Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Uneven cut, seems like it misses spots. new blades.
  • 333 Answers
Sounds like the belts are slipping on the deck. Wheneve it gets overloaded it skips? Check under the deck and see if there is anything that the grass can be catching on and keep it from flying out the discharge shoot. And see if there is anything on the belts. Like oil from something leaking, Lots of grass built up under the shieldsl Or if there is lots of grass build up keeping the tensionor pulley from tightning up the belty all of the way.
Posted on May 28, 2010
Left side is scalping especially when turning
Stephen Bent/damage blade or spindle, check your deck for support link pin missing, damaged or rusted out brackets, blade spindle loose/mount damages or rusted out, missing deck support spring,wheel/roller if equipped, damaged blades, Recheck tire pressure and front steering axles for bent/damage, etc.
When measuring deck for level, measure at blade tips not the deck on a flat level surface. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Mower Quality of Cuts Problems and Solutions
How to Adjust the Deck Height on Husqvarna
Craftsman Riding Lawn Mower cutting uneven
cutting uneven chopping up ground Craftsman Riding Mower
Jun 06, 2016 | Husqvarna Garden
Rider not cutting evenly
It's usually a bent blade, or a bent or loose deck, or a guide wheel or roller missing. It can occasionally be even a dull blade that pushes the grass over rather than cutting it. If the other blade(s) is sharp, it will cut at the correct length and you'll see an unevenness between the two.
Park it on a flat, smooth surface. A paved driveway or sidewalk works well. Check your wheels and/or rollers on the deck. Are they all touching the ground? Are they loose and wobbling? If nothing is obvious yet, take a tape measure and check the height of the bottom edge of the deck in several spots. They should be all close to the same measurement. If it has different measurements, there is usually a slotted adjustment where you can loosen the adjuster, make the correction, and tighten it up again.
Also, did you hit anything that may have bent a blade? Are the blades in good condition? If the blade tip on one end gets bent up, it will cause a sculpting effect to the lawn surface.
I hope that all helps!
Ed
Jul 25, 2011 | Garden
I had hit a somewhat hidden stump on the lawn..bending the blade. Took the deck off and replaced the bent blade. Put the deck back on and now the cut seems uneven. It appears that the deck is now...
I've only had luck removeing the deck, turn it upside down. Measure blade, mark, remove blade, insert large pipe over spindle, bend in direction. Re-install blade, and do it all over and over till straight. Measure in several locations.
Aug 18, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
My tractor cuts uneven when i am cutting my yard
Check your blades common problem with uneven cut is a bent blade. Next find a level spot like a padio and take a torpedo level place it on the front center side to side not front to rear. On one side or the other you should see a J(jay) bolt with a nut tighten to raise losen to lower.
Terry
Aug 18, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
The mower is mowing uneven in the front. what can i do? it seems that it is scalping the grass but both sides are level
Look under the mower deck. If you can't see well and work on it, you may have to remove the mower deck and flip it over on the ground. Grass and mud buildup in the decj could cause a blade to pinch grass, 'scalping' the lawn. Clean it all out. Dull blades cause cut grass to look torn and brown. Remove and sharpen. Bent blade will cause uneven cut. Replace it. Good luck! Please rate if you found this helpful, thanks!
Jun 05, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Why does my 42 inched deck craftsman tractor cut uneven?
It needs to be leveled. Level it from side to side and front to back, then drop the front 1/4" lower than the rear. The hangers holding the deck in place are adjustable.
Jun 05, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Cuts uneven, lawn looks terrible. Missing half
Are your blades upside down? Mower deck level?Proper air pressure all 4 tires?Correct blades for the diameter of cut? Deck bent? Deck hangers bent?
May 28, 2010 | Garden
I sharpened the blades at the end of last mowing season. The next cut was very uneven, so I checked to make sure that the blades were installed properly and re-leveled the deck. The last cut was even...
The problem you discribe is the classic broken blade spindle or quill. The tube that supports the bearings between the deck pulleys and the blades is almost certainly broken. Look under the deck [mower OFF] at the piece right above the blade that is malfunctioning and you will probably find a bad bearing or a chunk of the tube that holds the bearing/blade to be missing. That happens when the blade gets 'wacked'. The outer edge is cutting too high because the belt is pulling the shaft toward the center of the deck. The quills are fairly easy to replace. Get the model number off your tractor before you go to buy the part.
Apr 04, 2009 | Craftsman 42 in. Precision Cut Plus 24hp...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
137 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
