Question about Garden
Does the belt or pulley need to be timed? - Garden
  • 333 Answers
No
Belts and pulleys ard smoothe and slip quite ofton. So it wouldnt do any good andyway.
However some chains have to be timed. And split asle on older trucks.
Posted on May 28, 2010
Timing belt instalation 03 kia spectra need the diagram for it
Installing timing belt is not very hard. Install the timing belt onto the pulleys, as follows, crankshaft pulley first, then the idler pulley, exhaust camshaft pulley, intake camshaft pulley, and the tensioner pulley. Just make sure the timing marks are set exact and not got moved from its actual position.------ If in-case,you missed the timing marks.Then you need to align it exactly,other wise there will be problem.------ For timing belt replacing and timing belt diagram,click the link below:--- http://carbeltrouting.blogspot.com/2011/10/2003-kia-spectra-timing-belt.html ------- This should help.Thanks.Helpmech.
Oct 03, 2011 | 2003 Kia Spectra
Need to know timing marks
REMOVAL
1. Disconnect negative battery cable.
2. Loosen power steering lock bolts and nuts accordingly and remove tension from power steering (P/S) and/or air conditioning (A/C) compressor drive belt.
3. Remove P/S and/or A/C drive belt.
4. Loosen generator mounting bolts and adjusting bolt.
5. Remove generator bolts.
6. Remove water pump pulley.
7. Remove crankshaft pulley.
8. Remove upper and lower timing belt covers.
9. Turn crankshaft so that timing mark on timing belt pulley is aligned with timing mark on engine.
10. Check that "I" mark on intake camshaft pulley is aligned with mark on seal plate and "E" mark on exhaust camshaft pulley is aligned with mark on seal plate.
Do not move camshaft or crankshaft once timing marks have been correctly positioned.
11. Loosen tensioner pulley lock bolt.
12. Protect timing belt with a rag.
13. Remove tensioner pulley.
14. Remove timing belt. Mark the direction of timing belt rotation (on the timing belt) for proper reinstallation.
INSTALLATION
1. Install tensioner pulley. Replace tensioner spring whenever timing belt is replaced.
2. Pull tensioner pulley to its furthest point and tighten lock bolt.
3. Check that timing mark on timing belt pulley is aligned with timing mark on engine.
4. Check that "I" mark on intake camshaft pulley is aligned with mark on seal plate and "E" mark on exhaust camshaft pulley is aligned with mark on seal plate.
If existing timing belt is being reused, install belt in proper rotation direction marked prior to removal.
5. Install timing belt onto timing belt pulley first, then idler pulley, exhaust camshaft pulley, intake camshaft pulley, and tensioner pulley in that order.
6. Check that there is no looseness in belt between idler pulley and exhaust camshaft pulley or between intake and exhaust camshaft pulleys.
7. Loosen tensioner pulley lock bolt and allow tensioner spring to apply tension to timing belt.
Do not add additional tension.
8. Tighten tensioner pulley lock bolt to specified torque.
Tightening torque:28~38 lb-ft (38~51 N·m, 3.9~5.2 kg-m)
9. Rotate crankshaft two full revolutions (clockwise only) and align timing mark on timing belt pulley with timing mark on engine block.
10. Check that "I" mark on intake camshaft pulley and "E" mark on exhaust camshaft pulley are aligned with marks on seal plate.
11. If they are not aligned, remove timing belt and start process from tensioner installation.
12. Measure timing belt deflection by applying moderate pressure midway between camshaft pulleys. If deflection is not correct, repeat from tensioner installation.
Deflection pressure:22 Ib. (98 N, 10 kg)Deflection:0.39~0.50 in. (11~13 mm)
13. Install lower and upper timing belt covers in that order.
Tightening torque:5.8~8.0 Ib-ft (7.9~10.7 N·m, 0.8~1.1 kg-m)
14. Install timing belt guide plate and crankshaft pulley.
Tightening torque:9.0~12.6 lb-ft (12.3~17.2 N·m, 1.3~1.8 kg-m)
15. Install water pump pulley.
16. Install generator belt and adjust the tension.
17. Install P/S and/or A/C drive belt and adjust the tension.
18. Connect negative battery cable.
INSPECTION
Never forcefully twist, turn inside out or bend timing belt. Do not allow oil or grease to come in contact with timing belt.
