Question about Texas Instruments TI-36 X Solar Calculator
Square root I have a problem that ask for the square root but some of the number are not whole numbers ex. 0.4053 I hot the square root button and it shows 0 but the problem answer is 0.636 can you tell me how to get this to square root a number that is not whole?
    Problem Solver:
  • 14 Answers
It may be that you have somehow changed to a 'mode' that only shows integer values.
Try pressing the green button, then 5, then 9. Then try the calculation again.
If this fails, you can use Google as a calculator - search Google for sqrt(0.4053) and see what happens.. :-)
Posted on May 28, 2010
How do i find the square root of a number on the casio scientific calculator
If, for example, you're getting the square root of 3 as the square root of 3, press the S-D button (just above the DEL) button to convert the symbolic result to a decimal result.
If you want all results to come up in decimal, press SHIFT SETUP 2 to select the LineIO mode.
Feb 03, 2015 | Casio fx-115ES Plus Scientific Calculator
Square Root Again
On a TI 36X Solar, you enter the number and press the square-root key.
If you're asking about some other calculator, please reply to this post and specify the make and model of the calculator.
Apr 16, 2014 | Texas Instruments TI-36 X Solar Calculator
30xiis decimals square root
In general you cannot. If the square root happens to be an integer (ex: SQRT (4)=2) or a rational number (SQRT(16/9)=4/3) you can convert from one form to the other, but that is the same as converting from a decimal to a fraction.
However you can never convert 1.414213562 (the first 10 digits of SQRT(2)) into the radical SQRT(2). The reason is that root here is an irrational number: its decimal representation is endless and not periodic (non repeating).
Nov 17, 2013 | Texas Instruments TI-30 XIIS Calculator
How do i find the square root using TI30XA?
The square root button is the button to the left of the division button and to the right of the square button. So enter the number first, then press the square root to find your answer.
Mar 03, 2011 | Texas Instruments TI-30XA Calculator
I cant figure out how to get the square root of a negative number
The square root of a negative number is an imaginary number, and the TI-30XA does not deal with imaginary numbers.
However, the square root of -x is equal to i times the square root of x. So, to calculate the square root of -4, for example, press 4 square_root = and read 2. Thus the square root of -4 is 2i.
Oct 07, 2010 | Texas Instruments TI-30XA Calculator
How to calculate a square root number after pressing the 2nd button? For example, one of the problems i was asked was, 105625 all in square root by pressing 2nd, x^2 105625) and enter. But I cannot find...
Are we discussing squares or square roots?
The square root is the 2nd function of the multiply key.
There is no square function on the keyboard. Instead, simply raise the number to the second power using the ^ key just above the divide.
Sep 04, 2010 | Texas Instruments TI-89 Calculator
How do i do a number 'to the power of 1/2 or 2/3? cheers Brad
Power 1/2 is the same as square root: You can use the square root key to the left of the square key.
Similarly power 1/3 is the cube root. You use the [SHIFT][Square root] key sequence.
Power 2/3 is the square of the cube root, or the cube root of the square.
More generally, you can use the universal power key, marked with X with a raised white rectangle. It is between X square and log.
Ex: Calculate 15^(2/3)
15 [X with raised rectangle] 2 [/] 3 [)] [=]; the result is 6.082
The last parenthesis closes the left parenthesis introduced by the calculator.
Alternatively you can use the cube root and the x-root selections available under the MATH menu.(selections 4 and 5)
Mar 14, 2010 | Casio FX-115ES Scientific Calculator
How do you tak the square root of 64 or the 4 root of any other #
Hi shiny_diamon
Here is a picture of the powers and root functions of your calculator.
1.To calculate the cubic root of a number you use the key combination shown on line 5
Ex: Cubic root of 27
27 [2nd] [3 root x] [EXE]; Should get 3
2. You can use the general root key on line 7 [2nd][x Root y]
Ex: Cubic root of 125
125 [2nd][ x Root y] 3 [EXE] Should get 5
(-125) [2nd][x Root y] 3 [EXE]; Should get -5
3. You can also yse the general power key on line 6: [Y to x], but the degree of the root is entered as a fraction 1/3
Ex: cubic root of -125.
(-125) [Y to x]( 1/3) [EXE]; You should get -5
4. The [Y to x[ key is the one you use to obtain all other roots fourth, fift, tenth, n-th.
Ex: Fourth root of 256
256 [Y to x] (1/4) [EXE]: You should get 4
5. To extract the squqre root of a number you can use the key on the 3rd line [root x] or the general power key on line 6 with exponent 1/2
Exemple square root of 256
256 [Root x] [EXE] should give you 16
256 [Y to x] (1/2) [EXE] should give you 16 also
Hope that helps.
Nov 08, 2009 | Texas Instruments TI-30XA Calculator
How do I do square roots?
if there is a square root symbol on one button than use that.
punch in your numeber en then that button to derive result.
On a Casio you have to invoke the function call first because they have shared buttons.
May 07, 2009 | Texas Instruments TI-30XA Calculator
Texas Instruments TI-36 X Solar Calculator Logo
88 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
