Question about Samsung CXJ1352 13 in. TV/VCR Combo
A/v channel DOES THIS TV HAVE A A/V CHANNEL?
    President:
  • 1,099 Answers
this have av channel and the av port is at the side front view of the television and can change it to av by using the remote control of the television.
Take care..
Posted on Jun 01, 2010
What does RF CH mean?
What is the difference between a RF channel and a virtual channel? The RF channel is the channel that the TV station uses to broadcast its signal. Before the conversion to digital, TV stations were normally identified by their channel number, and most people knew that a particular network was on a specific TV channel. While analog broadcasting was being phased out and all TV stations were converting to digital broadcasting, it was necessary for the TV stations to continue to broadcast their analog signals on their original RF channels, and also broadcast their digital signals on a different RF channel. However, since the TV station used their broadcast channel as part of their identification, they wanted to keep using the same channel number. To allow this to happen, the new digital television broadcasting standards (ATSC) provided TV stations the ability to continue to use their original channel number and also tell the TV set to tune to the new RF broadcast channel when their virtual channel number was selected. The original channel number is called the virtual channel number, and it will be followed by a period and a second number (3.1, 7.1, etc.).
One of the benefits of converting to digital for the TV stations is that they now have the ability to transmit more than one program at the same time on the same RF channel. The number of additional channels they can broadcast is determined by the resolution of the program (SD vs. HD, text only, music only, etc.). The second number in their virtual channel number indicates that one of the additional programming sources from the same TV station is being viewed (10.2, 10.3, 10.4, etc.).
When selecting an antenna, it is important to understand the difference between the RF broadcast channel and the virtual channel. Antennas are designed to receive specific ranges of RF channels, and the antenna needs to be selected for the RF channel you wish to receive. TV stations broadcast in two broad frequency ranges, called VHF and UHF. RF channels 2 through 13 are considered VHF, and RF channels 14 through 51 are considered UHF. In order to pick up the channels, the antenna has to be designed for the correct frequency range. It is very common today to find that TV stations using virtual channels 2 through 13 are actually using RF broadcast channels in the UHF range. Although not as common, some TV stations using virtual channels 14 through 51 are actually transmitting in the VHF range. An antenna designed for only UHF channels will not work effectively for RF broadcast channels in the VHF range, and an antenna designed for only VHF channels will not work effectively for RF broadcast channels in the UHF range.
Apr 09, 2015 | Televison & Video
TV will not display picture or sound except for 1 station which appears to be 440. I can't change the channel either at the dials or remote. The display says EAS.
DONT USE the remote that came with your TV
use the buttons on the box to change the channel. did the channel change?
usually when someone only has one channel its because they are changing the tv channel not the cable box channel
think of it like this:
the TV is a monitor and should always be on the same channel (3, 4, hdmi, or whatever) its actually the box that tunes and the tv always stays on the same channel.
so if you change the tv channel you are no longer watching the output of the cable box.
USE the remote supplied by your cable provider
Aug 06, 2013 | Motorola Mobility DCH3416 (160 GB) DTV...
Whats the process to change RF to channel 4?
1 Press POWER to turn the power off.
2 Press TV/VCR, current VCR Output Channel will appear on the LCD display.
3 Each time TV/VCR is pressed for 2 seconds, the LCD display changes as follow
clock press tv/vcr RF3 2 secondes later RF4.
• VCR Output Channel is automatically set during EZ Set Up.
1. If Channel 3 (or 4) is an active broadcast channel in your area, the Channel 4 (or 3) will be set.
2. If both channel are the active channel or none active channel, the VCR Output Channel will be set to Channel 3.
• Cancelled the EZ Set Up by pressing POWER during EZ Set Up before setting the Output Channel.
• VCR Output Channel will not change to previous VCR Output Channel if TV/VCR is pressed continuosly for more than 2
seconds.
May 27, 2010 | Sharp VC-H965U VHS VCR
Getting a specific channel on the TV without using a remote
Usually if you go into the setup menu, there is an option to allow you to either "scan" for a channel, or "input" a channel. In this case, select "input" and see if the TV will allow you to press the up and down channel buttons and go to a specific channel. If so, when you get to channel 4, press the "add this channel" option (or whatever the menu option says) and you should then be able to go to channel 4 using the buttons on the front without skipping over it.