1. Replace timing belt if it is contaminated with oil or grease.
2. Check timing belt for uneven wear, fraying, peeling, cracking and hardening. Replace timing belt as necessary.
3. Bend timing belt into a "U" shape as shown in figure. Distance "A" must be at least 1.0 in (25 mm).
4. Inspect both idler pulley and tensioner pulley for uneven wear and smooth bearing operation.
5. Inspect camshaft pulleys and timing belt pulley for broken teeth or damage.
Replace any component that shows damage, excessive wear, or that appears prone to a possible failure.
Feb 26, 2011 | 2002 Kia Spectra
Need diagram to put timingbelt on 2001 kia sportage
prev.gif next.gif Timing Belt Removal & Installation SOHC To Remove:
  1. Disconnect battery negative cable.
  2. Remove fresh air duct.
  3. Drain engine coolant into an appropriate container and retighten radiator drain plug.
  4. Remove upper radiator hose.
  5. Remove fan clutch assembly bolts.
  6. Remove 5 cooling fan shroud bolts.
  7. Remove fan shroud and fan as an assembly.
  8. Loosen alternator mounting bolts and remove drive belt from pulley.
  9. Remove fan pulley.
  10. Remove 4 cooling fan assembly bolts.
  11. Remove cooling fan assembly.
  12. Remove 4 bolts and upper timing belt cover.
  13. Remove 2 lower bolts and lower timing belt cover.
  14. Loosen adjusting bolt and remove A/C belt.
  15. Remove alternator belt.
  16. Loosen power steering pump lock bolt and mounting bolt.
  17. Remove drive belt from crankshaft damper. Camshaft timing marks kia-03-20-7032.gif
  18. Turn crankshaft until timing mark on front housing and the arrow "2" on the camshaft pulley align.
  19. Remove 5 bolts and remove damper.
  20. Remove timing belt guide from timing belt pulley.
  21. Loosen tensioner lock bolt.
  22. Pry tensioner away from timing belt and tighten lock bolt to relieve tension on the timing belt. NOTE: Mark the direction of timing belt rotation on the belt if it is being reused.
  23. Remove timing belt.
To Install:
NOTE: Timing belt pulley timing mark and timing mark must be aligned.
NOTE: The arrow at "2" on camshaft pulley must be aligned with timing mark on front housing.
  1. Install timing belt with minimal slack from timing belt pulley to water pump and from water pump to camshaft pulley.
  2. Loosen tensioner lock bolt until tension is applied to timing belt. CAUTION
    Do not turn crankshaft counterclockwise.
  3. Turn crankshaft pulley 2 full turns clockwise and ensure timing marks are properly aligned.
  4. Tighten tensioner lock bolt to 33 ft lb (45 Nm).
  5. Apply a force of 21 lb to timing belt midway between idler pulley and camshaft pulley.
    • Deflection should measure 0.43-0.51 inch (11-13 mm)
    NOTE: if timing belt deflection is incorrect remove timing belt and install NEW tensioner spring.
  6. Install timing belt guide.
  7. Install crankshaft damper pulley.
  8. Install 5 crankshaft damper pulley bolts. Tighten bolts to 132 in lb (15 Nm).
  9. Install power steering pump drive belt.
  10. Adjust power steering pump drive belt tension and tighten lock bolt and mounting bolt.
  11. Install alternator drive belt.
  12. Install A/C drive belt.
  13. Install lower timing belt cover and bolts. Tighten bolts to 84 in lb (10 Nm).
  14. Install upper timing belt cover and bolts. Tighten bolts to 84 in lb (10 Nm).
  15. Install cooling fan assembly and 4 bolts. Tighten bolts to 27 ft lb (37 Nm).
  16. Install fan pulley.
  17. Install fan clutch and shroud as an assembly. Tighten bolts to 74 in lb (8 Nm).
  18. Tighten 4 cooling fan nuts to 16 ft lb (22 Nm).
  19. Adjust alternator belt tension and tighten alternator mounting bolts.
  20. Install upper radiator hose.
  21. Install fresh air duct.
  22. Connect battery negative cable.
  23. Refill/bleed cooling system.
DOHC To Remove:
