Question about Royal 150MX Cross-Cut Shredder
Need a part for the jaws js1100 shreader.where do i get it?
    Genius:
  • 1,218 Answers
Contact Royal consumer Products at 1-800-524-0799 or Fax to 1-800-421-4832
Posted on May 28, 2010
My son needs to make jaws of life out of syringes, tubing and cardboard. How on earth do i do that
THE syringes act as the teeth of the jaws of life, the surgical tubing is used to hinge the jaws....fabricate some scissor like cardboard I am done with handles and there you have your Mock jaws of life
Mar 14, 2014 | Vehicle Parts & Accessories
Can a dentist treat a broken jaw?
There are some less severe cases of broken jaws that most dentists can treat although in most cases you will need to visit the emergency room of your nearby hospital.
Feb 03, 2013 | Health & Beauty
M1112 chuck .0045 off center
There are three possiblities: 1. dirt interfering with the jaw position or between the jaw and the workpiece - if you loosen, tap the jaw, retighten on your work and the result is repeatable, then this is not the problem. 2. the jaw itself needs to be cut, as you are doing - this will solve the problem and give you repeatably centering so long as 1 or 3 are not the problem. 3. The most insidious problem would be that the spiral groove on the back plate which is supposed to move the three jaws in harmony has a bad spot - this would give you inconsistent centering of the jaws at different diameters and could only be fixed by re-grinding that spiral groove (this would be VERY tricky to do yourself) or replacing the backplate.
good luck!
Jun 13, 2012 | Shop Fox M1112 Gunsmith Metal Lathe 2 Hp...
Have a Troy Bilt chipper/shreader model 47285. I
Taked the broken belt to the auto parts store for a replacement.
Jun 06, 2010 | Troy-Bilt ChipperShredder
PS60C-2 Shredder: Fellowes P50CM paper shreader motor runs but cutte...
One of the drive gears has stripped its teeth, usually caused by overloading the machine. These are personal shredders and parts are not available in my experience.Sorry.
May 03, 2010 | Fellowes Office Equipment & Supplies
MTD chipper shreader
Sounds like the carb is gummed up. Do a complete carb cleaning and see if it helps.
Jul 10, 2009 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Drive gear for staples shredder Model# SPL-770M is worn
is it the drive gear or is it that the shreader is dull that makes the shreader sluggish?
Apr 04, 2009 | Fellowes Office Equipment & Supplies
Blade gone south (shreader)
www.gopresto.com you can order parts here!
Please rate this FREE response!
Dec 07, 2008 | Presto SaladShooter Plus Food Processor
The shredder runs perfectley in the reverse direction, but does not run at all in the shredding direction
I have seen many shreaders that are caked with paper underneath the blades.
After you remove the power, turn the shreader upside down (if possible )and completely clean the area.
Make sure you use shreader oil after you clean it
Dec 01, 2008 | Office Equipment & Supplies
FELLOWS PS 65C SHREADER
There is probably astripped or broken gear inside the gear box.
Nov 05, 2008 | Fellowes Office Equipment & Supplies
Royal 150MX Cross-Cut Shredder Logo
54 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
