My computer screen keeps going blank then a error message appears saying that logon process has failed to create the secuity options dialog
    Novelist:
  • 125 Answers
There are two soltions to this problem that i know of
More than likely this happens because you have a non-Vista compatible
security suite installed. Have you installed some kind of
firewall/antivirus/whatever suite? If so, which?
and the second path to follow which i have heard of is that your C Drives S.M.A.R.T Data has errors on it , the only way to fix it then is to buy a new Hard Drive and re-install Vista , then add your old hard drive as a slave and get the data that you want off it.
Posted on Apr 07, 2008
Won't log in, says "the User Profile Service service failed the logon. User Profile cannot be loaded."
This is a simple fix that can be done in a few minutes or less. It is a problem with either an update from MSFT that had gone awry or an attack from a virus... Anyhow the steps to take are relatively simple just follow along.
1 - go to this site and it will walk you through step by step
You receive The User Profile Service failed the logon error message *make sure to choose option 1
Apr 12, 2014 | Computers & Internet
Tip
Create A windows 7 system repair disk
put a blank CD into the CD drive.(must be at least 700 MB) Go into SETTINGS and select BACKUP AND RESTORE on the left sidebar one of the options is to create system repair disk. Click this option and a window will appear. select your CD drive letter, then click create system repair disk it will take a minute then you will get a message saying that it's finished. take the CD out and keep it in case your computer crashes
on Mar 09, 2011 | Computers & Internet
Cant login
Restart your computer in safe mode. To do this first power it down wait 10 seconds. Locate the F8 key; press power button an start tapping F8 key. This will bring you to a screen with many options. Choose safe mode. This is a limited mode but many things can be fixed including your profile. Option 1. Go to control panel user accounts. Here you can add an account. Option 2 Delete your account (make sure there is another account you can log into prior to doing this) Go to start->computer right click then click properties. In system properties click advanced tab. Under user profiles click settings. In the User Profiles dialog box, select the profile that you want to delete, click Delete, and then click OK. Click Start, type regedit in the Search box, and then press ENTER. Locate and then click the following registry subkey:
    1. HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList
      Right-click the SID that you want to remove, and then click Delete.
  1. Log on to the computer and create a new profile.
  2. Hope this info helps.
Apr 27, 2013 | Acer Computers & Internet
I have a dell xps m140, when I turn on the computer I get a blue screen with the message, STOP: c000021a {FATAL SYSTEM ERROR} the windows logon process system process terminated unexpectedy without...
Hi
You do not say which operating system you are using.
A blue screen can have many causes, so you need to undertake an elimination process to identify the cause.
Most importantly, do not repeatedly keep trying to boot if blue screen keeps appearing, as this could lead to hasrdware failure. It is important to identify and fix the fault as soon as possible.
If you read the full error message, there will usually be an indication of the likely cause of the crash as well as some suggested remedies.
Typical causes are:
Conflict with newly installed software
Driver conflict or corruption
Malware infection
Insufficient Hard Drive space
Operating system corruption
Hard Drive fault
Overheating
Memory corruption
Graphics card fault
Each of these will have a different remedy.
Start by studying the error message in more detail, try the suggested remedy options, then post again with more specific information, if necessary.
Hope this helps.
Aug 22, 2011 | Dell Inspiron XPS M140 Notebook
Everytime i boot my Toshiba Satellite L305D i get a message on a the black screen before windows startup saying "windows has encountered a problem communicating with a device connected to your...
If you have external USB and/or CD disconnect them and try again. Otherwise it could be a fault hard rive - try to boot from an emergency CD (hopefully you created one when you installed Windows).
May 11, 2011 | Computers & Internet
How to change the Windows Logon screen saver from GPO
OK I know how to change the logon screen saver. I have a small batch
file to do it as part of our install process and it works. What I
would like to do is use our university logo and have it move around
the screen.
How do I have my scr file move around the screen like logon.scr ?
---blank-scr.bat---
:: Install a blank screen saver
@echo off
copy /y %Z%\packages\blank.scr %WinDir%\system32
:: Change logo screenscaver from logon.scr to blank.scr
reg add "HKU\.DEFAULT\Control Panel\Desktop" /v SCRNSAVE.EXE /t REG_SZ
/d blank.scr /f > nul
:: Change blanking time to 60 seconds
reg add "HKU\.DEFAULT\Control Panel\Desktop" /v ScreenSaveTimeOut /t
REG_SZ /d 60 /f > nul
Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Nov 11, 2009 | Microsoft Windows Server 2008 Enterprise...
My acer aspire 5570
Yes i have had this before and it only affects limited user accounts logging on, you use vista aye, i think it is another teething prob, just restart your computer and it should be right. i hope this answers you question. If not let me know
Dec 25, 2007 | Acer Aspire 5570-2758 Notebook
Microsoft Fingerprint Reader
If a screen popsup requiring user input is it possible that the screen you are referring to is getting shot down by a popup blocker?
Sep 23, 2007 | Microsoft Fingerprint Reader
Computers & Internet Logo
David Payne
David Payne