Jan 24, 2010 | Televison & Video
How do i tune my philips 3590H philips dvd recorder into digital
The User Manual for your DVD Recorder is available here... http://www.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_dfu_eng.pdf
Info related to your specific problem is as follows...
Setting your TV channel
programmes
Before the recorder can start recording
the TV channel programmes, you need to
search for the available TV channels and
store them in the recorder.
Note: Make sure you have successfully
made all the required connections to the
recorder, the TV and Satellite Receiver/
Cable Box (if any) and switched them on.
Tuner settings can only be changed
when there is no disc in the disc tray.
A Press SYSTEM-MENU on the remote
control.
�� The system menu appears on the TV.
B Use ���� keys to highlight
{ System Menu - Channel Setup }
and press ��.
Modify Channel Information
Sort Channels
Channel Search
Edit
Sort
C Use ���� keys to highlight { Channel
Search } and press OK.
�� The automatic TV channel search
starts. This process may take several
minutes. Once complete, the total
number of channels found appears on the
TV.
Automatically scan all the receivable analogue local TV
channels and store these channels on the recorder.
�� Use ���� keys to highlight { Channel Search } and press OK.
�� The automatic TV channel search starts. This process may take
several minutes. Once complete, the total number of channels found
and stored appears on the TV.
Modify Channel Adjust a stored TV channel to your preference, improve the
Information reception and the sound quality of that TV channel.
1) Use ���� keys to highlight { Modify Channel Information } and
press OK.
�� The channel menu appears.
2) Use ���� keys to select one of the options.
{ Name } – You can use the numeric keypad 0-9 to select
the channel preset number which you wish to
change.
– Use ����keys to change alphabet/ number and
use ���� keys to select different entry fi elds, then
press OK to confi rm.
{ Scan Mode } – Select TV channel search mode based on
channel allocation or frequency.
– Use ���� keys to select { Frequency },
{ Channel } or { S-Channel } (Special Channel),
then press OK to confi rm.
{ Frequency } – Shows the frequency of the current TV
channel.
– If required, use ���� keys to start the automatic
frequency search and press OK to confi rm.
{ TV System } – Set the TV system that produces the least
distortion of picture and sound.
– Use ���� keys to select a suitable sound mode,
then press OK to confi rm. (See chapter “TV
System Guide” at the back of this manual for
more information).
{ NICAM } – Turn on or off the digital sound transmission
system which improves the sound quality of the
TV channel.
– Use ���� keys to select { On } or { Off }, then
Dec 12, 2008 | Philips DVDR3380/05 DVD Recorder
I am stuck on channel 2
some tv's default to channel 2 after being unplugged.since it is a older tv ,the buttons on the remote and the tv maybe worn down.on the tv itself try pushing the buttons down a liitle harder. if you have aux or line in/video inputs,scroll down on the channel button to log into a aux channel for the dvd player.as for the remote try buying a cheap universal remote to see if that works.
good luck
wg
Feb 02, 2008 | Zenith A25A23W 25" TV
Can't get TV onto the AUX channel
Do you have the correct scart socket plugged in this is usually a common problem easily sorted..
swampy
Dec 15, 2007 | Toshiba 27D46 27" TV
You can purchase an RCA universal remote that will let you access the A-V inputs. These only cost about $10.00 or so. Stargazer
Sep 09, 2007 | RCA F25254GY 25" TV
TV Channels
SOUNDS LIKE WHAT HAPPENED TO ME WHEN THE CHANNEL GOT ACCIDENTALLY BLOCKED AS AN UNUSED CHANNEL CHECK YOUR MENU ON REMOTE FOR ADD AND REMOVE CHANNELS AND RELOAD THAT CHANNEL AS INSTRUCTS IN MANUAL FOR THE TV
Jul 17, 2007 | Emerson EWF2703 27" TV
Samsung CXJ1352 13 in. TV/VCR Combo Logo
289 people viewed this question
Jerry Greenberg
Jerry Greenberg
