Question about Samsung HLR5067WX 50" Rear Projection HDTV
Tv wont turn on.
Problem started with a clicking noise and the normal tone it makes when first turned on. Picture and sound did come on in a few seconds. Then one day i tried to turn it on and it did not make the clicking noise, just the normal tone it makes when turned on, but no picture or sound came on. It seemed like it was trying to recycle the start up after a minute, with the same normal tone it makes when you first turn it on ,but then after a while the lights just blinked on the power switch. No picture, no sound.
  • Samsung Master
  • 12,061 Answers
Http://www.my.electronicshelponline.com/Samsung_65.html Above is a service manual, also link below, www.scribd.com/.../Philips-DPTV400-TV-Projection-Training-Manual
With this symptom, it is impossible to tell what the exact "Cause" of this symptom is. The LED's do not tell us what is wrong, sometimes it may indicate the "Area" in your case it is the X board. BUT thats NOT where the "Fault is" thats just the part that is affected. Most likely, you issue involves your Power Supply, this is shutting down for safety reasons. These days unlike the "Old" analogue days it just isn't realistically possible to fix anything but the most basic of problems with todays sophisticated units. This is quite apart from the Safety aspect, any unit that can cause a firs or have an explosion, or both, is NOT to be treated lightly, and and the repairer, of the unit is legally responsible, another thing to think about. Also, one must have tools, a Multimeter, a soldering iron, a deslodering iron, an oscilloscope, a signal tracer, tools, and most important of all, a Service Manual, without which, there is no way to even begin to understand and fix it, and more importantly Program it, AFTER it has been fixed. As these days a TV, is a PC, a Tuner, and an HDTV Monitor, and more, all in one. in the "old" days TV"s were more, rudimentary, and built to last for 20 years, and a "Parts" supply was set aside. They usually used to fail for only a few reasons, and they while still difficult, were less difficult to repair. Electrical knowledge was transferable, and they could be and would respond to, This-is-the-symptom-This-us-the-Fix, But that no longer applies, as now, it can be a Fault on I squared Bus, or "Sensor" failure, or it simple may have "Crashed" just like a PC, It could be a Diode go bad, and that will stop the whole thing. You see, in the day, the sets were Very "Fault Tolerant" because they were Analouge, and a faulty, component, or more sometimes, the set would always diplay something usually, and when they didn't it was one of anly a few things, sure there are always the horrid ones, and there are pleanty of those, but all in all it was quite easy. But with Digital Electronics, it either goes, or it doesnt, there are usualy few half measures. I mean thats the definition of logic either going or not. So it can take very little to completely paralyse a set, and generally give the only sysmptom, it can, by not working, usually No picture, or the like. So you, see the list is endless almost for any given SYMPTOM, as that is what is being seen, not the cause, as I keep going on about. Also any fault, usually involves the Power Supply, it is either the cause, the cause of the damage, or it is damaged. or ALL of them. Then after you have done the electronic repairs, you then must program the set to work, and align, and set up in general, any one of those settings missed or done wrong, back to square one. So, it is nearly always my professional opinion that one should always get a "Quote" form the manufacturers recommended service center, I cannot stress how important that last point is. It is even worth the cost of shipping. you see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace. Often my clients,do not go through with repair, unless it is moderate, but in some of the more costly jobs they see it, as do i, that a replacement, with a warranty, is a better option. As an aside here, one could then tear the TV down, and sell the Known Good bits. You'd be surprised who needs parts, i myself often must by from third party sources to effect a repair. So money could be recouped, somewhat,and help out someone else.
So, it is nearly always my professional opinion that one should always get a "Quote" from the manufacturers recommended service center, Samsung, in your case, please contact a local or head office and ask for a referral to an Authorised service center. I cannot stress how important that last point is. It is even worth the cost of shipping. You see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace. Often my clients,do not go through with repair, unless it is moderate, but in some of the more costly jobs they see it, as do i, that a replacement, with a warranty, is a better option. As an aside here, one could then tear the TV down, and sell the Known Good bits. You'd be surprised who needs parts, i myself often must by from third party sources to effect a repair. So money could be recouped, somewhat,and help out someone else.
