Question about NetGear RangeMax WPN824 Router
When i try to connect wirelessly to the router, it
When i try to connect wirelessly to the router, My Toshiba computer with Windows XP doesnt prompt me for the passcode, tries to connect and then just dies off. I am able to access internet using wired connection
  • 1,272 Answers
HI, please perform the below task to configure settings on the concerned computer:
Configure XP for wireless connection
Hope this allows you to resolve the issue. If you need any further assistance then please let me know.
Regards
Anand
Posted on Jun 09, 2010
My wireless internet stopped working. i have model #wrt54g v8. i have cable internet also. when the wireless stopped working cable company checked said everything on there part is fine. its pluged in. the...
When you plug in the ethernet cable the corresponding numbered indicator on the router should flash to indicate a LAN connection and some data flow from the router to the computer. This does not necessarily mean that there is data flow from the internet to your computer via the router. Simple check would be to use a smartphone and try and connect to WiFi on the router but restart the router first. If the smartphone is also having problems then the problem may be with your internet provider or the router. If the smartphone connects then restart the computer. If the computer still does not connect then try the following steps to refresh the computers IP address:
For Windows XP
Step 1
Click Start->Run, type cmd and press Enter.
Step 2
Type ipconfig /release at the prompt window, press Enter, it will release the current IP configuration.
Step 3
Type ipconfig /renew at the prompt window, press Enter, wait for a while, the DHCP server will assign a new IP address for your computer.
For Windows Vista& Windows 7
Step 1
Click Start on the task bar, type cmd into the search box and press Enter.
Step 2
Step 3
Type ipconfig /renew at the prompt window, wait for a while, the DHCP server will assign a new IP address for your computer.
For Windows 8 & Windows 8.1&10
Step 1
Press windows key and X key at the same time. Then click at Command Prompt.
Step 2
Type ipconfig /release at the Command Prompt window, press Enter, it will release the current IP configuration.
Step 3
Type ipconfig /renew at the Command Prompt window, wait for a while, the DHCP server will assign a new IP address for your computer.
Hope that helps.
https://fastproactiveit.com/
Proactive IT Support PC Repairs Laptop Repairs Custom Built PC Leading IT...
Sep 22, 2017 | Linksys WRT54G Wireless Router
Toshiba Satellite P10-S429 cannot acquire an IP address. Here's the deal: I'm running Windows XP SP3 on the Toshiba with a Linksys WUSB54GC v.3 wireless adapter. The laptop does not have a wireless...
I would start by downloading all available drivers from Toshiba, just in case some have been updated. If you hard wire the laptop and from the Toshiba web site, follow the prompts to find all drivers for your exact model.
Laptops LCD Televisions Projectors Medical Imaging More Toshiba America Inc
Mar 13, 2017 | Toshiba Satellite Pro L300-EZ1501 Notebook
Can't connect to the internet with router
1.Powercycle equipment ( Unplug power wait 15 seconds then plug back in. 2.Make sure connections are tight in to the router and to the modem. 3.Check you network settings Windows XP: Start/Run/Type ncpa.cpl and hit ok. Check and make sure that your connection doesnt say Connected Firewalled if it does to the left hand side you will see change windows firewall settings turn to off.If it doesnt say that double click the connection hit properties click on internet protocol and hit properties again,ensure that obtain ipaddress automatically is checked as well as obtain dns server automatically If not check them both and restart your computer. Windows Vista/7 Start/Search bar type ncpa.cpl right click on your connection and hit properties uncheck ipv6 and click on ipv4 and hit properties. After Ensure obtain ip address automatically is checked as well as Obtain DNS server automatically is checked restart computer. 4.Use command prompt: WIndows XP: Start/Run/Type cmd and hit ok Windows Vista/7 Start/All Programs/Accessories/Right Click Command Prompt and hit run as administrator. 5.Type in Command Prompt the Following Commands Each line is a seperate line is a new command simply press enter after each. netsh int ip reset reset.log netsh int ip delete arpcache netsh winsock reset ipconfig /flushdns 6.Restart Computer Final: If you still have issues connecting refer to router manufacture.
