Question about Olevia LT32HVM 32 in. LCD Television
TV says it does not support HDCP.
Had a thunderstorm last night and have not had cable since (unless I hook up using S-video or YPrPb. Have had it hooked up using HDMI for almost 2 yrs! What can I do?
UNPLUG ALL CONNECTION FROM DECODER EXCEPT MAIN CABLE SIGNAL UNPLUG POWER WITH CABLE ONLY CONNECTED RECONNECT POWER WAIT FOR CLOCK TO DISPLAY HDCP SHOULD BE GONE RECONNECT ALL OTHER CABLES
Posted on May 31, 2010
How do I get picture back on TV which was working the night before, which is hooked up to HD cable box, thru HDMI?
OS info is always helpful, if say you are running some type of nix, it's likely not getting recognized by xserver or if your running some version of windows your display manager has shut it down because of a resolution mismatch.
May 26, 2014 | Amstron Fujitsu LifeBook E390 Laptop DC...
I just bought my 42in last night and I attached my cable box to it, with a normal black coaxal cable and the red/white/yellow hookups. The only problem i have is the picture looks kind of grainy and...
Cable box have HDMI port,hook it up on a HDMI cable to the tv,will improve picture quality greatly.Tries HDMI cable to hook up the PS3 system and go in setup changes to HDMI setup will get HD format picture,will be very clear no more grainy and inconsistanty.
Feb 17, 2011 | Sansui HDLCD-4212 LCD TV
How to hook up yprpb
This is another way of describing Component Video (Y usually a green colored connection, Pr usually color coded red, Pb usually blue). The device you want to hook up to the Emerson must have a component output.
The YPrPb needs three cables and does the video (picture). You will still need 2 cables for the audio (sound) and the they will be a white and red normally. Don't mix up the red for the video with the red for the audio. If you do, the right speaker will have noise and the picture will be bad or gone. If so, switch them so the are correct and you should be fine.
Component video can handle HD.
Jan 19, 2011 | Emerson LC320EM9 32 in. LCD HDTV
I HOOKED MY PS3 UP TO HDMI LAST NIGHT AND NOW I WANT TO GO BACK TO AV CABLES AND IM NOT GETTING ANYTHING
when the system is in stand by hold down the power button for 15 seconds and it will do an auto - video reset to the used video component. same works if you want to go back to hdmi just hold it down again.
Jun 14, 2010 | Sony Playstation 3 (PS3) Console
Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Jun 16, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
No sound from hdmi cable
Go to the Sound settings in PS3 and be sure it's listed as HDMI and not Audio Video Cables.
Output on TV may be set to surround sound system? Powerd On?
May 25, 2009 | Sony Playstation 3 (PS3) Console
No HDMI Output thru' receiver
you most likley blew a fuse . take it to a repair shop it you live in an area that has lot's of storm activitey you might want to look in to getting serg protection on your elect panel to save repairing other thing's in your home. thank you please rate mee
Feb 12, 2009 | Pioneer Elite VSX-91TXH
Console will not work
you should never unhook or hookup anything hot. shut your stuff down and then plug unplug whatever it is you are doing
good luck cullen
Jul 28, 2008 | Sony Playstation 3 (PS3) Console
HDMI Cable problem
Well, first you might want to try another hdmi connection behind your TV.If it appears to have the same message,you need to check your TV setup and be sure the HDMI video is active.
Secondly,go with the recommendation of the set top box.You will use component video cable to connect from your set top box component video output(Y PR PB) to your TV (Y PR PB) and see if that actually work.If so,just use the cable box for the time being and call your cable company for another cable box to replace this one!
solutiondoct
Jun 13, 2008 | Samsung HP-T4254 42 in. Plasma Television
Olevia LT32HVM 32 in. LCD Television Logo
226 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
