Question about Nu Mark Numark Cd-Mix-2 Dual CD Player/Mixer Combo - Good CD Player
Numark Mixer 4 channel mixer with pdl I have good out put until I plug in th second main out it doesn't matter which one then the volume is reduced greatly if i use the pan knob right or left I get better bass response but then is seems to be only that one channel
  • 4,234 Answers
This sounds like someting is out of phase. Can you describe all of the connections you have to the amp and speakers. Double check them as well to be sure that the positives are connected to the same terminals on the amp and speakers. If that is OK, we'll start looking inside the mixer.
Dan
Posted on Apr 07, 2008
SOURCE:
How to get sound from a nady audio 4130 mpm 4 channel power mixer
First, plug it in. Next connect the speakers. Center all eq controls both master and channel. Turn off any reverb or effects. Turn the master volume 1/2 way up. Plug a sound source into channel 1 wiyj the channel volume all the way off. Turn on the amp. Slowly raise the channel volume until you heat output. If you get nothing, it's broken.
Nov 10, 2016 | Nady Systems Music
PLEASE PLEASE a million times what makes my NUMARK IM9 DJ MIXER to sometimes play only one channell .I would really appreciate your help in this regard
If it's not the cables that you are using, it could be a number of things. Bad solder connection or corrosion on one or more ribbon cables. Maybe a weak return contact on a 1/4 inch female jack. Try putting a signal into the mixer and then inserting a male 1/4 inch plug into the different jacks to find out which jacks disconnect the signal when inserted. Even when they are not used these jacks tend to become slightly corroded and the signal is lost. You can give the jacks a burst of contact spray and 'work' a male plug in and out of the jack a dozen times.
Apr 02, 2015 | Numark IM9 4-Channel Mixer and iPod Dock
Mic feedback with numark c3fx
Feedback occurs whenever a microphone is being amplified, and it picks up its own signal above a certain level. Unfortunately, there's no way to reduce this possibility using just the Numark C3FX - you can only turn the microphone level down. The only way to reduce feedback through a speaker system is to use a graphic equalizer. Here's a good resource for how to do that: http://rfmedia.hubpages.com/hub/Controlling-Microphone-Feedback-with-a-Graphic-Equalizer
Nov 07, 2013 | Numark C3FX 4-Channel Rack Mixer With...
I HAVE A NUMARKKMX01 MIXER WHEN I PLUG THE RED RCA JACK IN TO THE MIXER I GET A LOUND HUM
What is plugged into your Numark mixer when this happens? Try disconnecting ALL audio inputs to your mixer, turn mixer volumes to zero and see if the hum is still present. Adjust the volume and check if the hum you mentioned returns. If it is still heard, try new cables between the mixer and amp...if not then start reconnecting inputs until the hum is heard again. It's a process of elimination but not that difficult to find the source of your problem.
Oct 31, 2012 | Numark Industries Numark DM 1200 Mixer
Non of the right side outputs work on the second channel I've tried the rca main and record and eve the 1/4
I do not know this mixer but it is possibly the pan control, it may simply be adjusted to one side. It sounds like the mixer failed.
Jul 03, 2012 | Numark Dxm06 2–channel Digital Tabletop...
We have a pmp6000 mixer hooked up to our ep 4000 and b1800 and b2520,it seems we can only hook up the amp to the mixer into either mono's 1 and 2 or the main 2 however not in main 1 with full...
MAKE SURE the cables you plug into 1/4 inch mains are TRS plugs, and not mono cables (TS). The main output 1/4 inch jacks are TRS balanced outputs and if you plug mono (TS) cables that shorts out the ring connector reducing the power by 6 Db. USE ONLY TRS balanced cables for interconnects !!!! Also read my tip on Fixya regarding PMP mixers. If you use 1/4 inch SPEAKER cables or adapters, if you short the SLEEVE of channel A output to ground you can pop the channel A amp. The TIP of channel B is the hot BUT the SLEEVE of channel A is the HOT. The ttip I posted explains why this is and it isn't mention in the Behringer documentation.
Aug 06, 2011 | Behringer EUROPOWER EP4000 4,000-Watt...
I have a Phonic Max 2500 amp and use a Numark 2 channel mixer with CDN 22 mK4 Dual CD. Just in past wekk I've been unable to fade out the track playing oin either side of the mixer (you can still hear...
If you have fader capabilities...and there is still signal "leaking" through...you may try reducing your input gain on each channel of your mixer...as well as make sure you have a good ground connection between your components.
Jun 19, 2011 | Phonic MAX 2500 Amplifier
When setting up a sound card to my m4 numark 3 channel mixer do i have the switch to phono or line
"PHONO" is ONLY for an old school turntable that would require a PHONO preamp, so that leaves, uh, LINE.
It's more than a matter of gain as Phono cartridges require special equalization to restore flatness to the sound recorded in a vinyl groove.
Mar 17, 2011 | Nu Mark Numark Dm3050 3-Channel DJ Mixer...
How do I connect my samson amp to my samson MDR10 mixer?
on the mixxer, use the "mix" "L" and "R" outputs. use 1/4 inch instrument cables, and connect the mox L and R to the amp's "channel 1" and "channel 2 inputs". always turn the mixing board on first, and the amp second- when turning off turn off the amp first, and turn off the mixer second. start with the mixer levels at the lowest, with the amp levels about 1/2 to 3/4 up. slowly raise the mixer channels first and then the mixer main volume until you have an adequate volume.
Mar 09, 2011 | Samson SX1200 Amplifier
Numark
You need a new adaptor...the wires have lost their connection in the cable or plug which isnt user servicable
KK
Aug 29, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
Nu Mark Numark Cd-Mix-2 Dual CD Player/Mixer Combo - Good CD Player Logo
53 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
da surgen
 Ian Kayhan
Ian Kayhan
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
