Question about LG WM-2277HW Front Load Washer
Power button on lg wm2277hw was pushed in and is not releasing or popping back to normal postion. How do i fix this problem?
2 Suggested Answers
SOURCE: LG Tromm WM2277HW during high speed spin makes noise
I had exactly the same symptom...grinding noise only during high speed spin cycle.
I took the top and back panels off to see how the drain hoses etc. connected. Not wanting to take it apart further, I eventually just took the washing machine outside (I knew I was going to be dealing with water!), pulled the debris catcher front side bottom, and let rip with a garden hose inside the drum with the catcher out (leaving an open drain that could flow unimpeded).
Water flowed quickly out of the open drain, and lo and behold, a small drill bit came out with the water flow. This bit, presumably had gotten through the drum grating, and was resting on the bottom of the housing, scraping and grinding when the drum was spinning.
Posted on Sep 19, 2010
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
The dispenser drawer on my LG WM2277HW is stuck and I can't open it. Suggestions on what to do to fix this.
Hi Elaine258, you may need to take a look into it from the top, the soap, softener dispenser may be catching. Fairly straight forward to do, disconnect from the mains, two fasteners at the back hold the top on (if I remember right) lift top up from back and push forward, vvwalla.
Hope this helps.
Oct 04, 2015 | LG WM Washing Machines
How do i reset the service counter in my 2002 mercedes ml500
Turn the ignition key 2 clicks (postion II) and then quickly push trip button twice, you should see time or mileage remaining for service.hold trip button down and turn key off, keep trip button down do not release, with trip still down turn key back on to the II postion continue to hold button for about 10 sec,you will hear the dash beep and the display will read 10000,all set release trip and turn key off. let me know the outcome. good day
Feb 15, 2012 | Cars & Trucks
LG Tromm WM2277HW
Does spin only work well?
Apr 11, 2017 | LG WM-2277HW Front Load Washer
How do unlock mitre saw mastercraft 7-1/4-in mitre saw with laser its in the lock postion and wont release
There is a lever or push button by the hinge (where the saw pivots).Just push down on the top of the saw and release latch.To lock back down , just push down on the saw and put lever back in the lock position.
Jun 04, 2011 | Garden
My laptop does not go to sleep when I close it.
Check your laptop's energy savings settings are on. It might be set to go into hybernation after a certain amount of time. Also, have you tried pushing and releasing the power button instead of holding it when it does this? By holding the power button down until it turns off, you are causing a "hard" shutdown, which means it is by-passing all of the normal shutdown operations and can cause an error message to pop up when you boot it back up. Let me know if this helps!
Apr 29, 2010 | Dell Latitude D600 Notebook
1995 C220 SUNROOF NOT SEATING PROPERLY
Unfortunatly these roofs are basically a complete unit with cable and frame all in one unit where as previous roofs had replacable components. Assuming yourr roof seal is not torn or damaged you can adjust the glass somewhat. There are 6 torx style bolts that secure the roof to the tilting brackets. I would raise the roof in the pop up position and carefully remove the side bellows(They are also a common failure and can cause roof to bind or not operate to complete rest postion)-they pop out by pulling outward. Just remove the bottom section so you can easily reinstall them. Next loosen the back torx screws( I beleive they are size t20) and push roof up as far as you can and resecure. If only one side is not popping up as far as it should just do that side. Then try resynchronizing the roof parameters by pushing the button untill roof is in forward postion and hold for approximatly 10 seconds-next push button untill roof is in pop up position and hold for 10 seconds. You can also loosen all 6 screws by popping off the plastic trim piece in front of roof and loosening the screws and pushing roof all the way forward. but you will spend alot of time adjusting utill roof is perfect. good luck
Aug 04, 2009 | 2002 Mercedes-Benz C-Class
2004 CHEVY BLAZER REAR WINDOW LATCH
Any solution for this? I have the same problem on my 1996 s10 blazer.
Jul 06, 2008 | 2001 Chevrolet Blazer
LG WM-2277HW Front Load Washer Logo
124 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
