Question about Metz 58 AF-1 FLASH f/NIKON TTL Flash
Metz p76 or p50 battery pack any ideas of the number of batteries in the unit and the voltage configuration for the red, hite and black wires
  • 2,100 Answers
Http://www.flickr.com/groups/strobist/discuss/72157602956972285/
I found this discussion going on, but I couldn't find the voltage listed anywhere. These guys are rebuilding their batteries, 7.2 was the common voltage, but the generator makes 350v at .7 mA or 18 V at 50 mA. I'll let you check out the site. Hope this helps. One expensive battery!
Posted on May 28, 2010
Metz CT-4 flash gun overheated on the shaft the plastic casing overheated and melted the plastic on the handle grip I opened it up and noticed the wires inside were completely Melted.
Unfortunately, from your description, the flash is completely done for - while a repair may be possible, I doubt if it would be economically worthwhile. Replacement is probably the only answer.
What may be more important is to find out why this occurred - is it down to the charger, the batteries or an internal problem with the flash ? Were the batteries those supplied by Metz, or a different make ? If they were Metz ones, then maybe you should inform the manufacturers, to help others avoid this problem, and you might get a replacement flash if it is a manufacturing problem.
Jan 13, 2016 | Metz Cameras
Have to manually reset constantly the Metz 76 MZ-5 with SCA 3202 unit.
ya you can try the Metz p76 battery pack this will overcome the problem
May 16, 2008 | Metz mecablitz 76 MZ-5 TTL Flash
Any idea where I get a replacement charger for a Metz60CT4
EBay, if that's what you want. The metz "chargers" are just 7 volt ac transformers - they supply 7 volts to the battery pack which has the actual charging circuit in it. I haven't pulled one apart yet, but I'm guessing they're very rudimentary chargers. Depending on what you're using for a battery you might want to use a modern external smart charger. I use $20 AGM batteries from batteries plus (instead of the $80 metz batteries) and use an external charger from WallMart on them. It's quick, lets me see the current charge state, won't overcharge the battery, and works on my car and boat batteries too.
Jan 24, 2012 | Metz Mecablitz 60CT4 TTL Flash
I didn't take note of how the wires were connected to the RT1250 battery pack in my Belkin 900VA when I took them out to order replacements. Can anyone tell me the correct configuration? Thanks!
The two batteries are taped together with terminals and labels facing out. The jumper wire goes red(+)[battery1] to black(-)[battery2] on one side of each battery. This is a series connection making the total voltage 24v (12v+12v). Do not connect in parallel, the voltage will be too low and not charge. Do not connect the jumper to (+)&(-) of same battery, you could start a fire.
Nov 05, 2009 | IBM Belkin Enterprise 900VA (31P7076) UPS...
Metz Mecablitz 60CT4 TTL Flash Questions
How old is that Flash?
In my opinion, battery is dry and flash circuit is OK.
Dec 30, 2008 | Metz Mecablitz 60CT4 TTL Flash
Metz 45CT-4 power output
Have it serviced, or sell it. The culprit of this malfunction is either a faulty quench capacitor, of high capacitance and voltage, but small physical size, or a thyristor. Both are made of "unobtainium", can only be cannibalized from organ donors.
Apr 13, 2008 | Metz 45 CL-1 Flash
Metz 60 CT4
The Metz 60CT-4 uses Accu 60-38 4.5Ah @6V Pb battery.
Charging system is difference from NiMH battery.
Beside the voltage is only 1.2VDC per cell on NiMH battery.
Four cells will have a total of 4.8VDC.
If you got five (5) cells: 1.2 X 5 = 6.0VDC. Do not charge these cells with Metz. Use NiMH Charger for NiMH battery.
Alexander
atdlee@netzero.com
Nov 12, 2007 | Metz Mecablitz 60CT4 TTL Flash
Metz 45 ct5 flash battery pack wiring diagram
You can rig that fella up for a better power.
atdlee@netzero.com
Oct 23, 2007 | Metz 70 MZ-5 TTL Flash
Open Questions:
Metz 58 AF-1 FLASH f/NIKON TTL Flash Logo
425 people viewed this question
Top Metz Cameras Experts
bhargav
TimHu
Level 1 Expert
Are you a Metz Camera Expert? Answer questions, earn points and help others