  3. Remove 5 cooling fan shroud bolts and 4 thermo-modulated fan nuts.
  4. Remove 4 thermo-modulated fan shroud fasteners.
  5. Remove generator drive belt.
  6. Remove fan pulley (located above crankshaft pulley).
  7. Remove 4 bolts and splash shield (located under front of vehicle).
  8. Remove A/C drive belt and power steering drive belt. Timing Belt Removal kia-03-20-7097.gif
  9. Remove 5 bolts and upper timing belt cover.
  10. Remove 2 bolts and lower timing belt cover.
  11. Loosen tensioner lock bolt and pivot tensioner pulley outboard.
  12. Retighten tensioner lock bolt. NOTE: Mark timing belt for rotation if it is being reused.
  13. Remove timing belt.
To Install:
  1. Align marks on timing belt pulley and pump body. Camshaft pulley alignment marks 79245g28.gif
  2. Align marks on camshaft pulleys with alignment marks on seal plate.
  3. Install timing belt. NOTE: No looseness should exist on the tension side and at the camshaft pulleys.
  4. Loosen tensioner lock bolt.
  5. Turn crankshaft 2 revolutions in direction of rotation and check that timing marks are still in alignment.
  6. Tighten timing belt tension lock bolt to 27-38 ft lb (32-52 Nm).
  7. Apply a force of 22 lbs to timing belt between camshaft sprockets.
    • Belt deflection should measure 0.30-0.33 in (7.5-8.5 mm)
    NOTE: Replace tensioner spring if timing belt deflection is excessive.
  8. Install lower timing belt cover.
  9. Install upper timing belt cover.
  10. Install power steering drive belt and adjust belt tension.
  11. Install fan pulley.
  12. Install generator drive belt and adjust belt tension.
  13. Install A/C drive belt and adjust belt tension.
  14. Install splash guard.
  15. Install fan and fan shroud.
  16. Install 4 fan bolts. Tighten to 24 ft lb (33 Nm).
  17. Install fan shroud mounting bolts.
  18. Install fresh air duct.
  19. Connect hose to resonance chamber.
  20. Connect battery negative cable.
Aug 02, 2010 | 2001 Kia Sportage
Would like information on timing belt settings on a 1993 Isuzu Rodeo 4X4 3.2 We have already bought the book. It seems that the setting still are not what this particular motor/engine needs are there other...
look for timing marks????
Align groove of crankshaft timing pulley with mark on oil pump.
Align the marks on the camshaft timing pulleys with the corresponding dots on the front plate. (i can email pic if needed)
When timing marks are aligned, no pistons will be on T.D.C.
install timing belt. Align the dotted alignment mark on the timing belt with the mark on the crankshaft gear.
For correct belt installation, the letters the belt must be able to be read as viewed from the front of the vehicle. It is recommended for easy installation that the belt be secured with double clips after it is installed to each pulley. Align the alignment mark (white line) on the timing belt with the alignment mark on the RH bank camshaft timing pulley (on the left side as viewed from the front of the vehicle Secure the belt with a double clip.
Turn the crankshaft counterclockwise to remove the belt slack between the crankshaft timing pulley and the RH bank camshaft timing pulley.
Install the belt on the water pump pulley. Remove double clips from pulleys. Turn the crankshaft pulley clockwise by two turns. Measure the rod protrusion to ensure it is within the standard. Standard 4-6 mm (0.16-0.24 in)
13) If out of standard, remove pusher, loosen adjusting bolt, and readjust. (Repeat from step 11). Tighten adjusting bolt to the specified torque. Torque 42 N-m (31 lb-ft)
  1. Pusher
    • Tighten bolt to the specified torque.
Torque 19 N-m (19 lb-ft)
  1. Timing belt cover
    • Remove crankshaft pulley that was installed in step 9.
    • Tighten bolts to the specified torque.
Torque 17 N-m (12 lb-ft)
  1. Oil cooler hose
    • Tighten oil cooler hose bracket bolts to the specified torque.
Torque 22 N-m (16 lb-ft)
  1. Crankshaft pulley assembly
    • Using special tool J-8614-01, hold the crankshaft pulley.
    • Tighten center bolt to the specified torque.
Torque 167 N-m (123 lb-ft)
  1. Crankshaft pulley; P/S belt
    • Tighten fixing bolt to the specified torque.
Install the belt on the idler pulley.
Mar 07, 2010 | 1993 Isuzu Rodeo
I need a new timming belt on a 01 kia sephia how do i change it
Below are the procedures to remove the timing belt...
2. Loosen power steering lock bolts and nuts accordingly and remove tension from power steering (P/S) and/or air conditioning (A/C) compressor drive belt. 3. Remove P/S and/or A/C drive belt.
4. Loosen generator mounting bolts and adjusting bolt. 5. Remove generator bolts.
7. Remove crankshaft pulley and timing belt guide plate.
10. Check that "I" mark on intake camshaft pulley is aligned with mark on cylinder head cover and "E" mark on exhaust camshaft pulley is aligned with mark on cylinder head cover.