Jan 12, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Can not access router @ 192.168.1.1 wired or
try to double check you dafault gateway, perform ipconfig to verify. also check if you have static ip on your pc..
Hope it helps!
Feb 14, 2010 | Linksys Wireless-G WRT54G Router
Toshiba A105-S2712 Won't Recognize The Wireless Connection
Have you installed the driver for the router that you are using or using the inbuilt windows program to search for your wireless network?
If windows, are you searching all channels or is it set to only find unsecure networks whilst i assume yours is secure?
Jan 24, 2010 | Toshiba Satellite A105 Notebook
I cannot make a wireless connection my new laptop to the linksys router. My homenetwork works and my first laptop is connected to a wireless linksys connection. when adding another laptop I cannot make a...
then it's the second computer's problem, try repairing the connection, turning the wireless switch on and off, rebooting, and if your using vista use windows system file checker
or if xp, put this in either command prompt or run
chkdsk /r
Sep 30, 2009 | Linksys Wireless-G WRT54GS Router...
I have a Compaq PC with Windows XP and the flat I've moved into has wireless broadband - how do I connect to it?
You can use a wireless network to share Internet access, files, printers, and more. Or you can use it to surf the Web while you're sitting on your couch or in your yard. Plus, it's easier to install than you think.
There are 4 steps to creating a wireless network:
1.
Choose your wireless equipment
2.
Connect your wireless router
3.
Configure your wireless router
4.
Connect your computers
For Windows XP users, Windows XP Service Pack 2 is not required for wireless networking, but it does make things much easier. Service Pack 2 also helps protect you against hackers, worms, and other Internet intruders.
If your computer does not have wireless network support built in, plug your network adapter into your USB port, and place the antenna on top of your computer (in the case of a desktop computer), or insert the network adapter into an empty PC card slot (in the case of a laptop). Windows XP will automatically detect the new adapter, and may prompt you to insert the CD that came with your adapter. The on-screen instructions will guide you through the configuration process.
Note: The steps below only apply if you're using Windows XP Service Pack 2. If you're running Windows XP and you don't have Service Pack 2 yet, plug your computer into your wireless router and download and install Windows XP Service Pack 2.
Windows XP should show an icon with a notification that says it has found a wireless network.
wireless_connected.gifFollow these steps to connect your computer to your wireless network:
1.
Right-click the wireless network icon in the lower-right corner of your screen, and then click View Available Wireless Networks. If you run into any problems, consult the documentation that came with your network adapter. Don't be afraid to call their tech support.
2.
The Wireless Network Connection window should appear and you should see your wireless network listed with the network name you chose. If you don't see your network, click Refresh network list in the upper-left corner. Click your network, and then click Connect in the lower-right corner.
wireless_chooseconnection.gif 3.
Windows XP prompts you to enter a key. Type the encryption key that you wrote down earlier in both the Network key and Confirm network key boxes, and then click Connect.
4.
Windows XP will show its progress as it connects to your network. After you're connected, you can now close the Wireless Network Connection window. You're done.
Note: If the Wireless Network Connection window continues to show Acquiring Network Address, you may have mistyped the encryption key.
Nov 05, 2008 | Compaq Computers & Internet
Linksys can't find ip address
TCP/IP stack repair options for use with Windows XP with SP2 & Vista.
For XP, Start, Run, CMD to open a command prompt.
For Vista, Start, Programs\Accessories and right click on Command Prompt, select "Run as Administrator" to open a command prompt.
Reset WINSOCK entries to installation defaults: netsh winsock reset catalog
Reset TCP/IP stack to installation defaults. netsh int ip reset reset.log
Reboot the machine.
Aug 13, 2008 | Linksys Wireless-G WRT54G Router
Router not being recongized
if your running windows xp then you should remove any programs that you installed to run router then look into hardware manager and uninstall router and restart computer . then try once again plug in router once comp boots and let win xp load the correct drivers if this doesnt work go to windows update website and get all available updates including all hardware updated then try installing again good luck with it
Jul 13, 2008 | D-Link AirPlus DI-524 Wireless Router
NetGear RangeMax WPN824 Router Logo
29 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
