Question about Uniden Cordless Phone
"Line in use" on screen. can't call out or receive calls
All the phones have LINE IN USE on their handset screens. I can't call out and I get a busy signal when I try to call in. I have unplugged all the phones but they still don't work.
  • Uniden Master
  • 5,475 Answers
First you need to diagnose where the problem is. I like an old corded phone for this. Unplug the cordless phones and plug a different phone. What tone do you hear if any? Find where your phone service comes in and open that box. (If you are lucky, you can just unplug the cable that runs to inside phone lines and plug in an RJ-11 jack (that spare phone). What do you hear? Older service boxes need a special connector to test that line. They are available but expensive (Cyberguys.com for example); a service technician from your phone company will have the tool.
If you hear either nothing or a fast busy signal at the outside connection, call the phone company. (could be a crossed connection or anything else) If you get a regular dial tone there but not inside, it's an inside problem and you'll need to pay for a service call or find the problem in your wall. Check the jacks and any visible wiring (like in a basement) for damage.
I hope this helps.
(who has had several phone outages that gave line in use errors that were outside problems. The phone company service person solved the problem quite quickly. One was a crossed line at the road; another was after a lightning strike damaged a part of the DSL installation)
Posted on May 28, 2010
HaveBinatone Symphony 3325 triple. screen shows 1 new call. cannot listen to call or clear it cannot receive or send calls. can you find me the instructions to clear this please
Showing 1 New Call would mean you need to check the Caller Display Record by pressing the arrow pointing up marked "Calls". This is not related to not being able to make/receive calls. If the phone is ringing and displaying "Handset 1" then check line, if it says "searching" then you will need to register handset. Call 0845 345 9677 for more help.
Feb 24, 2011 | Cell Phones
I can`t make or receive calls from my handsets. The screen says check tel line. Ihave checked the connections & turned off the power for a few minutes
check your call barring and cancel it.
\go to settongs --> call settings --> call barring--> cancel call barrings
Feb 10, 2011 | Cell Phones
Stations don't ring even though day ring and night ring enabled.
Sounds like the ring assignmet programming has defaulted.( all lines ring at station 4 only)
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #62 the screen should say day ring assn
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
5) press # when finished with the line
repeat for each line
Jul 20, 2009 | Samsung Prostar 816 Phone
What do I buy to use 2line phone and separate fax?
You can buy a 2 line phone, but to use the fax/dsl line for voice, you will also need a line sharing device.
"The stick" is a good brand....
All it does is recognize if an incoming call is a fax or a voice call. If fax it would go to a fax port on the stick. If voice, it comes out the voice port which you can call on.
The same rules apply to this line....if something is using it, the next call will get busy......But now you could have the phone company "Hunt" your line 1 to line 2 (fax/dsl) if line 1 is busy.......hence...2 incoming lines....
Apr 14, 2009 | RCA 25201RE1 Corded Phone
I cannot use my phones since Saturday. The phone message on hand
try to perform a soft reset.
Using:
menu/settings/ restore factory settings.
Dec 22, 2008 | Uniden Cordless Phone
Busy signal, phone states ''line in use.''
Make sure the handset is set in it's cradle. But it sounds like some other device is on the phone line.
Nov 13, 2008 | Brother IntelliFax-2480C Fax
Toshiba Super G3, e-Studio 170F
Fax display screen always reads, "Auto receive". When attempting to fax, the busy light flashes. Busy light stops flashing for 30 seconds, then starts flashing again.
Above is the default settings for the fax.
NGB0 indicates signal error or line condition error.
U need to check the phone line. U can hook any single line phone to the phone line, check for tones without background noise.
Sep 10, 2008 | Toshiba e-Studio DP170F Plain Paper Laser...
RCA ViSYS 25450 cordless handset
Quickly, return this Phone is you still have a chance, my small business used this phone for EXACLY 2 years, and now all lines are DEAD, NOT A SINGLE ONE WORKING. LINE ONE AND THREE HAVE NO DIAL TONE EXCEPT EXTREMELY LOUD STATICS. AND LINE 2 AND 4 ARE TOTALLY MUTED.
A lot of my customers are complaining about not being able to reach me in my office.
Apr 10, 2008 | RCA 25450 4-Line Extended Range Multi...
Telephone connection problem with DSL
unplug everthing from all jacks in the house. call your # a couple of times. if the line rings, plug everything in 1 at a time, but call again after each hook up. if the line goes dead or is busy, that phone you just plugged in is the problem. [ a short in the phone, computer, answer machine, or any piece of equipment plugged into the phone line.] if the line is busy when everything is unplugged, call your phone company. there maybe a problem with your inside wire.there also maybe a box [called a nid] inside your basment/garage or on the side of your house, where you can plug your phone directly in, bypassing all the jacks in your house
hope this helps.
wg
Feb 13, 2008 | Lands Phones
No dial tone
The feature you are looking for is called "prime line" or "Line preference" but not "ringing line preference". It is not usually on by default on a multi-line business phone system. Your system can do this but I suspect it's a system programming feature and not something you can set yourself. You would have to have the phone system administrator make the change. Or you may pay an installation company to make programming changes?
Jun 01, 2007 | Mitel Superset 4015 Corded Phone
Uniden Cordless Phone Logo
231 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