Regards,
Jeep Brainy
Sep 20, 2009 | 2001 Kia Sephia
The Timing belt
Recommended by kia is 100,000 km.
Timing Belt: Service and Repair
TIMING BELT
COMPONENT
REMOVAL
2. Loosen power steering lock bolts and nuts accordingly and remove tension from Power Steering (P/S) and/or Air Conditioning (A/C) compressor
drive belt.
NOTE: Do not move camshaft or crankshaft once timing marks have been correctly positioned.
NOTE: Mark the direction of timing belt rotation (on the timing belt) for proper reinstallation.
INSPECTION
NOTE: Never forcefully twist, turn inside out or bend timing belt. Do not allow oil or grease to come in contact with timing belt.
3. Bend timing belt into a "U" shape as shown in figure. Distance "A" must be at least 1.0 inch (25 mm).
NOTE: Replace any component that shows damage, excessive wear, or that appears prone to a possible failure.
INSTALLATION
NOTE: Replace tensioner spring whenever timing belt is replaced.
4. Check that "I" mark on intake camshaft pulley is aligned with mark on cylinder head cover and "E" mark on exhaust camshaft pulley is aligned
NOTE: If existing timing belt is being reused, install belt in proper rotation direction marked prior to removal.
order.
NOTE: Do not add additional tension.
Tightening torque: 28 - 38 ft. lbs. (38 - 51 Nm, 3.9 - 5.2 kg-m)
10. Check that "I" mark on intake camshaft pulley and "E" mark on exhaust camshaft pulley are aligned with marks on cylinder head cover.
Deflection pressure: 22 lb. (98 N, 10 kg)
Deflection: 0.39 - 0.50 inch (11 - 13 mm)
Tightening torque: 5.8 - 8.0 ft. lbs. (7.9 - 10.7 Nm, 0.8 - 1.1 kg-m)
Tightening torque: 9.0 - 12.6 ft. lbs. (12.3 - 17.2 Nm, 1.3 - 1.8 kg-m)
16. install generator belt and adjust the tension.
Sep 17, 2009 | 2003 Kia Rio
Timing belt alignment
A factory service manual would help, but I'm assuming that if you had one, you probably wouldn't be on this site.
To set the timing, you need to first perform the obvious: remove the accessory drive belts, cam pulley covers, and engine fan and hub. Next you'll need to rotate the engine by hand until the timing marks on the camshaft sprockets and crankshaft are aligned with their corresponding stationary marks. The 0 degree mark on the lower timing belt cover is the timing mark for the crankshaft pulley. There is a mark (small, vertical formed indentation) for the left camshaft pulley on the backing plate behind the pulley near the 1 o` clock position. The same mark exists for the right camshaft pulley only it is on the backing plate near the 8 o`clock position (making it difficult to see). With the crankshaft placed at the zero mark, you can observed where the timing discrepancy exists.
(TIP: Once the right camshaft timing is properly lined up, etch an additional mark on the pulley's face and the backing plate at the 12 o`clock position. This will make it easier to align the pulley for furture adjustments and repairs)
To set the timing correctly, move the crankshaft pulley to 12 deg. BTDC. Being careful to not disturb the position of the crankshaft once it has been moved to that position, remove the crankshaft pulley, lower timing belt cover, timing belt tensioner, and timing belt. Compress the timing belt tensioner and if the original ring pin isn't available to retain the tensioner a small allen wrench can be used to achieve the same results. Line up both camshaft marks and reinstall the timing belt and timing belt tensioner (do not remove the timing belt tensioner tool used to maintain the tensioner piston in a compressed position). When installing the timing belt, be sure to allow the least amount of slack to exisit between the left camshaft pulley and the crankshaft sprocket, but without moving the pulleys.
Next, remove the timing belt tensioner piston retention tool and mount the lower timing belt cover and crankshaft pulley (without fully installing them). Rotate the crankshaft pulley to the 0 deg. mark. If done correctly, moving the crankshaft pulley from 12 deg. BTDC to 0 deg. will remove all remaining slack from the timing belt assembly and the camshaft pulleys and crankshaft pulleys will be lined up with their corresponding marks. Once proper timing has been achieved, install all removed parts.
(Another TIP: I hope it's not necessary, but in case it is, I'll remind you that proper torque of all bolts are necessary as this is an all aluminum engine. Stripping out bolts holes due to over-tightening bolts occurs very easily and become very annoying to deal with [e.g. alternator belts not being able to be tightened completely and constantly squealing every few days, etc.])
