Question about Sta Rite Sr333na Max E Therm Pool & Spa Heater Dual Electronic Ignition Lo Nox 333,000 Btu Natural Gas
Service heater light on - Sta Rite Sr333na Max E Therm Pool & Spa Heater Dual Electronic Ignition Lo Nox 333,000 Btu Natural Gas
  • 640 Answers
The users manual for these pool heaters is very comprehensive with troubleshooting. Try starting there. There are some very specific questions that you need to be looking at the heater to answer.
http://www.backyardcitypools.com/images/bwp/Max-E-Therm-Manual.pdf
Posted on Aug 18, 2010
The heater turns on for about a minute... green light then the red light turns on then it powers off.
the red light is to say burner on so its obviously faulting as its trying to light so i would be getting your service agent to look for you unless its just a simple case of your gas being turned off to heater, if the gas supply is not getting to heater it will fault when lighting so check all gas stop valves are on to heater if this is not the problem and your getting gas to heater there is a fault in the ignition somewhere so get a service agent to fix as gas heaters can be dangerous to play with i would suggest any fault on heater would need a service agent to fix i've seen people try to do thier own and i'm suprised that the house has not burnt down and worse yet by killing themselves its a gas heater and needs an expert to look at it for you!!!!!!!!!!!
Dec 09, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Service light and ags light comes on after a minute or two
I had this problem. Jandy ended up replacing the burner from day 1 with the heater (LT400 propane). It was a manufacturing defect. Of course it took 5 trips from the "warranty" company to not fix it before they finally punted to Jandy. Then, there's only one Jandy service rep from VA to ME (I'm in PA).
Jan 27, 2010 | Jandy Laars Lt 400,000 Btu Heater
Sta-rite propane heater turns on, blower on but it doesn't fire
There can be a couple of reasons for this issue to occur. The first thing to check is the dsplay panel for which Service light is coming on. If it is the Service System light, then there is not enough flow of water in the system. You may need to clean your filter.
If it is the Service Heater light, then the problem is with the heater. What you can do is restart the heater and watch the display panel. If the water temp display is too high, or low, then the issue is the Thermister and it will need to be replaced. If the temps are about the same, then try and start the heater. The same issue may happen again, but that is what you actually want to happen. Once this does, take off the top two halves of the heater and turn the display panel over. There are diagnostic lights on the backside of the panel.
If there is a red light next to one of the following: AGS, AFS,
SFS, HLS, PS or THERMISTOR, then that is the item causing the problem with the heater. If you need an Owner's Manual, there is one online at the following link:
http://www.inyopools.com/owners_manual/sta-rite_heaters_max-e-therm.pdf
Jul 04, 2009 | Sta Rite Sta-Rite Max-E-Therm High...
Jandy pool heater model #LT400N-L service and ES1 light blinking
The heater won't fire up if there is no or inadequate water flow. Ck water pump and filters.
Jun 01, 2009 | Jandy Lite2 LG400 Ceramic Compact Heater
Pentair Heater shuts off prematurely when warming spa
check gas pressure could be running out or overheating
Mar 06, 2009 | Pentair MINIMAX NT TSI IGNITER
Laars Lt spa heater service light
replace temp sensor its by the plumbing inlets or mounted to top of heat exchange
Feb 22, 2009 | Jandy Laars Lt 250,000 Btu Heater
Sta Rite Sr333na Max E Therm Pool & Spa Heater Dual Electronic Ignition Lo Nox 333,000 Btu Natural Gas Logo
294 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
