Question about GE Quiet-Aire Ductless Mini Split System Air Conditioner
Im trying to clean the blower on my ductless a/c how do i do this from a-z
  • mopar440man May 28, 2010
    how old is the unit. it should not be dirty if you run it with the washable filters.
ARE YOU REFERRING TO THE INSIDE UNIT BLOWER
Posted on Jul 02, 2010
  • JIM PED Jul 03, 2010
    IS IT THE INDOOR OR OUTDOOR UNIT
Mitsubishi electric Mr Slim wall unit heat and air. strange smell coming out when air is on, we cleaned filters, but do not know where the heat exchange is or the the fan to clean them
Ductless split systems are know for creating a mildew looking "stuff" on the blower wheel. Try to open/move the louvers on the front of the indoor unit. By opening the "osculation blade"/louvers, you can see the blower wheel, normally blue in color. See if it has some mildew growing on it. If so, I found that a tooth brush and about 2 hrs labor does some good. I've found some aerosol spray, called mildew removal. Works great at covering up/controlling the smell. It's also possible that the unit is pulling air from the condensation drain line. These lines can for algae, and give us a sour yuck smell. To clean, use a wet vacuum, and clean from the outlet of the drain line. Hope this helps!
Aug 21, 2017 | Mitsubishi Heating & Cooling
How to replace the blower in a Senville SENA-24HF Mini Split Wall unit?
You have to pump down the a/c and remove the indoor unit. If not
The bottom of front side of front panel there are 3 screws. Unscrew and remove the front panel. Then unscrew PCB board. Then Unscrew the coil, and slightly keep upward and replace the blower.
Sep 08, 2015 | Senville 24000 BTU Energy Star Ductless...
WHAT IS REFRIGERANT SUCTION PRESSURE OF MY 1 TON SPLIT AC?
R22= 70-80psig
R410a=120-130psig
Depending on many variables such as blower speed, coils clean, indoor/outdoor temps.
Aug 05, 2015 | AMVENT 18000 Btu 1.5 Ton Ductless Mini...
My carrier split ac trip after some time and green light blinking contsly
If this is a ductless split call a tech! The ductless split systems can be a troublesome unit to diagnose. A few things to try. Clean air filters and ensure coil behind is clean. And build up or debris on blower wheel (indoor fan blades) will cause unit to fault. Turn off power at breaker or disconnect and clean (with water hose and medium pressure) the outdoor coil. Be sure you will not damage outdoor coils fins with too much water pressure. Turn power on. If this simple service don't do it again, call a tech! Be sure to ask if they have someone who is experienced with mini split systems and be patient. Even the best technician will need to call carrier for tech support.
Jun 04, 2015 | Carrier Heating & Cooling
Ductless Run from condenser to blower
Yes...also depends how many elbows you are using and height difference between indoor & outdoor unit
Dec 17, 2013 | Mitsubishi PUZHA36NHA2
My heater is flashing code 14 now and my fillters light is on...but my filters are spot less...whats the problem?
Code 14 is an indication of an over heat. If you cleaned the filters and still get the code 14 you need to look at the circulation fan blowers as well as the inside of the cabinet. A through cleaning of the stove may be in order. This will require taking the stove apart some. If you are not ready for that I would call a Rinnai service person.
Tom
Oct 22, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I ahve a rinnai enersaver 1004f model gas heater and i recently noticed that after several minutes sometimes just 2 minutes, the heater stops giving heat and the number 14 shows from the small LED where...
#14 is the code for over heat. Clean the circulating fan and blower blades. If there is anything on the top of the heater it need to go. Check the sides to make sure nothing is obstructing the air entering the back of the unit.
Tom Hawkins
hawkins111@gci.net
Jan 17, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Ductless heat pump systems
Heat pumps do loose their heating capacity and efficiency as temps drop. If you decide to rely on a heat pump you may want to make sure that your system has a back up heat strip, maybe even controled with an outdoor thermostat, if that is an option. The Mitsubishi is a great product.
Nov 15, 2007 | Mitsubishi MSH12TN Air Conditioner
GE Quiet-Aire Ductless Mini Split System Air Conditioner Logo
374 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
