Question about Samsung HL-R4677W 46 in. HDTV Television
The three lights (timer standby and lamp) are blinking on the front panel of the TV. On start up, a high pitched whine is heard. there is no picture and no sound.
  • Samsung Master
  • 5,099 Answers
This indicates a bad lamp. Get a replacement (make sure to check your TV for the code and type - this is listed on the right side of the TV and on the lamp case). Contact the store or a Samsung Service Center and give them the lamp code. Turn off the TV at least 30 minutes before replacing the lamp to allow it to cool. Remember to handle the new bulb with care; fingerprints can shorten the lamp life. The cool down happens when the TV is plugged into a wall outlet; if it is plugged into a cable box it may not cool properly. You need a Philips screwdriver (the screw is under a rubber cap that just pops off) and gloves. Unscrew this screw then remove the lamp cover; it takes a bit of force. Unscrew two more screws (one on the right and the left). They will remain on the body of the lamp. Separate the lamp from the engine by holding the handle and pulling it out. Reverse the steps to install the new lamp. Align the lamp cover with the grooves and secure the screws. If the lamp cover isn't properly closed, the TV will not turn on. There is a protection circuit involved.
I hope this helps.
Posted on May 28, 2010
I have a Samsung HL-P5067W/HL DLP tv. When I turn it on cold the lamp light blinks on and off. The fan makes a high pitch sound a relay clicks the TV goes back to standby and the lamp light starts blinking...
This sounds like a lazy lamp--that is getting hard to start. Try a new lamp first. If you are inclined to do so--get a bard bulb and install in the old lamp housing and save some money. Get a real PHILLIPS bulb--it will last a while--compared to cheap generics that are good for maybe 6 months !!
Feb 18, 2014 | Samsung HLP5067W Television
Tip
Error code by led indicator samsung SP67L6HX1X
<img src="mas_baz.jpg" /><br />There are three LED indicators. LAMP, TIMER, STANDBY/TEMP. Each Led or combination leds indicated problem.<br /> <ul> <li>LAMP blinking : The picture will automatically appear in about 15 seconds.</li> <li>TIMER and STANDBY/TEMP blinking : A cooling fan inside the set is not operating normally.</li> <li>LAMP and STANDBY/TEMP blinking : Lamp cover on the rear of the set is not properly shut.</li> <li>STANDBY/TEMP blinking : Check if the ventilation hole on the rear of the set is blocked, because if the inner temperature is too high, the power will shut off.</li> <li>All LED blinking : Lamp may be defective.<br /></li></ul>It takes about 30 seconds for the TV to warm up, so normal brightness may not appear immediately. The TV has a fan to keep the inside lamp from overheating. You'll occasionally hear it working.<br /><br /><br />
on Mar 29, 2011 | Samsung HL-R6167W 61" HDTV
Was watching TV, heard a pop and the screeen went black. Now when I turn it on, the pwoer light blinks green but their is no picture or audio. The light then starts blinking red
Is is standby light blinking red or any other light? Let me know how many times red standby light blinking after three seconds long pause to provide you helpful info.
It seems pop sound was due to broken lamp, please check lamp inside tv and if it is broken, replace it to solve tv problem.
Hope this will help.
Thanks.
Mar 09, 2011 | Sony KDS-50A2020 Television
Hlp 5063w on off front button flashing lamp then stanby..hear sound no picture.. shuts off then comes on.
If the lamp and standby lights are both flashing and the timer light is off, check that the lamp cover on the back of the TV is properly positioned in the groove and secured by the screw. Take it off and check that the screws that hold the lamp itself are secure. There is an safety feature that keeps the lamp from turning on when the lamp cover is off.
If the three lights (timer, lamp, and standby) are blinking, then the lamp needs to be replaced. If the timer and standby lights are blinking and the lamp light is off, then a cooling fan isn't working. When only the standby light is blinking and the other lights are off, the unit is overheating and a ventilation area may be blocked.
I hope this helps.
Sep 30, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
I own a Samsung HL-R5067W 50'' DLP. Set is about 3 years old. Recently I heard a loud pop while viewing, picture distorted, but never went blank. I turned set off. When turned on again a loud whining noise...
Check your color wheel. There is a DIY guide for replacing the color wheel. Mine did the same thing yours is and my color wheel was all busted up. Unfortunately after replacing the color wheel my set continues to do the same thing, but this could mean I need to replace the ballast as well.
Sep 20, 2009 | Samsung DLP HL-P5663W 56" TV
Whining Noise and Image Problems
You better to check the color wheel or Lamp ballast.
Normally, the noise comes from color wheel.
Jan 17, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
TV and Vedio-Projection televisions
what i would do is crack into the tv and watch the individual parts being careful not to unplug anything while you take the back panel off.....turn it on and see what happens. let me know what happens
Sep 30, 2008 | Televison & Video
3 blinking lights and no picture
The whine or squealing you hear is either the color wheel or fan. To determine which, when the noise is heard from the set, turn it off and listen carefully. If squealing stops immediately then Tthe fault is the color wheel, not the fan. And sounds like that are generally the color wheel. A new color wheel is Samsung p/n# BP96-00250A for this model. Vance Baldwin carries them for $97.20 plus shipping. https://www.vancebaldwin.com Logon as guest, select parts and copy past the above part number in without any dashes. Good luck... Bill
Jun 08, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HL-R4677W 46 in. HDTV Television Logo
96 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
