I do to get that fixed?
The pump in the dishwasher is supposed to provide enough water pressure to turn the spray arms and make them rotate. The pump is faulty and not giving enough pressure or the arms are stuck.
Try spinning the arms, if they rotate smoothly, you will need to replace the pump.
Aug 03, 2008 | Frigidaire Dishwashers
Technics SL-10 does not rotate
OK a blast from the past. There is a switch that is in the base which senses that the cover is closed and this unlocks the arm and disk motor can rotate. The reason that the disk rotates when the cover is up is because this allows the disk to spin up to speed before the arm comes down. Once the cover comes down the switch unlocks the arm and the arm then moves this switch also can stop the disk if the arm does not unlock.
Sep 11, 2007 | Audio Players & Recorders
Suspect blockage top rotating washer arm does not spin
Both arms (upper and lower) are fed from the back of the machine, when you close the door the arms make a water tight seal with the pumped water in your washer.
Check to see that when the machine is full that both the arms will turn with very little pressure. (watch out for forks sticking out of the cuttlery tray etc.)
You can usually clear a blockage by putting a bag over the back of the arm that engages with the pumped water on the arm that "IS WORKING" this will increase the pressure to the arm that is not working usually freeing the obstruction.
Nov 07, 2009 | Kenmore Dishwashers
I have had to re-install a windshield wiper motor in a 1981 Chrysler New Yorker. Upon completion the motor seems to either lock up or not be in the same sequence/rotation as the wiper arms. How can I get...
With the arms off, run the wiper motor and shut if off normally with the switch. After it stops install the arms in the parked position (horizontal with the lower edge of the windshield).
Oct 18, 2009 | Chrysler New Yorker Cars & Trucks
My kitchenaid dishwasher needs the rinse aid refilled after approximately 2-3 loads. The top rack of dishes will be dirty, but the spray arm seems to be rotating? Any help?
Possibly needs a good servive. Remove spray arms and make sure every hole is totally clean. As well, take sieve out and pressure wash it as those holes are micro fine and if blocked, wont allow a full compliment of water to flow. see if it runs better after that.
Sep 16, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Asko D1706.The washing arms have stopped turning.
Can you hear the motor running? If the motor is runningand machine is full of water, but not pumping water around, you have one of the following problems:
-a blockage in the filters or sump preventing enough water getting to motor impellor,
-blocked jets in spray arms themselves,
-or I have had cases where the impellor has broken off the motor, hence motor runs but doesn't pump any water around. Check for blockages first, wouldn't suggest you take motor out and disassemble unless qualified or confident to do so (it's not an easy job if you haven' done it before!!)
Aug 04, 2009 | Dishwashers
How do you take off the sunroof of a 1986 944 porsche turbo?
Turn ignition on, make the sunroof go up and all the way down, turn off ignition and press the sunroof button to go down. Then unclip the 2 front hooks and push up.
Jul 07, 2009 | 1987 Porsche 944
LG LDS5811WW Low pressure out of spray arms
On the LG LDF xxxx dishwasher family, the Vario feature uses a motor/check valve to switch between "full power" cleaning from _either_ the lower or the upper spray arms, never at the same time. So, not seeing the upper arm spin during the lower arm spinning is standard operating procedure.
But back to your problem. Step one would be to remove the filter assembly again and make certain that there is nothing (debris, broken glass) blocking the white areas where the check valve rotates to switch between upper/lower spray arms. A blockage there ~could~ cause impotent spraying/cleaning.
If there is no blockage and the impeller remains in good shape, suspect a failing wash pump motor. Try to isolate the noise to that motor.
Watch for error codes on the display and report back what you find, OK?
Good Luck!
May 14, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Bottom spray arm not rotating
The arm usually will stop rotateing because there is a obstuction in the arm itself you will need to remove the arm normally unclips (older machine used to scew off)When you have the arm out check all hole top and bottom and open any that are blocked rinse out arm and replace give it a wash and see if there is any improovement,let me know.
Thanks
Feb 01, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Bradley BTDS108P Smoker Logo
23 people viewed this question
Top Bradley Grilling Experts
Oloyede Monsuru
ray gallant
Tom Chichester
Are you a Bradley Grilling Expert? Answer questions, earn points and help others
