Question about Garden
Start rope won't pull
Starter rope won't pull. when pulled does not move.
  • 1,305 Answers
Remove your spark plug and attempt to pull it thru without the plug. If it does pull thru, continue to pull it thru several times.
You may want to then clean the old fuel out of the tank and carb and replace with a fresh fuel/oil mix. It may have got contaminated with water.
If for some reason, you cannot pull thru with the spark plug out, spra some lube in the spark plug hole and let it soak a bit and then attempt to pull thru again after a good soak.
then replace the spark plug (with a new one) and check your fuel lines to make sure they're clean and not cracked and you should be good to go.
Posted on May 28, 2010
How do I start a weedeater fb25?
Press primer bulb 6 times
Move throttle lever to start position
Move choke lever to full choke position
Pull starter rope sharply until engine attempts to start, but no more than 5 pulls.
Move choke lever to half choke position. Pull starter rope sharply engine runs. If engine hasn't started after 5 pulls, repeat all steps above.
After warming up for 10 seconds, move choke lever to run position.
Manuallib.com has a manual for this model available for free download
Oct 20, 2014 | Weedeater Garden
I have a 3hp briggs & stratton//the pull rope pulls freely//it does not engage the engine and turn the engine over
You probably need to replace the starter recoil. This is not a very expensive fix. Just be aware that this problem is usually caused by having to pull the starter rope excessively because of some other starting problem. Once you replace the recoil, keep your engine running properly.
Sep 07, 2014 | Garden
Starter cord will not pull
The pull cord or rope works on a tight spring just under the cover that the rope is in. Usually three to four small bolts on the edge of the cover to remove to repair/replace either the spring or the rope. First I would try to turn the motor manually with your hand on the flywheel, it should move around either direction freely with no effort. If it does not the motor itself maybe stuck not the rope. Then you have a seized engine and a different problem to deal with.
Dec 27, 2013 | Husqvarna 41 141 41 136 36 Recoil Pull...
STIHL WEED TRIMMER
With the plug removed the starter should pull very easily. When trying start did the cutter head try to spin? If yes clutch springs may need replacement
Jul 24, 2013 | Garden
Tiller won't start
Best advice is to spray some ether in the carb, if that doesn't start it up, then check the spark plug.
Mar 17, 2013 | Mtd Garden
Starter rope replacement
recoil spring has slipped out of the hole.pull your starter rope out of the wind up mechanism, insert the spring latch on both ends and put back into housing. with a piece of 3/4 square stock or something the will fit mthe hole start to wind the mechanism spring up tight. with apair vishgrips lock it down so it does not move. insert your starter rope anr release the visegrips. the springwii recoil and pull the rope in.cut off excess rope. good luck
Oct 17, 2012 | Little Wonder 6032 10 Inch Pro Lawn Edger,...
Starter rope hard to pull on mantis tiller
Sounds like your engine may be seized up. Mine did the same thing and I had to replace the block. If any dirt gets past the air cleaner or if your fuel mixture isn't right it won't take long to lock it up. If you need info on where to find parts, let me know. Good luck.
Jun 20, 2012 | Mantis 2-Cycle Tiller
Gx160 pull cord rope broken
1. Buy a starter repair kit or get five feet of nylon rope similar to what was in the starter from a Lowe's, The Home Depot or the like.
2. Remove the three bolts holding the starter on the motor and remove any remaining rope on the pulley.
3. Line the hole in the pulley up with the hole in the starter housing and thread the rope through both.
4. Tie a tight knot in the end of the rope and cut the tail off so it won't interfere with motor but not so short the knot comes undone.
5. Thread the other end of the rope through the t-handle and tie a knot in the very end so the handle won't come off and the rope won't be pulled into the starter during the next part.
6. Pull the rope up between the starter housing and pulley and get the rope into the notch in the pulley. Turn the pulley clockwise with the rope in the notch to put tention on the spring. Give it four turns.
7. When the notch gets back to the hole in the housing, hold the pulley and pull the rope back into place from outside the housing.
8. Let the pulley turn slowly so it retracts the rope.
9. You want four windings on the pulley and the t-handle to be held against the housing. If you don't get four windings on the pulley, give the pulley another tension turn (Step 6). If you have four windings and the t-handle isn't held against the housing or you get more that four windings, shorten the rope at the t-handle.
10. Reinstall the starter and you will be back in business.
Mar 06, 2012 | Honda Garden
Replacing starter pull cord on Cub Cadet mower
1st get same size cord 24" long .remove pull start assy. remove old rope.burn & smash ends flat of new rope(helps it go thru holes on pulley & cover easy). tie small knot in 1 end of rope. unwind spring pressure like if rope is pulled all the way out when starting.align holes in pulley & cover .fish rope thru holes start on pulley side, out thru cover so knotted end on pulley side.when ropes thru slip handle on .rewind spring will wind itself pulling rope in . your done
May 05, 2009 | Garden
Chainsaw won't start. Can't pull starting cord out
Try replacing the muffler. The baffle or something inside the muffler may be loose and when compression is put on the cylinder from pulling starter rope to crank over engine it will cause baffle to move over and seal off muffler leaving nowhere for compression to go. When the sparkplug is removed this allows an outlet for compression when starter rope is pulled. Hope this helps
Feb 24, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Garden Logo
145 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
