Question about Zodiac Baracuda G4 Automatic Pool Cleaner Ne221
Can Baracuda Diaphragm be replaced?
My baracuda stopped working and it still has suction. It sounds like the diaphram is whats wrong. Can you replace it or is the unit not good anymore?
  • 990 Answers
If you can't find any junk in the diaphram or throught. The best thing to do is take it to a store they can show you how to do this and they will not usually charge for more than just the part.
Posted on May 28, 2010
Testimonial: "Thanks - I will take it in and have them look at it."
What and where is the diaphragm on by baracuda pool clener i think perhaps it needs replacing
Posted on Jun 06, 2010
Zodiac ranger has good suction but doesn't move
Usually if you have good suction with a Baracuda and no movement you either need to clear the diaphragm of debris, or replace the diaphragm if it's got a hole in it.
Check out this video (not mine) for how to pull the diaphragm out.
http://www.youtube.com/watch?v=FRR1Gsps8Js
It's pretty straightforward, just keep undoing things until you get to the flexible rubber bit. You have to check fairly carefully for holes because even the smallest opening means it's curtains for the diaphragm.
Good news is though that Zodiac should have a 1 year warranty on the diaphragm, which you can check by looking at the moulded stamp on the part. If it's under a year old your local dealer should just swap a new one for the old without any dramas.
Mar 16, 2013 | Zodiac Baracuda Ranger - Above Ground...
Baracuda stopped working. it is not vibrating but not moving
it ended up being that the hose had a kink in it. It's working fine now.
Feb 05, 2013 | Pool & Spa
Our cleaner works for 5-10 minutes and then does not work anymore..we replaced the diaphram, cleaned the filter, etc (G3)
Since you've already replaced the diaphragm, it sounds like a filter problem. Try acid washing the filter and see if that solves your problem. A suction gauge is supplied with the cleaner and you can compare readings when working or not. If reading goes down, it's a filter problem If it stays the same it's a cleaner problem. Could be a crack someplace on cleaner housing.
Jul 31, 2010 | Zodiac Baracuda G3 Automatic In Ground...
How to install new diaphram
Page 8 in the users manual for these pool cleaners has a good image of the diaphragm. There is also an assembly break down on page 10. Here is a copy. It should show you exactly how to get the cleaner apart to replace the part.
http://www.baracuda.com/resources/manuals/TL-2050.pdf
Jun 12, 2010 | Zodiac Baracuda G3 Automatic In Ground...
My Baracuda Zodiac works for a few minutes and
check the diaphragm for debris, damage, or deformity. unthread the collar above the handle and push the tube downward. Inspect the rubber diaphragm, any damage or deformity will cause erratic behavior.
Apr 07, 2010 | Zodiac Baracuda G3 Automatic In Ground...
No movement with my g3 baracuda
A small rip or tear in the diaphragm will cause that problem. When you put your hand over the mouth you are creating more suction to the diaphragm. Replace diaphragm.
Mar 01, 2010 | Zodiac Baracuda G3 Automatic In Ground...
My Baracuda pool cleaner doesn't work at all
While the cleaner is in the water, see if there is suction on the bottom of it. If not than you probably have a bad hose.(Broken) If there is a lot of suction then the diaphragm probably is either worn out or has a rip or tear in it.
Feb 24, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
My baracuda G3 stop working is not pulsating and therefore not moving. I checked the suction and the hoses even the diaphram everything looks ok.
If you have suction at the bottom of the cleaner, there has to be a problem with the diaphragm. I would remove it and recheck.
Feb 01, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Zodiac Baracuda G4 Automatic Pool Cleaner Ne221 Logo
1,096 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
