Question about Nokia E71 Smartphone
So;ve my phone problem
My e71 camera saying format not supported and the memory card not reading in the phone
    Problem Solver:
  • 5 Answers
Maybe you should try to chage new, m.c or either,format ur fo.
Posted on May 28, 2010
My camera says the memory card is locked and memory card error appears when I turn on the camera. I've read that I have to format the card, but won't the photos be destroyed? How can I get my pictures
There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it. DO NOT format the card until you've BACKED UP your files from it (typically to a PC or USB drive (stick or external hard drive).
Nov 18, 2011 | Canon PowerShot SX130 IS Digital Camera
Coolpix s8100 technical support my camera dropped and broke so I was given a replacement. When I insert memory card from other camera and try to take pics, a message reads, "file contaisn no image...
First, get a card reader (they're very cheap) and use it to download the pics from the card. Then, re-insert the card into the camera and go into the menu and find "format"....follow the on-screen instructions to completely erase the card and optimize it for your new camera.
Oct 15, 2011 | Nikon COOLPIX L18 Digital Camera
I just opened a brand new SD card and tried to use it with my P850, but when I insert the memory card it says "Memory card is unusable. Insert new memory card." I've tried formatting and...
If you just purchased this camera, you can try phoning place of purchase or make a trip there. It sounds as if the software in camera may be messed up.
Sep 18, 2011 | Kodak EasyShare P850 Digital Camera
When I try to use my e 71 camera. it says : feature not supported. How can I fix this problem
Remove your memory card, do a backup of all your contacts and data, and then format it.
After doing the above, type: *#7370#
This should solve the problem. If it persists, try a firmware update using Nokia Software Updater.
If that fails, then its time for a dealer visit, its a hardware problem then.
Mar 13, 2011 | Nokia E71 Smartphone
When I want to use the camera it gives me an error which says camera in use by another application.
The phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation.
http://www.blogsdna.com/2278/how-to-format-nokia-n72-n73-n81-n95-nseries-mobile-phones.htm
Feb 24, 2011 | Nokia E71 Smartphone
How is format e71
LET ME SAY THE WAYS TO FORMAT
1.THE PHONE MEMORY
you cannot directly format the phone memory but you can only restore the factory settings . the option is available at phone management settings
2.TO FORMAT MEMORY CARD
select mem card .click on options. format option is available.Click on it.Format is done in few minutes.
NOTE:::::back up important contents on your PC
Dec 13, 2010 | Nokia E71 Smartphone
I keep getting the error msg memory card cannont be read
Your camera is only supporting: SD/MMC up to 1 Gigabyte
The card that you currently have might be high speed. All should be sorted if you change the SD card to the supported MMC SD card up to 1G. There is a lever on the SD card this one might need to be changed.
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
Jan 19, 2010 | Kodak Easyshare C190 12MP Digital Camera...
Memory corrupted
Same thing happened to me too. I formatted it and it is still in my E71. Try formatting it thru your PC.
Aug 24, 2009 | Nokia N72 Cellular Phone
New memory card will not format
You are probably using a 4 gigabyte memory card and your camera will only support a 2 gigabyte card. Get the right card and it will format properly.
Larry
Mar 23, 2009 | Kodak EasyShare V550 Digital Camera
Bought a new memory card and camera wont read it
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Apr 20, 2007 | Sharp VE-CG40U Digital Camera
    Nokia E71 Smartphone Logo
    74 people viewed this question
    Top Nokia Cell Phones Experts
    270rexton
    270rexton
