Question about Samsung WEP200 Headset
Phone does not detect headset
Phone does not detect bluetooth headset
    President:
  • Samsung Master
  • 1,118 Answers
Put your headset in pairing mode first. Turn it off. Then, press and hold the MFB for some 8 seconds, until the indicator light is steady blue. Then, make your phone's bluetooth application search for new devices. Your headset should appear on the phone screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset's indicator light should flash rapidly 10 times, and enter the stand-by mode (light flashing every 3 seconds). The pairing procedure should be done only once. After any two devices are paired, just by bringing them within 10-feet from each other should suffice to have the bluetooth link done. Otherwise, a simple press on the MFB should do.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Hope you are able to pair your headset with your phone.
Regards, Carlos
Posted on May 28, 2010
    Champion:
  • 274 Answers
Good answer.
electronics wholesale
Posted on Nov 07, 2011
I need help pairing my B250-XT bluetooth to my Iphone
Eileen,
There are 2 parts to bluetooth. Step 1 is pairing. You need to set the phone AND the headset to detect each other (pairing mode). The phone is the easy part - it will tell you on the screen that it is searching for the headset. The headset has a specific way to put it in detect/pair mode. Sometimes it is holding down the power button for 5 seconds or longer. When the phone detects the headset, it will ask for the password and allow you to name it.
Sometimes, the phones already try the default 0000 passcodes and connect automatically.
Step 2 is connecting to the bluetooth device.
If you are connected and can make and receive calls, you don't need to do anything anymore.
Best of luck.
Feb 12, 2014 | VXI Corporation Blueparrott B250-XT...
I cannot pair my nokia e63 with genius bt-03i. seems the phone can't sense the signal from the headset or either the headset is not transmitting bluetooth signal
Make sure the blue-tooth headset is charged
Make sure the phone is set to automatically detect new blue-tooth device.
On the headset, press the power key for five seconds until the RED light blinks quickly.
Phone should detect headset within 10 - 30 seconds. It should eventually say BT-03A then ask for aOnce it does, type 0000 into the phone when it asked for a device ID.
May 05, 2011 | Genius BT-03A Bluetooth Headset
Connect to phone, procedure to connect to phone (bluetooth)
To Quick Pair this headset with a phone:
1. Turn on the phone, and enable bluetooth on the phone.(See specifics your your particular handset)
2. With the Plantronics turned off, press the call button for 4sec until the light flashes blue.
3. Let go of the button, the Plantronics will be in pairing mode, flashing red and blue.
4. On your phone, goto the bluetooth menu and select to ADD A DEVICE, or SEARCH/DETECT.
5. On the Phone select the "220Plantronics" device that is listed.
*Assuming your headset was already in pairing mode when you told the phone to detect it.
*If it took you over 30-60sec to do the process and you dont see the device, turn off the headset,
and restart from step 2.
6.The Passkey is 0000 when the phone asks for it, the headset will flahs blue when it is fully paired.
7. Once paired, you will only need to turn on the headset to reconnect, assuming your phone has bluetooth turned on and you have not cleared of disabled the headsets it is paired to.
Mar 01, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Bluetooth connection
Ensure that your phone is switched
on and the headset is switched off.
2. Press and hold the power key until
the green indicator light starts to
flash quickly.
3. Activate the Bluetooth feature on
the phone, and set the phone to
search for Bluetooth devices.
4. Select the headset from the list
Feb 09, 2010 | Nokia BH-208 Wireless Headset
User manual for LG HBS-110 bluetooth headset
To pair the headset with your phone:
Turn on the headset. Then turn on bluetooth in your phone and search for bluetooth device.
When your headset is detected, just select it and follow onscreen instructions to pair it with your phone.
Jun 08, 2009 | LG HBS-110 Wireless Headset
My new phone can't even detect this plantronics
The sciphones have a VERY SHORT area to use bluetooth devices. I have contacted numerous companies about this. Mine works, but I need to have my sciphone on my shoulder while I am using the bluetooth headset. This sucks, but so far that is the only way I have gotten mine to work properly. Hope this info helps a little.
Apr 23, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Activating the buetooth function.
You have to "pair" your bluetooth device with your phone. This is just a fancy way of saying "sync" with each other. Check your bluetooth headset instructions on how to do this.
I am using a Motorola H700 Bluetooth Headset. To "pair" it with my phone I have to hold down the call button on the actual bluetooth headset itself while the headset is turned off. This puts the headset in "pairing" mode so its ready to detect any phone that wants to sync with it.
Then I have to go to my actual LG CU400 and enable bluetooth settings. Next, go to "Device List" settings and select "new". The phone will scan for the headset. Once the phone detects the headset it will request a numercial passcode. Your bluetooth headset instructions should list this passcode. Enter the passcode and the phone and headset are now connected! I hope this helps. Good Luck!
Jan 05, 2009 | LG CU400 Cellular Phone
Cannot pair Nokia N70 to Jabra BT150 bluetooth headset
turn on cell phone. activate bluetooth. press right button to search for bluetooth devices. Then press the on button and the volume UP button at the same time on the Jabra headset. The cell phone then finds the device. put in the password/pin (usually 0000). and voila! it works
Dec 07, 2008 | Jabra BT150 Wireless Headset
Bluetooth ear set not being detected by new phone
ok, thanks.
Found the problem. As always "Read the instructions first!"
Bye
Nov 16, 2008 | Jabra Bluetooth Headset with Adjustable...
Plantronics bluetooth
you have to first put bluetooth headset in pairing mode by holding the phone hook button down until blue indicator on headset goes solid blue not flashing then set your phone to find bluetooth device by looking under your phones menu and look under bluetooth or connections make sure to turn on bluetooth function and choose find or add device phone will detect bluetooth device and will display the type of device on your phones display tell it to bond or connect once you select yes thats it the bluetooth headset will start to flash and its ready to go.
Jan 14, 2008 | Plantronics 510 Voyager Headset - PLN-510...
Samsung WEP200 Headset Logo
728 people viewed this question
Top Samsung Radio Communications Experts
Michael Vincent Cruz
Ed Nelson
Ed Nelson
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