Apr 26, 2009 | 1997 Isuzu Rodeo
Need instructions to replace 1993 Toyota Camry Timing Belt
Hi Kmcarroll77
TIMING BELT REPLACEMENT - 2.2L -1993 Toyota Camry
Installation
1.Install No. 2 idler pulley (if removed). Install and tighten bolt to specification. See TORQUE SPECIFICATIONS . Ensure idler pulley is clean and rotates smoothly. 2.Install No. 1 idler pulley and tension spring (if removed). Pry No. 1 idler pulley away from timing belt area as far as possible. Temporarily tighten No. 1 idler pulley bolt. Ensure idler pulley is clean and rotates smoothly. 3.Using crankshaft pulley bolt, rotate crankshaft so timing mark on crankshaft sprocket aligns with timing mark on oil pump housing. See. This will position keyway in crankshaft sprocket at 12 o'clock position.
CAUTION:If reusing timing belt, ensure reference marks on timing belt align with reference marks placed on crankshaft and camshaft sprockets. Ensure timing belt is installed in original direction of rotation.
4.Ensure all sprockets and idler pulleys are clean. Install timing belt on crankshaft sprocket, oil pump sprocket, No. 1 idler pulley, and then No. 2 idler pulley in sequence. 5.Install timing belt guide with cupped side away from crankshaft sprocket and flat side toward timing belt. Install No. 1 timing belt cover and new gasket. 6.Align crankshaft pulley key groove with key in crankshaft. Install crankshaft pulley. Install and tighten crankshaft pulley bolt to specification. 7.Rotate crankshaft clockwise so cylinder No. 1 is at TDC on compression stroke. Ensure timing mark on crankshaft pulley aligns with "0" mark on No. 1 timing belt cover. If reusing timing belt, ensure reference mark on timing belt aligns with upper edge of No. 1 timing belt cover. 8.Rotate camshaft, and align hole in camshaft sprocket with alignment mark on camshaft bearing cap. See Fig. 2 . Install timing belt on camshaft sprocket. If reusing timing belt, ensure reference mark on timing belt aligns with the reference mark on camshaft sprocket. Ensure tension exists on timing belt between the crankshaft and camshaft sprockets.
CAUTION:DO NOT rotate crankshaft counterclockwise, as viewed from timing belt end of engine.
9.Loosen No. 1 idler pulley bolt 1/2 turn. Rotate crankshaft pulley 2 full revolutions clockwise from TDC to TDC. 10.Ensure timing mark on crankshaft pulley aligns with "0" mark on No. 1 timing belt cover, and hole in camshaft sprocket aligns with alignment mark on camshaft bearing cap. See Fig. 2 . If timing marks are not aligned, remove timing belt and reinstall. 11.Rotate crankshaft clockwise 1 and 7/8 revolutions and align crankshaft pulley "0" mark with 45-degree Before Top Dead Center (BTDC) mark on No. 1 timing belt cover. See Fig. 5 . 12.Tighten No. 1 idler pulley bolt to specification. See TORQUE SPECIFICATIONS . Install No. 2 timing belt cover and gaskets. Install and tighten spark plugs to specification. 13.To install remaining components, reverse removal procedure. Install all bolts/nuts on right (timing belt side) engine mount before tightening to specification. 14.On Camry, when installing control rod and bracket on strut tower and right (timing belt side engine mount, tighten bolts to specification in sequence. See Fig. 6 . On MR2, tighten engine
Hope this helps, don't forget to rate.
Lazaruselite
Feb 25, 2009 | 1993 Toyota Camry V6
I need instructions on replacing the timing belt
1. Remove the Alternator Belt.
2. Remove the Water Pump Pulley
3. Remove the Air Conditioner Belt and Power Steering Belt.
4. Remove the Crankshaft Pulley.
5. Remove the timing belt cover
6. Remove the timing belt tensioner pulley.
7. Remove the Timing Belt.
8. (If Replacing) Remove Idler Pulley.
Installation is reverse of removal. Keep a close eye on the timing marks on the cam sprockets to make sure you don't knock anything out of whack.
I would strongly recommend replacing the water pump while you are replacing the timing belt. (The water pump usually comes in the timing belt kit.) Otherwise you are going to have to do this all over again when your water pump goes out. Good Luck.
Nov 10, 2008 | 2004 Hyundai Tiburon
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
