Question about Cameras
Picture is not coming up on screen i got a message saying the camera isengaged doing something else consequently i cannot get a picture on my screen
  • 78 Answers
Remove the battery. Place the battery back in. Try again.
Patience - Practice zen gadgeting :) If this doesn't work, get back to me.
Posted on Apr 07, 2008
Kodak easyshare m583
I have never seen a camera where the display actually contains the words 'blah blah blah' . Are you sure that you have read them correctly ?
Oct 07, 2017 | Kodak EasyShare M530 Digital Camera
Does not work (blue screen)
Olympus Support number,
(800) 622-6372
There is something internal causing the issue. contact manufacturer
Nov 16, 2007 | Olympus Stylus 710 Digital Camera
Good afternoon! The problem I've been having with my fuji camera is that when I connect it to my laptop it doesn't recognize the new pictures I have on the camera...a message pops up on the screen...
Good afternoon! The reason why the picture cannot recognize : something virus in the camera; something wrong with your memory card;wrong file layout. The above reason may result in the bad connection.This 2 links is something about fuji a345 camera.you can have a look!
www.skiliwah.cn/
http://www.digitalcamera-parts.net/
MSN:e-8090team@hotmail.com
Aug 05, 2011 | Fuji FinePix A345 Digital Camera
Sdcard protect: when I plugg on camera an error message appears on screen " SDcard is protected " I tried to change SDcard and the same message related to sdcard appears . I can not unprotect...
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 25, 2011 | Intova CP8 Digital Camera
Write protect
When you disconnected the camera, did you use the "safely remove hardware" icon at the bottom of your computer screen?
Oct 28, 2009 | Olympus FE-210 Digital Camera
Help!
hi try turning on and taking hold of the end of the lense and gently pulling and twisting you may hear a click but dont force it. then turn off and on again. then you may want to try
Press Menu button
togle across from REC Mode to setup
togle down thrice from camera to setup 1
togle across into sub menu
togle down from four times to Initialize
togle across again to the sub-menu
togle up from cancel to OK
press center button to accept the OK choice
Screen changes and so press okay again
It should restart the camera
Opening on the 'Clock Set' screen
togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and not a hardware malfunction.
If it is working then don't forget to set your Clock.
May 30, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Error message 5e02
Turn on your camera, when the lense is opened, hold it till the blue screen appears, extend the lense to his maximum forcing it a little bit then when you turn off your camera, the noise won't be here. Turn on again your camera and hopes it works. I tried it on my camera, works well at the first try then again the error, i did it twice holding the lense when you turn it on, then it worked perfectly.
Hope it works for you.
P.S : my english isn't well but i hope it helps.
Oct 17, 2007 | Olympus Stylus 710 Digital Camera
Message on LCD screen
'No Picture' usually means just that. There are no images in the memory. So go take some pictures. Check you have the control to the picture taking mode and not the Viewing mode Give the manual a good read.
Jul 06, 2007 | Pentax EI-100 Digital Camera
Cameras Logo
43 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
