Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
The cooled air is coming out at a very weak rate. The ac unit outside is blowing out cool air when the neighbor's is blowing out warm air. The house is just not getting cool. AC has been on for 4 days straight
    Guru:
  • 415 Answers
Turn off your A/C and put your fan switch in ON or FAN. Run the fan only for approx 3 hours. Check your air filter and clean/replace as necessary. Also check your evaporator coil and clean if necessary. It is possible that your evaporator coil is frozen up from a dirty filter or coil. If it continues to be a problem, you probably have a refrigerant problem which will require a certified service technician to address. Try taking care of the filter and coil first. :-)
Posted on May 28, 2010
I have a whirlpool wall heat/ac unit, model ACE184XL0. All of a sudden, the heat quit working. Fan still blows, and AC still seems to work, although I can't tell if it's just pulling in cold outside air...
Dear it is a thermostat system. You can simply check it by setting temp at 30 then check either warm air is coming or cool air. at this time warm air should come. If warm air is not coming means there is a fault is realy in your pcb. It can be simply remove no need to worry.
Oct 14, 2013 | Whirlpool ACE244XS Air Conditioner
LG split unit AC works perfectly for 2 hours and then it stops blowing cool air
Check the amp draw on the condenser fan motor against the rating on the nameplate. motor may be getting weak and shuts down on thermal overload. If the amps are high you have a motor going bad, change it.
Aug 06, 2012 | LG Heating & Cooling
Ac unit isn't blowing
It sounds like your freezing up at the coil, which in turn, blocks airflow across coil and only a small amount of air comes out of the vents. This also explains the cold air coming from fan on the outside unit, since the system cannot absorb the heat from the inside of the house through the coil. Your air outside is usually blowing out warm to hot air because thats the heat it rejects out of your system. I would turn the thermostat to "OFF" and turn just the fan setting to "ON" instead of Auto, this thaws the system out faster. Give it time to fully thaw, make sure filters are clean, and check airflow. If airflow is back to normal, your problem is more than likely the charge of refrigerant. If you have to call a technician out, make sure the unit is not frozen at all before they get there, they would not be able to do anything with the system froze. Hope this helps and good luck!
Jun 18, 2012 | Heating & Cooling
Lennox 10HPB36-10P is blowing luke warm air.
What coil is getting cold? In cooling the evaporator coil should be getting cold not the outdoor condensing coil. Verify you have the tstat setup for heat pump, verify you have a proper refrigerant charge.
Apr 19, 2017 | Heating & Cooling
Why would cool air be blowing out of my central ac unit condensor that sits outside? The other unit I have next to it blows out warm air and responds well to thermostat changes. The unit blowing cool air...
It probably has a low refrigerant charge. The air coming out of the outside unit should be warmer than the outdoor temperature when in the cooling mode and if it's a heat pump it should be colder than the outdoor temperature in the the heating mode. Check the big line going to the unit, it should be somewhere around the 40 F range and the small line should be hot.
May 23, 2010 | Goodman CKL24AR24 Air Conditioner
Unit not blowing cold air
you have a slow leak in your refrigerant and need to find the leak. you will have to get an AC repairman to come to your house and check it for leaks and fix the problem.
Jul 28, 2009 | Amana Comfort Zone 12M32PBEH Air...
AC BLOWS WARM AIR
Cooling comes from what is done outside, if air handler is blowing and you are hearing a sound , may be in the duct work. If you feel warm air in cooling mode then the outside unit is the prob, need more info
Jul 25, 2009 | Heating & Cooling
AC not cooling during the day
Your AC cooling efficiency is low when he ambient temperature is high and naturally it cools well when the outside temperature drops.
Please remove the filter on the grill and try to clean it under the tap water and after removing all the dust fix it back to the unit. This would increase the cooling efficiency of the unit.
Your AC is also five years old. Please avoid frequent opening of doors or windows.
Ensure that the exhaust fan and the blower of your unit are functioning normal.
The technician might not have done a proper job in fixing the area where the refrigerant would have leaked out. Please check the refrigerant pressure to ensure that no further refrigerant leak has taken place. Or even servicing your unit he would have punchered the tubes resulting in very slow leak of refrigerant resulting in no cooling or less cooling. It takes around a month to feel the pinch of it and the refrigerant. One fine morning after sometime the unit will run and it would start throwing hot air instead of cool breeze!
Jul 13, 2009 | Heating & Cooling
AC unit outside turns on but no air blows through the vents
The first problem sounds like the wiring is wrong up at the heating unit not turning on the blower fan in the heater when you call for cooling. Most typical is either something has chewed the wires or the wires have been stripped b something else. The AC not cooling your house can be either it is low on freon or the system is to small for your house. Also check your filter and make sure that it is not blocked and everything is clean with the filter
May 28, 2009 | Heating & Cooling
My AC unit keeps freezing up on the copper lines going into the house from the outside unit. It also freezes up on the inside lines and the air is not cooling my home down.
Operate your air conditioner with the fan in the on position. But first turn the fan on, turn the temp up or shut the cooling off. Your coil is more than likely frozen over. At night when outside temperature drops the refrigerant pressure and temperature in the system also drops. This action can cause icing of the cooling coil, with the fan in automatic everything shuts down at the end of a cooling cycle. Thus no air movement to melt ice on previous cooling cycle.
May 09, 2008 | Heating & Cooling
Heating & Cooling Logo
139 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
