Question about Sony KDL60EX700 60 in. TV
No tv sound on satellite or blue ray player after hooking up wifi to sony hdtv but analog sound will play(wifi channels and vhs )
  • 178 Answers
Software update to Current Version 4.020.
Posted on May 28, 2010
  • Shukai Fung
    Shukai Fung Jun 04, 2010
    I am sure this is a helpful information, because this model just come to the market a couple of months, and sony update their software very often.
How do I connect Sony S590 3D Blu Ray to Analog TV & Sony DAV-DX255 Home Entertainment Center
It depends what connections the TV has. If it has HDMI sockets then you should be able to connect the player via one of them. The sound should be connected using an optical lead from the player to the Sony Center.
However you will not be ever be able to play a 3D movie till you have a 3D TV. It will simply not work.
So at the moment you have purchased a an expensive 3D player which can only play back normal Blu-Ray's and DVD.
Feb 04, 2018 | Sony BDP-S590 3D Blu-ray Disc Player with...
No Audio
cant use both hdmi and opti outs try sum setting in blue ray but u nee dto plug all blue ray dish directto samsung hdmi then 1 master digital out form tv to sterio digital i n ok tell samsung your output also
Jan 20, 2008 | Sony STR-DG510 Receiver
Can't get video on vhs sound but no picture, is it broken
I had the same problem, so I took it back to basics. Hooked cable into VCR/DVD player and another cable from player to TV. S cable too, plus red/white audio. Plays DVDs on AV1 and VHS on Channel 3 on TV setting.
Jun 30, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Sony RDR-VX535 I tried hooking it up to just a TV, no cable box or anything else. I put the 3-pin cable from the Sony's Output to my TV input (only has yellow and white on TV, no red). However, when I...
Red is Audio Right
White is Audio Left
Yellow is Video
You don't say what TV you have so it's impossible for me to guess what the connection it is that you are using. You will not see a signal on any of the channels you will need to select AV or Mode or Input or something similar on the TV
Jul 26, 2009 | Sony RDR-VX535 Player
DV220MW9 DVD/VCR: won't record video on VHS
your cable tv connect into dvd/vcr,video/audio out connect to av in your tv,solved
Jul 06, 2009 | Philips Magnavox DVD/VCR Dual Player
Emerson VCR/DVD player - can't get tv (cable tv) to play anymore
I have the same problem with my Emerson VCR. When the ADD button is flashing, just press the menu button to exit the menu. It will add. That's the only thing I know to do. Sometimes it works, sometimes it doesn't.
Feb 01, 2009 | Emerson EWD2203 DVD Player/VCR
LOST DIRECTIONAL BOOKLET & CAN'T GET UNIT TO WORK !
These players don't play through channels like the old school VCRs or some early DVD players.
This is either connected through your HDMI or component video cable input on your HDTV.
You need to toggle through your inputs on your TV to the proper one where your BD Player is connected through.
If you have it connected to an analog TV, then you need to toggle through your TV inputs as well. Usually called Video 1, Video 2, Etc.
Nov 23, 2008 | Sony BDP-S301 Player
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
Novice installing HDTV(Samsung),DVD(Sony) no pic on TV
Purchased a newer HDMI DVD player,(Sony)as well as found that I do need the video cables.Also found that I need to change the input to component on the DVD player by using a regular coxial to at least get a display from the DVD player had I kept the older one.
Oct 08, 2008 | Televison & Video
New dvd/vhs player but old tv
The easiest thing to do would be get a new TV plain and simple sounds as if you could use one n e ways. But first make sure you are hooked up through coaxal to the tv that will allow everything to run on channel 3. Let me know your current hookup.
Dec 24, 2007 | Televison & Video
Sony KDL60EX700 60 in. TV Logo
64 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