Below is another training manual to help you understand. www.scribd.com/.../Hitachi-Training-Manual-Projection-Television-DLP-1
Random shut down help below.
http://www.ehow.com/how_5205699_fix-dlp-tvs-random-shutdowns.html Another rear projection training manual.
http://www.pdfee.com/consumer-electronic/training-manual-tvp-13-plasma-tv-grand-wega-projection-tv
Posted on May 28, 2010
Sony Trinitron tv wont turn on no picture just makes clicking noise
Short circuited component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 09, 2014 | Televison & Video
Three-year old 47" Samsung LCD. At first, some pixelation, usually correctable by turning TV off then on again. This situation lasted months, getting slightly more frequent each week. More recently, the TV...
1. the motherboard might be bad and you will need to replace it. 2. or The power supply is bad
Chances are if its making clicks the power supply is bad and you will need to replace it. Which makes sense because constantly powering the tv on and off will damage the power supply or possibly short out your motherboard. These things usually cost about 200 bucks to fix at a local tv repair store.
Sep 02, 2010 | Samsung LN-T4671F 46 in. LCD Television
The power button is flashing red...
It ur power board,Tries buy it replaced it ur self it pretty easy.
Nov 18, 2009 | Philips 50PFP5332D 50 in. Plasma...
Tv keeps switching on and off and will not stop
unplug tv for 2 minutes and plug it back in. problem should go away. if not, call toshiba.
Jul 22, 2009 | Toshiba 27AF41 27" TV
Tv wont power up makes a noise but no picture
Replace your STKS big black ics 392-020 go to 040s if 119s 150s go to 180s.
Oct 13, 2008 | Philips Magnavox 51MP392H Rear Projection...
Magnavox 27m53404/17 Picture went out
Hello there, I'm having a major problem with my TV, I have called all of the local TV repair shops and they all are the same, they want money money money before they will even speak with me about the problem I'm having. This is the only TV in my entire household for a family of 4 and we desperately need the TV in working condition for our kids. I don't want to have to put out $500 for another set if I don't absolutely have to.
The Problem...
About 3-4 months ago the TV when turned on, the picture would slowly come into view and be very scrambled and before the picture would come into complete view the TV power would shut itself off, but the power light would remain on. You can hear the "Click" noise when it would shut itself off.
2-3 seconds after it 'shut itself off' then the TV would make the "Click" noise (The same noise it makes when you first turn it on), it would make the "Click" noise over and over and over again but nothing would happen. So i would turn it off and on again and change the channel rapidly until after 2-3 minutes it would come into view and work.
So we decided to leave the TV on 24 hours a day. Then today we awoke and it was off and making the "clicking" noise over and over and over again but with no picture or sound. Now it wont even turn on/off it just sits there and goes "Click, Click Click Click" and doesn't do anything.
I described the problem as best as I can. Here is the TV information and specifications...
Philips 27 Inch Tube TV
Model Number... 27PT54 3S37A
Serial Number... 78438404
105 Watts
60HZ
120V
Date Code March 2003
Now that I typed the model number there are threads everywhere people saying the same issue exactly as me, I will read them but please someone tell me is there anything I can do...
Can anyone explain exactly what is wrong with the Tv and why it's doing this?
Also, what should I expect to pay to repair it?
Any information or help would be appreciated very much.
Thanks in advance,
Anthony
Just got off the phone with certified Philips shop...they said they will repair it for $100-$130 with a $25 down payment just drop it off and he will call me when its done. Does this sound like its worth it or a rip off?
Sep 07, 2008 | Philips 27PT543S 27" TV
No picture, sound, or response from button on a Samsung DLP TV
Same Same Here - SAMSUNG SUCKS!!! One day we lazy Americans will learn not to outsource so much and get back to good ole American Made.
May 28, 2008 | Televison & Video
Toshiba Plasma clicking noise
Check the fan, it may be dust or a bad bearing.
Oct 10, 2007 | Toshiba 42DPC85 42 in. EDTV-Ready Plasma...
Samsung DLP HLR5668W has mostly dark picture + grinding noise
Pix looks like a light pipe issue, inside the Light Engine. as far as the shutting down, could be a bad fan causing the grinding and when stopps the DMD turns the set off.
Jul 08, 2007 | Samsung HL-R5668W 56" HDTV
Samsung HLR5067WX 50" Rear Projection HDTV Logo
359 people viewed this question
Henry  Thomas
Henry Thomas
